Any Help would be greatly appreciated!!! MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by THROUGHITALLDUDE, Mar 7, 2011.
  1. Mar 7, 2011 at 4:02 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE [OP] Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    Hey guys so my bro and I both have 2005 access cabs. He never does any work to his truck at all I do it all for him, and all the suddent he wants/NEEDS a CAI for better MPG so he was looking around for some and I told him that he should either go with AFE or TRD. But they to me dont do a whole lot for MPG like only a slight difference will occur. He was going to do a exhaust with it for maximum performance since he has seen the difference in my truck (flowmaster) compared to his. Well what I wanted to know is can a set up like this do the same thing as a FULL CAI and achieve the same benefits and performance.
    this is motomans CAI set up and I wanted to see what the pros and cons were of it if anyone knew?
  2. Mar 7, 2011 at 6:29 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    anyone, someone???
  3. Mar 7, 2011 at 6:36 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    I just installed a AFE, CIA. I have not yet noticed good or bad on the MPG, it seems to have stayed about the same. hope this helps a bit.... and I'm running stock exhaust still.
  4. Mar 7, 2011 at 6:49 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    well what I am trying to figure out is does all the piping which the air filter connects too matter or can the filter be bolted to the stock set up like the picture above
  5. Mar 7, 2011 at 6:53 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Tell him to save the money for gas. Even if a cai got you 2 mpg better it would take a very very long time to recoup the 200-300 bucks they cost
  6. Mar 7, 2011 at 7:27 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    On the AFE you get a new filter box that sits on the right side fender and new pipe to the TB. You scrap the entire stock intake system.
  7. Mar 7, 2011 at 7:34 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    Ive tried explaining that to him and he seems to have someone feeding him the idea that a combo of CAI and Cat back exhaust will make a world of a difference in MPG
  8. Mar 7, 2011 at 7:37 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    CAI nor exhaust is going to gave any real gains in MPG's or power. More often then not it gets worse. Nice easy acceleration to posted speed limit and keep the RPM's under 2000 is your best bet. These trucks with the 4.0 are not easy on gas.
  9. Mar 7, 2011 at 7:37 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  10. Mar 7, 2011 at 8:16 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
  11. Mar 8, 2011 at 10:38 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    You can check out my fuelly notes before and after I installed an AFE Stage 2 (WAI). MPG went to crap at first because I kept hot rodding. My biggest MPG gain is cruising around town under 2k RPMS, never exceeding 3k RPMS when accelerating onto the freeway up to the speed limit, and keeping the RPMS at or under 2k, or my speed no faster than 70mph (slightly above 2k rpms).
    If a light ahead of me turns red, I take my foot off the gas until I have to stop or the light turns green. Stay in the slow lane and try not to piss other people off :)
  12. Mar 9, 2011 at 2:40 PM
    johnw
    john
    orlando florida
    according to the guys on xru underground (x-runner forum) they saw 2 mpg increase and also more power in the low end and top end rpm ranges
  13. Mar 9, 2011 at 2:48 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    thanks for all the info guys we went with a catback exhaust system and drop in K&N. So far it seems to be doing well we also did a ton of preventative maintenance on the truck as well which also helped a ton.
  14. Mar 9, 2011 at 2:48 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    Were looking at for both of our trucks doing throttle body spacers and maybe even JBA or Doug Headers so well see...
  15. Mar 9, 2011 at 4:00 PM
    johnw
    john
    orlando florida
    throttle body spacers dont work
  16. Mar 9, 2011 at 5:46 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Yes, really, throttle body spacers don't work. Whoever posted that was, hopefully, just being sarcastic. If you friend wants to spend his money on both the AI and the catback, let him. I did it too and I like the sound of it, and maybe, MAYBE the added gains in high RPM.
    I didn't buy them for more MPG.
    He'll learn. Just don't let him blame you for it afterwards since he's pushing the issue.
