any experience w/ uhaul trailers?
Discussion in 'Towing' started by northside, Dec 5, 2010.
  1. Dec 22, 2010 at 7:34 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    2nd hens don't have an o/d button. They have 1, 2, 3, 4, abduction D. D is.our o/d.
  2. Dec 22, 2010 at 10:41 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Beaverton, OR
    SWB 05 Double Cab 4x4 TRD Off Road
    K so keep it in (4) so the rpm revs higher even though it sounds like the engine is working harder but its really not? Thanks!
    Oh how I wish my truck was stock right now. Gas will suck!! Hahah yeah and 2nd gens don't have the "OD button". I knew what you meant though because I used to have a 2002 double cab.
  3. Dec 24, 2010 at 1:43 AM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    pics later but uhaul blows, showed up clear on the other end of town and they didnt have the 5x8 that was ordered. send up to another spot and wound up with the 6x12
    super impressed with my t100 ... towed good and 16 mpg doing it! pics later
  4. Dec 24, 2010 at 5:17 PM
    97T
    Melt
    Littleton, CO
    heres the pics .... this is my first time towing anything with my t100, otherwise heavist thing ive hauled so far is my ATV
    in san francisco ... by the way the bridge toll over the golden gate was $12!! :eek: they charge per axle
    when summer comes and my dad hasnt bought a motorhome yet, ill likely have to flat tow his 59 cj5 jeep up to the mtns for our family camping trip, should be great and a hell of a lot better than towing it with my old 4cyl 99 mazda
  5. Jan 28, 2011 at 5:03 PM
    northside
    northside [OP] Member
    canadian rockies
    96 XtraCab V6 4x4
    307,xxx miles
    Hey, just wanted to update and say that the Tacoma did great towing the 6x12. Had some crappy conditions right off the bat with snow and ice, the trailer wanted to push a bit down hills but I just downshifted early and took it easy and had no problems. Dropped into 4wd for some icy climbs to get better traction as well, that was a heavy load! (trailer was 1920 lbs empty, and I filled it)
    Once the roads were clear I occasionally found myself doing 75 mph+ without any bad behaviors from the truck or trailer. As always though, one of my favorite things about towing a trailer is unhitching it and getting back the truck you remember!
    Never actually checked mileage, but I expected to be stopping for gas a lot more often than I did so it couldn't have been bad.
  6. Jan 28, 2011 at 5:16 PM
    Snowman11
    Snowman11 Supreme Ruler
    Snow
    Near Philly
    2011 DCLB TuRD Sport
    5100 Billies
    The overdrive is for the older models. X2 on 4th gear if you have the newer style auto. That reduces only by a little so it is essentially the same thing.
    Tire pressure? Read what your tire says on it and keep it close to max PSI for towing.
    I hauled a Uhaul 6x12 with a 2000 F150 and with a '05 Frontier. Both were the same - the brake built into the hitch constantly jerks you around on all bumps but it's livable. I didn't think braking was bad due to the hitch brake however these little V6's won't pull well up hills so take it easy. Make sure you change the trans fluid and rear diff fluid after your trip.
  7. Jan 28, 2011 at 5:26 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    heres mine towing a 6x12:
    it did good, i did however experience the tranny wanting to constantly downshift, i drove this bad boy from south florida to western washington..total weight including trailer came out to around 3600lbs..i couldnt put it in cruise control because it wanted to downshift, even on flat ground, i just adjusted throttle according to how the truck felt, i can kinda sense when its gonna downshift
  8. Jan 29, 2011 at 5:49 PM
    sil3ncer7
    sil3ncer7 Gimme some mud n ull have a good time
    Stafford Tx
    06, white, TRD offroad, and muddy
    3" Toytec, 285/70/16. Installing, sliders, cb, firestik antenna, Workin for 285's, BedBox, and undercover winch when weather gets warm.
    I just pulled a loaded 10' from St. Louis MO to Houston Tx, and it pulled great with my '06. I was able to use cruise control at times, mostly. but there were obvs times I had to manually adjust speed accordingly.
