Any fellow survivalists utilize their truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jez, Oct 31, 2011.
  1. Oct 16, 2014 at 9:00 PM
    #2581
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That's a great idea with the magnets. I'm going to use that one.
  2. Oct 16, 2014 at 9:06 PM
    #2582
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    I keep several of those magnets in the truck. I also have 2 tied with large lengths of braided fishing line in case I drop something like a lug nut in a hole. Playing around, I found that 2 hard drive magnets are strong enough to lift a crowbar out of a manhole, 1 is strong enough for a heavy hammer.
  3. Oct 16, 2014 at 10:24 PM
    #2583
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Those look like the Ziploc containers that walmart has, great containers but I wanted a taller container and I put a hole in one on the dunes... The cabelas container are more rugged... ..
  4. Oct 16, 2014 at 11:28 PM
    #2584
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    I chuckled at first then remembered my G/F who works in health care had to go for Ebola training yesterday. :(:(:(:(:(:eek::eek::eek::eek::eek:
    Calgary has already setup a treatment centre. Definitely a good time to stalk up on supplies.
  5. Oct 16, 2014 at 11:53 PM
    #2585
    Theloraxcross
    Theloraxcross "He's Got the Crazy Eye"
    Joseph
    San Angelo Tx
    08 AC TRD OR
    Does anyone have an opinion on whether gas or propane generators are better? Seems like the propane would last a lot longer due to it's nature. I have no experience with either. Just wondering.
  6. Oct 17, 2014 at 12:13 AM
    #2586
    ChiveOn
    A BC Boy in Calgary
    True, but if you are asking this from a survivalists point of view I would go with gas as it is more available and common.
    If Diesel is the in the equation then game over...Diesel Owns All
  7. Oct 17, 2014 at 4:53 AM
    #2587
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    The biggest advantage to propane over gas for a generator is how easy it is to store. It doesn't go bad after a year like a tank of gas will, and it starts just as easy after a year of sitting as it does when you're using it every day.
    But I agree, if you can swing it, diesel's the way to go for a generator. It's a stable fuel for storage and isn't ridiculously more expensive than gas. Plus, #2 heating fuel is (typically) made to the same standards as Agricultural Diesel fuel, so if you've got oil heat, you've potentially got a 250 gallon storage tank full of generator fuel sitting right in your cellar. (Call your heating oil supplier and ask if their #2 heating fuel is also approved for use as Ag Diesel before you count on this for an emergency, though!) Or you can always switch your home heat fuel to #2 diesel. Your boiler/furnace won't care, and even though #2 diesel is usually more expensive per gallon, a lot of times it works out to be pretty close to home heating fuel in a cost-per-BTU scale.
  8. Oct 17, 2014 at 5:47 AM
    #2588
    Marky
    Marky Well-Known Member
    Roanoke VA
    2014 DCLB Super White
    FLTruck's 2014 OEM Nav upgrade!
    I got a dual fuel conversion on my Honda 2000i, so it runs fine on gas or propane. Best of both worlds. And yes, these things are SUPER quiet. Pricey, but quiet.
  9. Oct 17, 2014 at 5:32 PM
    #2589
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    This.
    Otherwise, I prefer gas because that's what all my other engines use. Wife's car, 7 motorcycles, generator and can be used for my Coleman camping stove. I do have propane heaters and a propane grill. So the dual fuel would be optimum.
  10. Oct 17, 2014 at 6:05 PM
    #2590
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Which is why gasoline will be the first thing to run out. I work for the .gov and run several remote mountaintop sites, a doppler radar, and an office building with diesel generators. A couple are propane, but they are very small light use gen sets. We mix some Kerosene in with the diesel to prevent gelling, and it stores for years with no additives or maintenance. We store a lot of fuel, mostly because it may be years before the budget allows a refill. You can store gasoline, but it's difficult. The other thing to consider is that volume wise, diesel has more energy than any other fuel. I don't know about you, but around my place space is limited. You can run a generator longer on diesel than gas or propane. A diesel generator can also run on waste motor oil, canola oil, peanut oil, etc... and the diesel generators last for thousands of hours longer than the LPG or gasoline gen sets do... food for thought. My plan is to not use any more juice than I can produce with two 75W solar panels, but I understand that's not an option for most people.
  11. Oct 17, 2014 at 6:41 PM
    #2591
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    My plans as well is to stay in my home till shit calms down.I have more than enough supplies for 6-8 months for 3 people 2 satillite phones and a ham radio.
    I Have a close support group of well trained and expericened ex military Persoanl we will band together till all is exhausted here and make the appropiate move at that time.
  12. Oct 17, 2014 at 8:26 PM
    #2592
    shr133
    Muskego, WI
    2010 V6 Sport
    I'm bugging in also, safest way to go plus living in the north takes tons of gear. Worst case I have back up locations to bug out to... I have a gas generator but even with 20 gallons that is not a lot of run time. I'm also going to get solar panels to run things during the day...
  13. Oct 18, 2014 at 7:48 AM
    #2593
    Jefes Taco
    Denver, CO
    Honda doesn't make a diesel genny. :D
    I agree with all your points. I have no diesel engines any more. Mine is a short term plan. If we need to go longer than things have gone way bad and I doubt many of us, even prepers, will be able to sustain any sort of normality. Solar is the best option for electricity for this type of situation. But my fear would be those that are unprepared trying to take our/your supplies by force. You would need to be in isolation in order to keep that from happening. Lay low and don't show your cards.
  14. Oct 18, 2014 at 7:49 AM
    #2594
    Jefes Taco
    Denver, CO
    Bug in is the best option unless there's a real reason to leave.
  15. Oct 18, 2014 at 8:25 AM
    #2595
    username
    username Fluffer
    Pendleton, Or
    mostly stock
  16. Oct 18, 2014 at 9:01 AM
    #2596
    CVTejas
    CVTejas CVTejas
    Charles
    Fort Worth, TX
    2010 Taco 4x4 TRD Sport
    Farad Cold Air Intake, BFG All Terrains, ARE Z-Series Deluxe Fiberglass Top w/ Keyless Entry and LED interior lighting,Road Armor front bumper w PIAA 510 driving lights, Edlebrock adjustable shocks w factory coils, road Armor front bumper. Kenwood DDX8901HD
    Everyone seems worried about electricity for their homes and how they can bug in for months if they have a generator. If the SHTF and it's a long term power outage, you won't have running satire for more than a couple days. Not only will it not becoming out of your tap, but your toilets won't be working. More importantly for those of us on city sewage, the sewage collection systems that are run by electric pumps won't be running which means that sewage will eventually backup to everyone's house.
    Lastly, if you are the only one on your street or block with a generator running, everyone is going to hear it as well as see your lights on and come to you because "it's your duty" to share what you saved for your family with everyone else, because that's the mindset of the general public.
    If it's just bad weather, I'm good for two weeks at home, If it's anything else, it's bug out time with a few select folks. Water pumps, purification, first aid, fuel pumps, are just the beginning of the items to consider. You should have your emergency plans for bugging in, bugging out via vehicle, and finally a 3 day plan for on foot. After that, you need a new plan.
  17. Oct 18, 2014 at 9:20 AM
    #2597
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    12KW, $9000, you can run 3-4 homes on that :eek: Plenty of power, quiet, but expensive. I guess you have to set your priorities. I have a 4KW gasser, more than enough to run my well and heat (pellet stove), a few lights, and charge some batteries:thumbsup: No sewage worries I have a septic system:thumbsup::thumbsup:
  18. Oct 18, 2014 at 9:27 AM
    #2598
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    It's just proper planning to have a well and septic system. In the old days, many homes also had cisterns. I like that idea, but haven't really figured out where I would put the damn thing.
    Everyone in this thread preps for a different scenario. That's ok. No matter what we anticipate, it's good wholesome fun.
  19. Oct 18, 2014 at 12:47 PM
    #2599
    robssol
    Rob
    S. Wisconsin
    I thought cisterns were illegal in OR, or was it ID? Some states have restrictions on harvesting water, CRAZY:eek:!
  20. Oct 18, 2014 at 1:53 PM
    #2600
    1980
    1980 Well-Known Member
    The Dust Bowl
    Yeah, western water rights are a mess. Someone once arrested a lady because she put a barrel under a downspout so that she could get rainwater to wash her hair.
    http://boingboing.net/2009/03/18/people-who-use-barre.html
    You can have a backup cistern though if it contains water you have paid for.
    Make a pond and spend a month in jail:
    http://www.digitaljournal.com/article/329723
