Any help on a retrofit in progress? No passenger high beam
Discussion in 'Lighting' started by FishingInSand, Sep 1, 2017.
  1. Sep 1, 2017 at 11:43 PM
    FishingInSand
    FishingInSand [OP] Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    So I ordered the d2s 4.0 from TRS, everything was going good, went to the step where you test mount and make alignment adjustments, low beams work perfect, hit high beams... Only driver side activates.
    Tried toggling it multiple times testing if it's getting stuck but it's just as smooth as the other one that is working.
    I double checked all my connections and reread the instructions several times ( not sure it would work of I didn't).
    Any kind of help would be so awesome as I was hoping to get this project done and quick so I could enjoy the rest of my weekend. Thanks
  2. Sep 5, 2017 at 9:42 PM
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    Mine actually didn't work at first either, But once I grounded both sides of the harness they worked. idk hopfully you get it figured out :thumbsup:
