Any "how to's" on changing the radiator fluid?
Discussion in 'Technical Chat' started by hate2work, Oct 22, 2008.
  1. Oct 22, 2008 at 3:53 PM
    hate2work
    hate2work [OP] Well-Known Member
    Washington State
    06 standard cab
    My truck is now 2 years old, and I'd like to put in some new Toyota Red coolant/antifreeze.
    Can someone give me a quick tutorial about doing that? I don't think it needs to be flushed, just drained and refilled with the same amount.
    TIA~
  2. Oct 22, 2008 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    2 Years isnt that long for the coolant, Bu, On the bottom of the radiator you will see a drain valve. Take the cap off the radiator, and drain the coolant thru the drain valve. After it slows, close the valve, top off the coolant, then start the engine and let it run for a while with the cap off. Add coolant as you see the level drop. :)
  3. Oct 22, 2008 at 6:03 PM
    hate2work
    Washington State
    06 standard cab
    Yeah, I know I'm being a little anal about it, but I'm doing most of the other fluids so I might as well do that as well, right?
    Thanks Chris :D
  4. Oct 30, 2008 at 9:53 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    By the way, I'd use the Toyota Pink Coolant, the Red is the old formula for the older model vehicles. I honestly don't know if there is a difference other than color, but they recommended to replace with the same style that was factory-filled.
  5. Oct 11, 2009 at 10:01 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    :confused:Just wondering, I'd like to do a drain & refill for my radiator soon. Anyone know how much that fluid costs at Toyota? Thanks.
  6. Oct 13, 2009 at 1:40 PM
    monoman
    Dave
    Hmmm, not too bad cost wise. Thanks.;)
    So, I was just going to drain & refill, but it it nesessary to flush it out every time? I've never flushed this thing out & I have 74,000 miles on it. Should I do it?:confused:
    EDIT.....Also I've looked inside & it's clean as a whistle!
  7. Oct 13, 2009 at 5:19 PM
    jpg366
    jpg366 Well-Known Member
    TX
    09 Prerunner SR5
    Be sure to find a good place (business) to dispose of the old coolant. Quite toxic to animals and very bad (and illegal) to either put down the drain or into a storm sewer. I think Wal Mart will take stuff like that. No charge last time I took some there.
  8. Oct 14, 2009 at 2:34 PM
    monoman
    Dave
    Good info. I didn't know WalMart took that stuff. I kinda figued most auto supplies took used oil & other fluids too. Thanks guys! :D
  9. Oct 14, 2009 at 2:37 PM
    monoman
    Dave
    OK. Will do. And why shouldn't you use a hose to flush out the radiator? I've done that in the past with other cars & have had no problems.
  10. Oct 14, 2009 at 2:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, I belive the 1GR-FE requires a special type of coolant. Being as its an all aluminum block. Im looking into this.....
  11. Oct 14, 2009 at 2:42 PM
    monoman
    Dave
    I have the 3.4 engine.
  12. Oct 14, 2009 at 2:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....Any should be fine then.
  13. Oct 14, 2009 at 2:45 PM
    monoman
    Dave
    But it would be better to get it at Toyota, right?
  14. Oct 14, 2009 at 2:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would see whats out there. I think Toyota uses the RED long life stuff....Thats the same as the GM stuff, so whichever is cheaper.
  15. Oct 14, 2009 at 2:53 PM
    monoman
    Dave
    Yea, that's what's in there now, so I think I'll go with that. Thanks Chris!:D
  16. Oct 21, 2011 at 11:31 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    If I remember I will take pics of the steps I did
  17. Oct 21, 2011 at 11:55 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    Be careful of the coolant you buy.
    Not long ago I did this to my Jeep which also uses the Toyota/GM Red type coolant and the bottle did not specify very well whether it needed to be diluted or not. Noticed this in all the Red type coolants that AdvanceAuto had. After looking all over the bottle, I found in the farther corner that it did need to be diluted.
    Just a heads up anyhow... I would stick with the Toyota one anyhow. Price should not be much more and you know you are doing it right.
  18. Oct 22, 2011 at 7:02 AM
    saugus
    saugus Well-Known Member
    Just did a full flush if anyone cares. The book says 9.2 quarts. The truck only took about 7.5 quarts including the reserve bottle. This was after draining everything from the radiator, engine and thermostat. So my mix is obviously not 50/50 with the pink stuff added. Probably ~41/59. That's why I hate this 50/50 shit. I'm thinking the heater core was the problem but I did run the heater at max when flushing.
  19. Oct 22, 2011 at 7:23 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    Red is concentrated an pink is premixed. Do not use tap water to flush/dilute. Only distilled water should be use. On the driver side bottom there is a drain that you can hook a small hose to. Empty reservoir first.
