Any FAA/Federal Employees out there? Even Police Officers?
Discussion in 'Jobs & Careers' started by jjew18, May 6, 2011.
Do I answer "I am Aware" or "Not Aware" about instances?
Poll closed Jun 5, 2011.
  1. I am Aware
    25.0%
  2. Not Aware
    75.0%
  1. May 6, 2011 at 7:15 AM
    jjew18
    jjew18 [OP] the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I have been selected for an Air Traffic Control Specialist position and I am filling out my paperwork. (Below) This is from the Employment Agreement and not the actual background check, not sure how I should answer.
    Here is my predicament in "short":
    I received my email with all the forms I need to fill out, one being the Employment Agreement. On this form it has a section stating that the clearance process takes 45-60 days and certain occurences could cause it to take longer such as: (verbatim)
    -any arrests
    -being fired from employment or removed for cause
    -any history of involvement with illegal drugs (buying, selling, recreational use, abuse)
    -discharge from the military under other than an honorable discharge (i.e., general or dishonorable)
    -discharge from the military for reasons associated with health status
    Then at the end it of the form it asks you to check one of the following boxes:
    -I am not aware of any situations in my background that should delay or prevent my employment with the FAA as an Air Traffic Controller Specialist.
    -I understand that situations in my background require further evaluation and will delay the processing of my application.
    Now my situation, I ran with a "rough crowd" when I was younger (15 or 16), got pulled over with a buddy of mine and we went down to juvi for possesion. Technically we were arrested, but no conviction and was even able to have it removed from my record all together because it was not mine (for real) and it was such a small amount. So how do I answer the above question? Is this something I even need to worry about showing up? Technically I was "involved" and "arrested" but never anything came of it. I have since been employed in the airline industry with a job requiring FAA security clearance and nothing came up.
    I want to check the "I am aware" box, but don't know if this will show up and I don't want to draw attention to something that doesn't need it. If I mark yes, is this past "involvement" with marijuana a disqualifier? My step-mom is a retired controller who says zero tolerance, but I think she is thinking about once I am on the job.
    Also note that the actual background check form states to list any criminal offenses in the past 7 years (it doesn't say that is all it checks, but it leads one to believe they won't look further).
    Sorry for the lenghty thread!
  2. May 6, 2011 at 7:27 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Bump for help!
    Just FYI the Background Check form is the SF-85P, I believe this is for any governement job that needs security clearance.
  3. May 6, 2011 at 7:34 AM
    jrw1965
    jrw1965 Well-Known Member
    Southern Maryland
    '08 dbl cab long bed 4 x 4
    Front tint, Stainless steel nerf bars, Leer tonneau, Rear spring TSB, Michelin LTX A/T2 265 70 16, Pioneer AVIC X910 so far
    Dont say anything about it. You were under age. I'm not a lawyer, but I dont think anyone can give any info about someone under the age of 18.
  4. May 6, 2011 at 7:37 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Just FYI, that is the other thing the SF-85P states:
    List offenses for the last 7 years but not before your 16th birthday. It still leads me to believe that they only look 7 years, but if not this happened, I believe right after 16.
  5. May 6, 2011 at 7:40 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Hmm... I am not sure whether or not something you did but were never convicted for would fall under that category. I just had to go through this a few months ago, but I also have a clean record. I would personally mark "I understand that situations in my background..." The whole thing is that it will take 60 days for an investigator to even see your paperwork. After that point, it all happens very fast. You would then be able to explain to them the situation and your reasoning for answering why you did. It did happen, and it was possession of an illegal substance. If they want to dig (which they will), they can find that.
  6. May 6, 2011 at 7:55 AM
    MooseHead
    MooseHead Member
    Ed
    Gig Harbor, Washington
    2011 TRD D/cab V6 Auto 4x4
    3" lift, 265 75/16 A/T, Snug shell w/built-in rack, WeatherTech mats & side window deflectors, Pop-n-Lock tailgate handle, neoprene seat covers (front) (GTCovers), Redline Elite Hood Supports, Elusive Elements Grille, PIAA 520 ATP, 12V Sea Blue Block, 12v underhood and bed outlets, disabled seatbelt warning chime
    Just spoke to a friend of mine that processing security clearance for the federal government. They will not go to the juvi records. However, since it does ask whether you have a history of - he indicated that it would be best to indicate the circumstances and that you have never used again. Be truthful. They will only look back 7 years, but that is to determine whether you are truthful and if something comes up - then your clearance could be questionable. I have a TS clearance and they will contact neighbors, friends, etc. Look at it as if it were a tree. You start at the base of the tree and the investigator will branch out where the lead that them. It is your call, but better to be truthful in the process.
  7. May 6, 2011 at 7:58 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    ^ Thanks, that is pretty darn close to the answer I am looking for.
    If anyone does know, even if this offense does show up, is this an auto disqualifier for ATC? I wouldn't think so, but it is the FAA.
  8. May 6, 2011 at 9:03 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Where are all the law officers on this? I don't know exactly what you have to go through, but I'm sure you might know a bit about background checks?
  9. May 6, 2011 at 9:37 AM
    TacoTabe
    TacoTabe Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    Not sure what kind of background check they do, but just FYI-
    I believe it is illegal to demand that an applicant admit to crimes committed as a minor, if the final disposition of the case included that the person's record was expunged/sealed. There is an exception to this though- and its government agencies. At least from my experience, I was expected to admit to everything, even shit that I wasnt ever caught doing.
    And another FYI-just cuz ur record was 'sealed' doesnt mean shit- there is still a record of what happened- and government agencies can access these records, with your permission. So the easy way they do this is to have you sign a consent form allowing them to. You dont sign the consent, you are removed from consideration for the job...
    Not sure how this applies to your specific situation, as mine was for local law enforcement, but I hope the info helped
  10. May 6, 2011 at 9:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would put not aware because, although you were taken into custody, it was removed from your record and you were never convicted. If you are asked about it, I would not lie, tell them the whole story but in the end I think you could truthfully say you did not feel it was something of relevance since it was supposedly removed from your record.
  11. May 6, 2011 at 9:59 AM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    if its a police (federal, state, city) type background check, you've got to put EVERYTHING to your knowledge from the last 5 years. if you lie or "forget" they will find out anyways and use it against you for that position. as for the drugs part, it's not just within 5 years its "any history" that they can prove.
    juvenile crimes don't need told. i did though and they still accepted my application.
  12. May 6, 2011 at 10:01 AM
    meeestirg
    Vance County, NC
    oh my application only said 5 years. OP record 7 years just to be safe
  13. May 6, 2011 at 10:14 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Trust me that is exactly the debate I have in my head. Just because it is not going to show up when I apply at Arby's doesn't mean that if Uncle Sam wants it he can't have it.
    And yes it helps, thank you!
  14. May 6, 2011 at 10:15 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    The background specifically asks for 7 years. Thanks for the help.
  15. May 6, 2011 at 11:00 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Any other professional advice/opinions! I have to have my paperwork in soon, would like to have it in today!
    P.S. - rest assured I am not solely making a decision on everyone's opinions, just getting some thoughts on it.
  16. May 6, 2011 at 12:23 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Alright, the deed is done, sent in my paperwork, checked that I am aware of things that may come up. Wish me luck!
  17. May 6, 2011 at 1:56 PM
    meeestirg
    Vance County, NC
    good luck!
  18. May 6, 2011 at 2:15 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Did t read anything, just the first 3 posts but wouldnt they be able to dig this page up on you if they really wanted too?
  19. May 6, 2011 at 2:22 PM
    meeestirg
    Vance County, NC
    the govt. could pretty much do anything and deny it if they wanted to.
  20. May 6, 2011 at 2:48 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    That's more or less what I wanted to know, do they want to dig this up?
