Any fellow survivalists utilize their truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jez, Oct 31, 2011.
  1. Dec 7, 2015 at 10:56 AM
    #3221
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Guys, carrying O2 is a dumb idea in my opinion. First off it is considered "prescription only" as it is a "drug" in the eyes of the law. Also, what are you really planning to do with it in the field outside of your ambulance? It is indicated for fewer and fewer situations as protocols evolve in time. Not to mention it is dangerous to keep in your vehicle and can become one hell of a missile if it is damaged in the event of a crash.
  2. Dec 7, 2015 at 11:05 AM
    #3222
    G.T.
    G.T.
    CONUS
    Good thing I'm keeping it in the house then.
  3. Dec 7, 2015 at 1:47 PM
    #3223
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Sorry, but saying O2 cylinders are prescription only is a crock of shit. There is literally no difference between medical filled containers of O2 and welding O2. They both come from the same container of LOX. The only difference is the paperwork that goes along with it as all medical cylinders have to be traceable. Standard operating procedure for any O2 refill is to vacuum evacuate the container prior to refill to remove impurities.
    14489 and jdg like this.
  4. Dec 7, 2015 at 7:22 PM
    #3224
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Yes to everything but +100 for the go girl lady pee cup thing. Looks silly and I got one halfway as a joke for my ol lady. Twice now camping in open desert with people everywhere and no bush to hide behind and at a concert where the porta potties looked like murder scenes it's been worth it's weight in gold. Not a life or death item but it's the handy little things that make everything run smooth
    Guerrilla[QUOTED] likes this.
  5. Dec 7, 2015 at 9:40 PM
    #3225
    Liquix
    Liquix Well-Known Member
    Connecticut
    14 ACOR 4x4 v6
    How can I store water in my truck this water and keep it from freezing? I was thinking of adding a drop of Vodka per litre. Any other suggestions or ideas?[/QUOTE]
    Unfortunately I think doing that would create fractional freezing. In other words it'll still freeze on top and the unfrozen portion of liquid will have an increased concentration of alcohol. I think you've got to try to keep the water insulated. Keep it above freezing and have a way to warm it up, some good insulation and the heat capacity of water will go a long way. I don't know what substances one can safely put in water to keep it's freezing point low.
  6. Dec 8, 2015 at 6:26 AM
    #3226
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Unfortunately I think doing that would create fractional freezing. In other words it'll still freeze on top and the unfrozen portion of liquid will have an increased concentration of alcohol. I think you've got to try to keep the water insulated. Keep it above freezing and have a way to warm it up, some good insulation and the heat capacity of water will go a long way. I don't know what substances one can safely put in water to keep it's freezing point low.[/QUOTE]
    The Vodka thing works in high enough concentrations, but I don't want to be getting hammered in a bad situation. I just let it freeze. Normal plastic water bottles will freeze just fine. When I need water, I fire up the single burner stove, cut open a bottle, and melt some. Besides, Cocoa is better than water in sub zero temps.
  7. Dec 8, 2015 at 7:21 AM
    #3227
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    i keep one of those life straws in my truck
  8. Dec 8, 2015 at 9:25 AM
    #3228
    Spencer
    TIGGLEBITTIES
    Make sure you use the damn thing every now and then. I had an old one that sat unused for years as a "just in case" item. I decided to try it out one day, took a big sip and sucked up a mouthful of the most godawful tasting muck. whatever is inside of those things will crumble apart and make you throw up when it comes out.
    use it or lose it applies to all your gear, I've learned. keep everything cycled out and fresh.
  9. Dec 8, 2015 at 9:44 AM
    #3229
    Mariotaco
    Mariotaco Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    What's in the bag on the top right corner? lol
  10. Dec 8, 2015 at 9:57 AM
    #3230
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Blech.
    Had it been used before that? Or was it just sitting new in the package?
  11. Dec 8, 2015 at 10:35 AM
    #3231
    ejl923
    Eric
    Western Mass
    Interesting. The site says no shelf life. Now, nothing is forever, but i would expect a few years anyway
  12. Dec 8, 2015 at 1:29 PM
    #3232
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Better throw in another cylinder of acetylene for "welding" then I guess. Don't forget your torch as well. Not to mention if you plan on utilizing your "survival oxygen" on anyone other than yourself, you'd better have a good defense ready when the department of health asks wtf you were doing treating people with a drug.
  13. Dec 8, 2015 at 1:35 PM
    #3233
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Get off your high horse. I replace my tanks as they get empty and don't have coincide with any other tanks, smartass.
    In case you missed it, the goal of this thread is survivalist. If it helps me and my family, I could care less about your laws as a medic. Nobody here is preaching to use oxygen for some random Joe on the street.
    ChamYota likes this.
  14. Dec 8, 2015 at 1:38 PM
    #3234
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Go on then, badass. Save yourself from... whatever it is that you think a portable tank of oxygen and a nasal cannula is going to save you from.
  15. Dec 8, 2015 at 1:58 PM
    #3235
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    What's your issue anyway? Is it because you're a medic? I wasn't the one who started posting about portable oxygen, genius. Just adding insight on your legalities post about being in possession of oxygen.
  16. Dec 8, 2015 at 2:14 PM
    #3236
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Not all of us live in the flatlands. http://www.mlive.com/news/jackson/index.ssf/2015/10/we_built_so_much_here_albion_f.html
    That tank might last long enough to get you off the mountain and to an area with cell coverage. Most of the area where I work and play is out of network. There is nobody to call. Just me and my rudimentary med kit and lifesaving skills.
    14489, ChamYota and jberry813 like this.
  17. Dec 8, 2015 at 2:18 PM
    #3237
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I think that in a survival situation, if you gave somebody who needed oxygen some, you could rightfully tell the department of health to fuck off.
  18. Dec 8, 2015 at 3:09 PM
    #3238
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Fuck can't we all just get along?
    robssol and SixthSnail like this.
  19. Dec 8, 2015 at 5:18 PM
    #3239
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Oxygen is tearing this thread apart.
    TacomaMike37 and SixthSnail like this.
  20. Dec 8, 2015 at 5:24 PM
    #3240
    IPNPULZ
    going to be fun!
    I guess you starve for oxygen with "cranial rectosis"
    Adventurer_Alex likes this.
