Any full LCA replacement DIY threads?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Sep 22, 2015.
  1. Sep 22, 2015 at 9:20 PM
    iJDub
    iJDub [OP] Well-Known Member
    I've seen some for Ball Joint R&I but not the full LCA.
  2. Sep 22, 2015 at 9:58 PM
    iJDub
    Looking at the PDF...since the Moog LCA requires no assembly...as long as the bolts are seized it should be a super easy job?
  3. Sep 23, 2015 at 3:12 AM
    iJDub
    Yes, "aren't" lol
  4. Sep 23, 2015 at 5:03 AM
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
  5. Sep 23, 2015 at 5:10 AM
    Large
    Large Red
    I'm not sure what year truck you have but prepare for them to be seized. I have a 2012 and they were seized like a mofo.
  6. Sep 23, 2015 at 5:34 AM
    Pigpen
    Dan
    Northwest Montana
    Mine are seized and make a disturbing noise any time they flex. What are the chances they'll break? I'm far from home (and any town) a lot this time of year.
  7. Sep 24, 2015 at 8:18 PM
    iJDub
    Mine weren't seized. 2006. Original bolts.
