Any good solutions for rodent problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NWTacoTime, Feb 9, 2021.
  1. Feb 10, 2021 at 7:49 AM
    #61
    CrazyAirborne
    CrazyAirborne Who jumps out of perfectly good airplanes?
    Central Wisconsin
    2017 TRD Sport
    thats the first thing I tried, but mice can literally lick it off the bait plate and not set off the trap. research confirmed this. watched a bunch of videos on youtube as well. hot glue a pretzel on there and the trap can be reused for multiple mice.
    shakerhood and Doc62 like this.
  2. Feb 10, 2021 at 7:50 AM
    #62
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Hmmmm.....I've always had excellent results baiting with peanut butter. Just need to smear in on both sides of the trip pedal.
    VirusCage, TRD-ED and CrazyAirborne like this.
  3. Feb 10, 2021 at 8:04 AM
    #63
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    This is my situation as well. I've been wanting an outdoor cat for a while to deal with the moles, wife said no. A house up the street ended up being a cat factory in the last year or two. A bunch of outdoor cats. Well, now there are no more moles. I'll dump leftover scraps outside every once in a while and regularly see them coming through.
    Make sure you spay or neuter them, or those 5 will quickly turn into 20. Not sure why you'd need 5 in the first place.
    hiPSI[QUOTED] and TRD-ED like this.
  4. Feb 10, 2021 at 8:23 AM
    #64
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    So rodents cut cleanly all the way through the metal wires? Something doesn't add up here...
    TXpro4X4[QUOTED] likes this.
  5. Feb 10, 2021 at 8:28 AM
    #65
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    The more the better
  6. Feb 10, 2021 at 8:34 AM
    #66
    ret42
    VA
  7. Feb 10, 2021 at 8:37 AM
    #67
    Knute
    Easy answer.
    6 would be too many and 4 wouldn't be enough.
  8. Feb 10, 2021 at 8:41 AM
    #68
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    Moth balls for critters, diamataceous earth for crawlies.
  9. Feb 10, 2021 at 8:46 AM
    #69
    Pep
    Pep Active Member
    Howard
    Choot Em, Choot em.
  10. Feb 10, 2021 at 9:11 AM
    #70
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Be careful, we dont need another "I shot my truck" thread.
    NWTacoTime[OP] likes this.
  11. Feb 10, 2021 at 9:12 AM
    #71
    Knute
    Shotgun loaded with rock salt could likely dispatch a mouse.
  12. Feb 10, 2021 at 9:38 AM
    #72
    Knute
    I live in a very small town located in the middle of a corn field. Every fall during Harvest, the rodents escape the fields for warmer more hospitable living quarters.
    So, to stem the migration into our home. I use several approaches.
    1. Remove all food. Not only human food, but food like seeds, grass seeds, garden seeds....... also get the garbage sealed/closed up. Never store garbage any longer than the garbage pick up cycle.
    2. Inspect the house for any openings 1/4" or bigger. Plug these with steel wool, then gap filler. These "gaps" are generally under the bottom edge of siding where it meets the foundation.
    3. Trim any foundation plants around the house. Use cedar mulch.
    4. Set snap traps in garage, basement, kitchen, laundry rooms. Bait with peanut butter, check frequently. Always clean the trap after a kill with hot water, when setting wear rubber gloves, don't spread your scent on the trap. You ask "Laundry Room?", they like the lint for nesting.
    5. Our Terrier dog. He likes hunting mice. Really skilled. If he smells or hears one, the hunt is on. If you want to see skilled mousers, get onto YouTube search for "terriers hunting". Very entertaining. Nature at its best.
    Typically, I'll get 1 or 2 each year. The dog will get 1 or 2. We keep a score. This year he leads me by one kill.
    After winter sets in, the problem is very rare. The migration has ended and the survivors have found other homes.
  13. Feb 10, 2021 at 9:40 AM
    #73
    NWTacoTime
    NWTacoTime [OP] Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    i setup snap traps last night (3 total). This morning i checked and two are untouched but one is completely gone. Disappeared no where to be seen..... No i'm curious what got caught? Maybe there is a coon somewhere out there with a snap trap stuck on it
    Appreciate the advice everyone, some far i'm 2 nights in and 0 kills..... gunna keep trying
  14. Feb 10, 2021 at 9:46 AM
    #74
    Knute
    Have you seen mouse signs? Droppings, shredded lint, chewed box or bags.
    Where are you placing the traps?
    How are the traps positioned?
  15. Feb 10, 2021 at 9:54 AM
    #75
    NWTacoTime
    Nate
    WA - Seattle/Kent
    Car Seats
    TBH none of those things. I've been parking like this for 2 years and this really only has become a problem in the past few months. I wouldn't have ever known other than the wires getting chewed, but i also have found rat droppings in the engine bay as well recently.
    So i park my truck by my fence. On the otherside of my fence is a neighbor in another neighborhood. That is where i'm assuming the rats are coming from or in that area. I placed the snap traps along the fence assuming they'd run along the sides.
    I dont keep any food out and we live in a new development neighborhood. They are building a new development behind my house which previously was just a field so i'm wondering if that work is causing them to seek out new homes......
  16. Feb 10, 2021 at 10:06 AM
    #76
    Knute
    Yeah, the construction is likely sending them looking for new homes.
    So, this is primarily outside.
    Your situation, suggest to park away from the fence. Pick a spot where the critter needs to cross open ground. They like to scurry along structures, they avoid open ground.
    Set some rat traps along the fence. Possibly some D-con, but be careful of kids and pets. If you use a poison bait, place it in a container that only the rat can access and anchor it.
    I'd try predator urine on the truck and in the engine bay. Do you have coyotes in the area? If so, use that scent.
    Take precautions to deter entrance into your home.
  17. Feb 10, 2021 at 10:08 AM
    #77
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    Send a few cats to the OP to help him out.
    NWTacoTime[OP] and shakerhood like this.
  18. Feb 10, 2021 at 10:10 AM
    #78
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My cat goes after anything in the yard, mice, moles, rabbits, snakes, lizards, frogs, crickets, grasshoppers, butterflies, birds, and l am sure l am forgetting many other things that she brings to show me.
    cropduster78, The hammer and Kremtok like this.
  19. Feb 10, 2021 at 10:10 AM
    #79
    NWTacoTime
    Nate
    WA - Seattle/Kent
    Car Seats
    Yeah exactly, right now its only relegated to outside but need to take precautions from it moving inside. My hope right now is to get my truck to fit in the garage when i get it repaired at least until summer time. I've thought about moving where i park it, perhaps in the culdesac in an open space if i ever do park outside.
    I've ordered some ultrasonic/LED under hood rat prevention things
    Going to clean my engine bay and then spray it down with rat repellant
    Continue to set snap traps outside and probably spray down the area with rat repellant too
    Worst case i'll call in the professionals but hoping these things will solve this fo rnow
  20. Feb 10, 2021 at 10:14 AM
    #80
    shakerhood
    Southern Ohio
