Any Home HVAC guys out there?
Discussion in 'Off-Topic Discussion' started by TnShooter, Nov 18, 2020.
  1. Nov 20, 2020 at 11:59 AM
    #41
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The Aux light was flash when it did this the other day. But, even if you turn the system Off on the Thermostat it continues to run. Only way to kill the system is by the breaker near the Heat pump or in this the main panel of the house.
  2. Nov 20, 2020 at 12:02 PM
    #42
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Pretty much that. You have high voltage and low voltage. Low voltage is the hardest to diagnose because it’s intermittent most of the time. But as long as you can read a wiring diagram and know how to use a meter you are good to go.
    TnShooter[QUOTED][OP] likes this.
  3. Nov 20, 2020 at 12:05 PM
    #43
    Panchovilla6192002
    Arizona
    If you are having to do this, then yes, it’s going to be a contactor.
  4. Nov 20, 2020 at 6:09 PM
    #44
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    A contactor is the same thing as a relay just bigger and looks a little different. Outside of automotive they normally have a lower voltage control wiring.
  5. Nov 24, 2020 at 12:32 PM
    #45
    Panchovilla6192002
    Arizona
    Any updates OP?
  6. Nov 24, 2020 at 12:42 PM
    #46
    TnShooter
    Deogee
    STOCK
    Yes, we put in a new “connector”.
    To me it looked like an over sized relay.
    It was located on the Heat Pump itself.
    The old one was black and stuck at the time we removed it.
    So far, so good.
    I couldn’t tell you the exact name of the part.
    A friend of the family came over and fixed.
    I helped, by standing there a watching. Lol
    I didn’t mess with high voltage electric, I don’t know anything about it.
  7. Nov 24, 2020 at 12:46 PM
    #47
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    Sure thing.
    Describe "will not shut off sometimes" a little better.
    Does the house keep getting warmer and warmer?
    Or is the space temperature still below the thermostat setting when it "will not shut off"?
    What kind of thermostat? Post a picture of the model number of the thermostat.
    PHM
  8. Nov 24, 2020 at 12:49 PM
    #48
    TnShooter
    Deogee
    STOCK
    Maybe this will explain it better.
  9. Nov 24, 2020 at 12:49 PM
    #49
    Poodle Head Mikey
    A heat pump most commonly powers the yellow and orange for cooling. For heating it just powers the yellow. The O powers the reversing valve to make it cool. The design logic is "fail-safe to heat". ALTHOUGH . . . . some brands do it the opposite way - O powered for heat.
    With the make and model number of the outdoor unit we can find out pretty quick.
    PHM
  10. Nov 24, 2020 at 12:50 PM
    #50
    TnShooter
    Deogee
    STOCK
    As of now. We have it fixed.
    Or at least it’s operating as Normal.
    Hopefully it stays working.
    Thanks for the help.
  11. Nov 24, 2020 at 1:11 PM
    #51
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Is the heat pump defrosting at all? Also, when you were using it in COOL mode over the summer, did it seem to be performing okay?
  12. Nov 24, 2020 at 1:16 PM
    #52
    TnShooter
    Deogee
    STOCK
    Yea to both question.
    However, we didn’t use AC all that much.
    And we have had this problem before, just not last summer.
    By the looks of the old “contractor” it was likely the problem.
    It was stuck. I smacked it on the ground a few times and it popped free.
    It’s in the trash now. A new one has be installed.
  13. Nov 24, 2020 at 1:18 PM
    #53
    PennSilverTaco
    Charlie
    I’m not an HVAC tech, but I know quite a bit about the topic and I’ve given out advice to other members. So you’re saying that the heat pump just runs constantly? Does it get the house to the desired temperature?
    I have a slight feeling you might be low on Freon.
  14. Nov 24, 2020 at 1:19 PM
    #54
    TnShooter
    Deogee
    STOCK
    Yes, like 89 degrees. And kept getting warmer
    It would NOT turn off.
  15. Nov 24, 2020 at 1:22 PM
    #55
    PennSilverTaco
    Charlie
    So it keeps running even after it reaches the set temperature on thermostat?!?!
  16. Nov 24, 2020 at 1:27 PM
    #56
    TnShooter
    Deogee
    STOCK
    Yes, it did.
  17. Nov 24, 2020 at 1:27 PM
    #57
    PennSilverTaco
    Charlie
    @TnShooter
    Also, what brand is it? Carrier? Trane? Lennox?
    The average service life for a residential air-source heat pump is about ten years, though most of the ones I’ve seen tend to last considerably longer than that; Oldest operational heat pump I’ve ever seen was a 1970s Carrier “spam can” and that was maybe three years ago.
    The newest heat pump I’ve ever seen get replaced due to some sort of mechanical failure was an 11-year old Trane XE1000 (manufactured in late 1998, installed in the summer of 1999, failed in spring 2010).
  18. Nov 24, 2020 at 1:28 PM
    #58
    PennSilverTaco
    Charlie
    Sounds like the problem might be with the thermostat, or thermostat wiring. Is the thermostat from 1997 as well?
  19. Nov 24, 2020 at 1:33 PM
    #59
    TnShooter
    Deogee
    STOCK
    It was, until I changed it.
    And the same thing happened.
    The thing we replaced looked like this.
    Best I can describe it as is a big relay for 240v
    It was getting stuck ON, and the heat pump would stay On.
  20. Nov 24, 2020 at 1:34 PM
    #60
    PennSilverTaco
    Charlie
    Stuck in heat mode too? Also, what brand?!?!
