Any first gens with king coilovers
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Jan 27, 2010.
  1. Jan 27, 2010 at 1:03 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey I wanna see if anybody has a 1st gen running kin coilovers.....I wanna get some on my 03 pretaco.....that's post pics if you can and specs on how hight u cranked it
  2. Oct 16, 2010 at 10:17 AM
    7tac0ma7
    7tac0ma7 Member
    Spencer
    humboldt
    99 Tacoma 6" lift/fiberglass fenders
    6" fabtech lift, king coilovers, 5125 rear bilsteins, 2.5" skyjacker softride leaf springs, 33x12.50 toyo mt's, 15x10 ion alloy powdercoat wheels, downey fiberglass front end, k&n air filter, flowmaster dual exhaust, factory e-locker
    I just put on my king coilovers and i love them!!
  3. Oct 16, 2010 at 7:18 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Me. I have them.
  4. Feb 27, 2011 at 6:44 PM
    t0mills
    t0mills Well-Known Member
    TRD, Gray Wire Mod, 3" Suspension lift, 3" Body Lift, 285/75 AT2s
    I realize this is an old thread, but it seems to be relevant to my question.
    Those that are running the King coilovers, are these the ones you're running?
    http://downsouthmotorsports.com/i-1...96-2004-toyota-tacoma-4wd-2wd-pre-runner.html
    Is there a set that have the remote resi like the 05+ models? If not, why exactly is that? I'm guessing the front suspension on the 05+ is quite a bit different?
    I've also noticed that King makes rear shocks for the 05+ tacomas, but not for my 02... Has anyone adapted these to the 1st gen trucks? Or are the regular bilstien shocks enough for everyone?
    Just trying to get all my info together. I was going to purchase the Camburg Coilovers and UCAs, but upon reading about them and SAW, it seems that they don't really compare to the King coilovers. If the Kings are really that much better, I'll go with them.
    Also, if King doesn't make a remote resi coilover for the 1st gen trucks, is there a company out there that does? Fox? Icon?
    Thanks in advance!
  5. Feb 27, 2011 at 7:42 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    AFAIK, the King's have an internal resevoir for the 1st gen, not remote.
    Fox makes a remote resi c/o both in standard and mid travel (aftermarket UCA required).
    http://www.polyperformance.com/shop...ng-Travel-Kits-for-Toyota-Trucks-p-18206.html
    I've got the Fox mid travel remote resi's on my truck.
    I think Icon might they also make a remote resi (stage III or something?), but I've never seen one.
    As for the rear, going along your theme of wanting remote resi's, the Bilstein 5150 have a piggyback resi if you want something a little nicer than the regular 5100's.
  6. Feb 28, 2011 at 4:57 AM
    t0mills
    Great info, thanks. How do you like your Fox mid travels? What UCAs are you running with them?
  7. Feb 28, 2011 at 9:37 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I have the Total Chaos UCAs. If you wanna save yourself 200 bucks, get the Camberg ones. Functionally equivalent, just a different color. I like that the TC's are similar in color as the Fox c/o's though.
    The fox mid's are great. The resevoir is huge though, probably twice the size of the resevoir my buddy has with his King's on his FJ. It was a little too close for compfort to my tires so I ended up having the lines extended. I mounted the resevoirs to welded brackets on the front crossmember (well protected behind the skidplate). Below are a couple glamour shots of what I'm talking about.
  8. Feb 28, 2011 at 11:04 AM
    t0mills
    Nice. Do you have a part number for those Fox coilovers? I may end up copying your setup... :D
    I bought the truck with a 3" Revtec spacer lift, and from what I've read, it leaves a lot to be desired in ride quality.
    Also, any trouble out of your Uniball UCAs? I'm guessing that the Uniball is a lot stronger than a Balljoint, but I've heard there is more maintenance involved. As long as said maintenance is just occasional cleaning/lubricating, then I'm fine with that.
    Reason I say this, is because there will be times where I'm on the road for a couple months straight (have an Alaska trip planned) and I would like to keep this thing as reliable as possible.
    Thanks for your help
  9. Feb 28, 2011 at 11:41 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Uniball's are great. Maintenence is a snap. Bushings have zirk fittings and the ball joint is easy to grease. Little bit of lube goes a long way (that's what she said). :D
    Fox Part #'s
    --Front Options
    FOX-880-02-410-A 96-04 Tacoma PreRunner Front Kit (Pair) 0"-3" 2.5" C/O Remote Res Black
    FOX-880-02-409-A 96-04 Tacoma PreRunner Mid Trave Front Kit (Pair) 0"-3" 2.5" C/O Remote Res Black
    --Rear Options
    FOX-980-02-550-A 96-04 Tacoma PreRunner Rear Left (Single) Stock 2.0" PiggyBack Black
    FOX-980-02-551-A 96-04 Tacoma PreRunner Rear Right (Single) Stock 2.0" PiggyBack Black
    Wheelers probably has the best prices on UCA and they are a pleasure to work with
    TC: Camburg:
    Again you only need the UCA if you go with the mid travel (but I would certainly recommend).
  10. Feb 28, 2011 at 12:03 PM
    Skillet
    Skillet Well-Known Member
    Caleb
    Palmdale,Ca
    99 tacoma prerunner 3.4 auto trans trd,
    Trd edition,black powdercoated wheels,king Coils front, king double bypass rear, k&n cai, jba headers,borla exhuast,optima batt,xenon hid,crystal headlights,rewired entire car to four guage wiring on big stuff alt starter etc.,alpine screen,focal honeycomb components,JL four channel amp,dynamated entire inside of truck and hoodliner,limo tint all rear windows,LEDs everywhere possible dome light, tails,fronts,04 tailights,
    I have king shocks front and rear, the rears are new models I am one of the first to own em the new rears I have are bypass shocks w/remote res, the fronts are just coilovers no extra res there. They're very smooth! Hey j berry were you able to put you're ucas on yoursself, cause my friend told me the upper ball joint on the spindles are press out only ,is that tru?+ some are supposed to be really hard to press out on some years cmpared to others I was told the spindles could take up to a 50 ton press to get off you're upper ball joints.... Is that tru that's all that's holding me back from my final setup?
  11. Feb 28, 2011 at 1:58 PM
    t0mills
    Very cool! I really appreciate the part numbers.
    I found this kit that basically includes all of the above, at a pretty good price:
    http://www.offroadwarehouse.com/products/sfID1/4/sfID2/78/sfID3/83/productID/50906
    Unless anyone knows of a better deal out there, it looks like I will be ordering that kit. I'm excited to see the difference it makes over the 3" spacer lift!
    Also, regarding Skillet's post, I'd like to know if that upper ball joint is a bear to press out. I can do the install of coilovers/UCAs by myself, but if that ball joint is a pain I'll just take it somewhere.
  12. Feb 28, 2011 at 2:29 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's not too difficult as you are not reusing the ball joints. My solution was a socket and a Ford tool (big fucking hammer). :cool:
    Check out this link:
    http://www.parksoffroad.com/tacomamods/upballjointout/balljoint.htm
  13. Feb 28, 2011 at 3:24 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    I am running Kings and made no adjustments to them got right about 2.5 inches of lift but like mentioned no external resi. Also They did just cone out with a rear 2.5 resi shock for the rear on our trucks. Talk to DSMS about it.
  14. Feb 28, 2011 at 5:31 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I have King remote resi's in the rear too. :D
  15. Feb 28, 2011 at 6:04 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Damn nice set up. Those are what they call the triple by pass correct? I would have no need for those since I don't think I would get long travel but I would like a nice set of resis out back for off roading.:)
  16. Feb 28, 2011 at 8:08 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Actually they are a 2.5x16" double bypass. Only one compression and one rebound tube. Tripple bypass have an additional compression tube. Custom from Giant Motorsports:
    http://giantmotorsports.com/index.php?option=com_content&task=view&id=66&Itemid=67
  17. Mar 1, 2011 at 1:37 AM
    Skillet
    Caleb
    Palmdale,Ca
    Wow Jberry that's how it's done ie, clean and really aggressive looking, back suspension is one of the cleaner made set ups i've seen, Im drooling over you're setup damn!
  18. Mar 1, 2011 at 9:35 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Thanks!
