Any fellow survivalists utilize their truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jez, Oct 31, 2011.
  1. Oct 22, 2014 at 1:08 PM
    #2621
    tacomacrazy
    tacomacrazy ExPo Truck
    Bryant
    Coral Gables, FL
    07 DC 4x4 TRD Offroad
    HIDs 10k & 3k, AFE Intake, LEDs Red Map & dome, Pioneer 4300 Walker Evan 2.5 coilover 2.0 rear with all pro expo leaf pack. SnugTop Campershell Famous Fab rear bumper/ tire carrier. Dual Battery System Upgrade 250a Alternator
    I was thinking since i use up the 10 gals in the truck before filling up eventaully i can treat the gas i have stored up.. correct? those additives are good for gas and other fuels?
  2. Oct 22, 2014 at 3:07 PM
    #2622
    1980
    1980 Well-Known Member
    The Dust Bowl
    Probably all you would need to do is to re-grease the pump with food grade grease or silicone.
    A lot of things are now "non-approved" which didn't do most of us any harm. I think much if this is because companies have to be super-safe in today's litigious society on the off chance that one person with a severely compromised system will react adversely. In an emergency situation you can get by.
    In the Army we had sort-of filters that would clean swamp water until you could barely see the brown then added sodium hypochlorite to the Lister bag to sterilize it. The resulting water was sort of like drinking from a swimming pool but it kept you alive and didn't kill you.
  3. Oct 22, 2014 at 3:29 PM
    #2623
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    [/QUOTE]I keep my spare fuel in the garage. I don't have a truck cap on mine, so I don't want to keep an extra 10 gallons of fuel out there where any jackass can wander off with it. I generally try to keep a spare 25 gallons of gasoline on hand, and rotate it out every few months. I figure even if I'm not driving, my coleman stove and lantern are both dual fuel and can run on gasoline. I usually keep 10 gallons of diesel (for the tractor) on hand as well, but that stuff stores forever and the tractor's a real fuel sipper, so it's easier.
    Before they switched to ethanol gas I had a 50 gallon drum with a hand pump that I used, but the ethanol stuff doesn't store long enough for me to bother keeping that much on hand any more.[/QUOTE]
    I installed two d ring loops, set the cans in, and run a chain trough them to keep douchebags from stealing them. Granted someone could cut the chain but if I had a topper they could also break a window.
    I'll post pics later.
    Also I bolted a 50cal ammo box to the factory rails for a toolbox.
  4. Oct 22, 2014 at 3:44 PM
    #2624
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Exactly what I did. I bought new leathers for it, boiled them, and greased them with food grade silicone grease.
    Only downside is that since it's just a backup I tear it down whenever I do use it and regrease the leathers to make sure they don't dry out by the time I need the pump again. I've got a couple of spare sets as a just-in-case, but I'd rather not have to use them up faster than I have to.
  5. Oct 22, 2014 at 11:02 PM
    #2625
    Theloraxcross
    Theloraxcross "He's Got the Crazy Eye"
    Joseph
    San Angelo Tx
    08 AC TRD OR
    Well, decided against the land as the realtor could'nt get me any answers that I needed. The right place will come up eventually.
  6. Oct 23, 2014 at 4:27 AM
    #2626
    Noelie84
    Noel
    Wales, Maine
    Sorry to hear that. You're right, though. Eventually the right place will show up.
    I can't even count how many places we looked at when we were shopping for a house or land to build one on. Patience is key; I've got a couple of friends who are stuck with problems because they didn't do the research before they signed on the dotted line.
  7. Oct 23, 2014 at 4:31 AM
    #2627
    Theloraxcross
    Joseph
    San Angelo Tx
    08 AC TRD OR
    Thanks for the support. I mean that. I had it in my mind that if the land doesn't convince that thats where I need to be than I would listen.
  8. Oct 23, 2014 at 6:24 AM
    #2628
    TRD2013Chris
    TRD2013Chris Well-Known Member
    chris
    CT
    Black 2013 Tacoma TRD Sport Dbl Cab Long bed
    I have build in flame thrower in the bed the my truck!
  9. Oct 23, 2014 at 7:00 AM
    #2629
    Noelie84
    Noel
    Wales, Maine
    Hopefully your flamethrower building skills exceed your sentence building skills.
    :D
  10. Oct 23, 2014 at 7:05 AM
    #2630
    TRD2013Chris
    chris
    CT
    LMAO i was asking for that ONE! Well I burred myself with it and lost one eye and can hardly see out of one eye!
  11. Oct 23, 2014 at 10:21 AM
    #2631
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    Smart move--- get your technicians license than get your general license and you're good to go KD0JXB---Jim
  12. Oct 23, 2014 at 10:45 AM
    #2632
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Not sure if it has been covered yet, but in a pinch, the rubber bed mat could be used for shelter creation.
  13. Oct 23, 2014 at 1:53 PM
    #2633
    0mechanicalskills
    0mechanicalskills Active Member
    Chad
    Ocean Beach, CA
    08 Prerunner SR5, work in progress
    K&N Filter, 5100's on all 4 corners
    This thread is why I joined TW. Just starting this mission. Like you OP, not an end of the world prepper, just a guy who would like to be a little more self sufficient than the rest. I am going to borrow some of your ideas and be sure I have better emergency provisions. Any suggestions for someone, just starting? What would you ensure you had first?
  14. Oct 23, 2014 at 4:32 PM
    #2634
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I've got MREs, heat blankets, fire starters, medical supplies, machete, ammo, saws, axe, knives, water, and an emergency tool kit in my truck.
    Edit: Also installed a CB in my truck for when cell service goes down.
  15. Oct 23, 2014 at 6:18 PM
    #2635
    mad monk
    mad monk Well-Known Member
    mid atlantic
    2007 TRD SR5 DCLB
    basics - westin nerf bars, extang tonno audio - JVC HU w/ axxess interface mod misc - screen cover for cabin air intake. Weathertech floor mats front & rear.
    so what's involved with getting a ham license and what it cost to get a basic ham radio setup?
  16. Oct 23, 2014 at 7:56 PM
    #2636
    G.T.
    G.T.
    CONUS
    Study the test which is published online for free and then make arrangements with your local amateur radio club to arrive during their testing day with your small fee - $15.00USD - and take it.
    You will find that many times those same local clubs have "loaner" gear to get you started or some have even used their collective buying power to assemble starter kits that will cost you less. Lots of great technical advice as well as help setting up and troubleshooting a base station or mobile radio will be available too.
    You can easily do this for under a hundred dollars and build from there if you have the inclination. My wife and I are both licensed operators and she actually uses it more than I do.
  17. Oct 23, 2014 at 8:08 PM
    #2637
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good info, thanks. I just started thinking about getting my license.
  18. Oct 26, 2014 at 2:56 PM
    #2638
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  19. Oct 26, 2014 at 4:52 PM
    #2639
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  20. Oct 26, 2014 at 4:52 PM
    #2640
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Nice! I'm looking at signing up for one soon as well.
