Any has the ALIGMENT number for a 4drs Taco
Discussion in 'Wheels & Tires' started by rmacher, Jul 26, 2011.
  1. Jul 26, 2011 at 5:41 AM
    rmacher
    rmacher [OP] Well-Known Member
    2010 TRD SR5 / SB
    4 Kergen HID / Spidertrax spacers / Argentinian leather / FAb light bar / Raamaudio /DMM HID's 6000k/ Jl Audio amp /etc //
    Hello, i am looking for the specs on the Aligment.
  2. Jul 26, 2011 at 5:42 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Ideal specs...0 camber, 0 toe, and Caster should be >1.8 depending on tire size.
    I had mine aligned at toyota after my lift (stock UCA's) and the tech got mine to +.8 Camber, +.05 Toe, and 1.9 Caster He said that was all within spec. I think camber "range" goes up to +1.2
  3. Jul 26, 2011 at 5:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you lift, you want 0* (or very slightly +) Toe, 0* Camber, and 2.1* or more Caster.
  4. Jul 26, 2011 at 5:52 AM
    rmacher
    2010 TRD SR5 / SB
    this one is stock with 1.25" specer's only.
  5. Jul 26, 2011 at 5:53 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Wheel spacers, top plate spacers, or coil spacers?
  6. Jul 26, 2011 at 6:08 AM
    rmacher
    2010 TRD SR5 / SB
    Spider / wheel spacer // anything else stock / stock tires 265/70/16 /
  7. Jul 26, 2011 at 11:00 PM
    rmacher
    2010 TRD SR5 / SB
