any HVAC guys out there? got an issue...
Discussion in 'Off-Topic Discussion' started by timmaayyy, Aug 12, 2010.
  1. Aug 12, 2010 at 7:45 PM
    timmaayyy
    timmaayyy [OP] Well-Known Member
    Tim
    Raleigh, NC
    '16 TRD Sport DC
    so i was trimming around my AC unit and i got a little too close to a wire and it got caught up in the trimmer head. the wire is a brown jacket wire with several smaller colored wires inside, i think it is the wire that goes back to the thermostat in the house.
    i thought i saw a couple of sparks and below is how it looks now. seems to be working fine but the yellow wire looks cut, not sure if it was already like that or not. any thoughts?
  2. Aug 13, 2010 at 5:22 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Call an hvac guy and have it serviced.
  3. Aug 13, 2010 at 5:24 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    shut the breakers off for the inside and outside unit then just recut and splice the wire together. its only 24volts
  4. Aug 13, 2010 at 5:33 AM
    Oldewing
    Oldewing Guest
    +1 on shut down and splice.
    Yes it is the theromstat circurt. Yellow maybe a heater control, so you would not see a problem with AC. There is a circurt that runs between the two so you don't run both at the same time.
  5. Aug 13, 2010 at 5:35 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...and take some ties and secure it to the other lines so its not as vulnerable to damage in the future.
  6. Aug 13, 2010 at 5:46 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    It looks like he pulled the wires out of the box. Opening up the box and putting the wires back on is easy, if flu know where they go.
    Just make sure you pull the disconnect before you open it up.
    I still say to call for service.
  7. Aug 13, 2010 at 6:19 AM
    tnj
    tnj Well-Known Member
    tom and jane
    CO
    2007 tacoma 4x4 off road 6speed
    13"antennax,black painted grill,hammered black paint on rims,debadged,3" toytec lift,aal,884 coils with top plate,diff. drop,custom grill,6 speed trans, painted engine cover
    yes it is the thermostat wire,splice it like diddy said and u will be alright
  8. Aug 13, 2010 at 10:26 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    :thumbsup:
  9. Aug 13, 2010 at 10:51 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    As paintdiddy said, cut and resplice, probably also wanna heat shrink it to seal it from corrosion.
    Get some round up, kill the grass, then put down some mulch/pinestraw/ground cover/ etc. around the AC unit then you won't have that problem in the future. Less Trimming to do. I don't have any grass touching my house, makes trimming a lot easier.
  10. Aug 13, 2010 at 11:49 AM
    timmaayyy
    Tim
    Raleigh, NC
    '16 TRD Sport DC
    good call on the mulch, i think i still have a bag.
    thanks for the tips guys, i'm gonna flip the breaker and go to work on it tonight.
