Any harm with removing my front diff and driving around?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slodc4, Jul 15, 2020.
  1. Jul 15, 2020 at 11:07 AM
    slodc4
    slodc4 [OP] Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    Is there any harm in removing the front driveshaft/diff/axles and drive the truck around?
  2. Jul 15, 2020 at 12:24 PM
    Muddinfun
    Muddinfun Well-Known Member
    Yes. Without the outer CV stubs, the wheel bearings can fall apart.
  3. Jul 15, 2020 at 12:26 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Exactly.
    Muddinfun[QUOTED] likes this.
  4. Jul 15, 2020 at 12:28 PM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    I didn’t think about that. Anyway around it?
  5. Jul 15, 2020 at 12:31 PM
    Muddinfun
    Buy a pair of halfshafts, dissect off the CV stubs, put them in the hubs and tighten the nut.
    TnShooter and slodc4[OP] like this.
  6. Jul 15, 2020 at 12:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't start until you can finish.
    Have someone else do it.
    Have something else on hand to drive, put the garage stuff in the bed to access.
    Always options.
    QuicksandTaco likes this.
  7. Jul 15, 2020 at 12:33 PM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    Thanks a lot man. I have some junk cvs laying around. Do they come apart or do I have to cut the cvs?
  8. Jul 15, 2020 at 12:34 PM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    I have a 3rd gen Tacoma and a 20 Camry...I’m not worried about something else to drive
    Also I’d rather work on it myself
    SR-71A likes this.
  9. Jul 15, 2020 at 12:37 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    The birfield side isn't meant to be disassembled, so in order to make stubs/blanks you have to cut some things up to make it happen. Other than there there isnt any downside, I've been having a lot of issues on my front drive train and have done exactly what you're talking about several times now.
    slodc4[QUOTED][OP] likes this.
  10. Jul 15, 2020 at 12:39 PM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    Thanks for the info! Where did you cut yours?
  11. Jul 15, 2020 at 12:39 PM
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    Remove the driveshaft from the transfer case and use a CV stub shaft in the hubs to hold them together and you will be ok.
    slodc4[OP] likes this.
  12. Jul 15, 2020 at 12:42 PM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    Perfect. Thanks man
  13. Jul 15, 2020 at 12:43 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Can confirm, I cross threaded an axle nut once and that alone caused my wheel bearing to fail ~300 miles later.
  14. Jul 15, 2020 at 12:44 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  15. Jul 15, 2020 at 12:49 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I has solution. Buy cheap wheel bearings and outer seal. Send em to me. I press in 2wd hubs. I send complete assemblies to you. You remove front diff, and all associated stuff. Install 2wd wheel bearings, and good.
    Taco-Obsessed and MattCowsmasher like this.
  16. Jul 15, 2020 at 12:50 PM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    That would work but I have a set of cv’s laying around that I can just chop and install into my hubs
  17. Jul 15, 2020 at 12:55 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Let me know if you change your mind. I can also send you 2wd hubs with bolts for you to press yourself.
  18. Jul 15, 2020 at 12:58 PM
    tetten
    Andy
    Socal
    I cut mine too short so it doesn't get a perfect seal around the birfield stub, if you do go that route make sure you don't make the same mistake.
  19. Jul 15, 2020 at 12:59 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    What di you cut with?
  20. Jul 15, 2020 at 1:00 PM
    tetten
    Andy
    Socal
    6" grinder with cut off wheels
    Texoma[QUOTED], SR-71A and slodc4[OP] like this.
