Any downsides to a single piece drive shaft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Dec 28, 2016.
  1. Oct 21, 2018 at 12:38 PM
    #41
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I believe I got my leaf shims from Wheelers Offroad. They are cheap and go on the bottom of the leaf perch and are mounted using the Springs Center Bolt.
    After the post you quoted, I actually add 2 more 1/4" shims to the center carrier bearing mount to give me 1" of carrier bearing drop, and it actually got smoother. This all takes time and patience. I ended up adjusting the rear drive shaft 6 times, and each time I took it for a test drive and noted the difference. There is no cookie cutter approach to this, and if you have to pay a shop to figure it out you might as well forget it.
    Small side of shim towards front of truck.
    lower your 4x4 and mcharfauros like this.
  2. Jan 6, 2019 at 5:16 PM
    #42
    Jeremy2046
    Jeremy2046 Member
    Jeremy
    18 tacoma sport
    None
    Well it depends on which way you need your pinion to go. My blocks were fat side back however now t get my pinion angle and transfer caee angle parallel/offsetting angles I actually need about 3.5 degrees putting the pinion angle down now. At least I think I have that right. Am missing something?
    MTopp likes this.
