Any EGCS issues with Bilstein 5100’s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roddy13, Feb 3, 2019.
  1. Feb 3, 2019 at 11:42 AM
    Roddy13
    Roddy13 [OP] Well-Known Member
    Ive heard that the EGCS bushing is more common if an issue at 2” of lift/level or more.
    With bilstein 5100’s set at the 4th notch I should be at about 1.6”... am I likely to avoid the EGCS bushing issues with this set up?
    Thanks
    VaToy likes this.
  2. Feb 3, 2019 at 11:43 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Every truck is different but when I did them at 1.75 on my 15 it arrived fairly quickly.
  3. Feb 3, 2019 at 11:44 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    It's best to get it done while you're doing the front suspension. That being said...I'm on 5100s with 885 coils. I have around that amount of lift with no issues so far..roughly 12k miles. I still planing on putting in that bushing though.
  4. Feb 3, 2019 at 11:47 AM
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    5100s with 887 coils and don't have the vibes... yet. Bought the bushing when I bought the lift just never installed it. Around 4k miles since the lift. Its honestly a case by case basis
    Roddy13[OP] likes this.
  5. Feb 3, 2019 at 12:59 PM
    longspur
    longspur Well-Known Member
    Tim
    Western Ky.
    2015 extended cab 4x4 4cyl 5 speed
    Just installed bushing on a stock 17 SR, just never know. Also installed bushing on a 07 and a 14 that started having vibes after lifting. The vibes on the stock 17 was worse than the other 2 after lifting them. Just a roll of the dice
  6. Feb 3, 2019 at 1:21 PM
    SpeySquatch
    2016 TRD OR DCSB
    I put my lift at 1.5-1.75” in the front, had vines, put in ECGS, vibes gone
  7. Feb 3, 2019 at 1:52 PM
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    Have 5100s up front 1.5inch no vibes with 2k miles on them so far
  8. Feb 3, 2019 at 2:14 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I set mine on the 4th setting and after the 265/70/17 I got about 2 3/4 up front, running a one inch block in the back. I was worried about needing to replace mine later but great advice was given here by many as to doing it while the lift is going on. 4k miles on the lift and bushing and all is well .Do it now and thank us all later.
  9. Feb 3, 2019 at 2:15 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    I've got mine at 4th notch. No issues.
  10. Feb 3, 2019 at 2:17 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I have 1.75" of front lift and zero vibes for 25000 km.
    VaToy likes this.
  11. Feb 3, 2019 at 3:53 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just do it while you have the suspension out
    VaToy likes this.
  12. Feb 3, 2019 at 7:00 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    If you care about ride quality, why dont you upgrade the coils to 888 or 887 while you are at it....relatively cheap upgrade for noticeably better ride...and do the ecg while you are at it. Over 20k and no probs
    Dr. Emmett Brown likes this.
  13. Feb 3, 2019 at 7:08 PM
    Dr. Emmett Brown
    I didn't notice too much increase harshness in ride quality when setting mine at 4th notch but I'm really curious to see how my ride quality changes when I swap out my oem coils for the 888s. Still waiting for delivery on them and my Dakar HD pack.
  14. Feb 3, 2019 at 7:37 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    44k miles of 4th notch, no vibes other than what was there already. My truck has always vibrated around 70-80mph, shakes the passenger seat like turbulence. :confused:
    jerryb1984 likes this.
  15. Feb 3, 2019 at 11:43 PM
    cruxx
    Huy
    2017 TRD Sport
    I dont know what your setup feels like but a separate coil to do the lifting would soften the ride
  16. Feb 3, 2019 at 11:58 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    No bushibg, no problem. Guessing it's a truck to truck basis
  17. Feb 4, 2019 at 12:39 AM
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    6112s
    5/6 notch
    No vibes
