Any idea what this is for?!??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mouse, May 21, 2008.
  1. May 21, 2008 at 4:57 PM
    Mouse
    Mouse [OP] Active Member
    Charlotte - NC
    08 PreRunner SR5 w/ Sports Package
    Indigo Ink Pearl Exterior Graphite Cloth Interior, TrueFlow XDi CAI, Redline Tunning Hood Struts, Bluetooth Handfree Phone System, Tinted Windows. Chrome: Bull Bar, Billet Grill, Tail Light Guards, Tailgate and Door Trim, AC Vents.
    I have installed hood struts on my 08 and this thing is in the way. I think I might have bent it a little when I closed the hood for the first time.
    Anyway...does anyone know what this does of it for? It is on the driver side screwed onto the fender screw. The hood closes on top of it pressing the button down. The wire go from the button into the dash board somewhere behind the firewall. I have turned on the truck and pressed the button and see any warning lights on the dash going on or off.
    Also...I am looking at moving it closer to the hood hinges so I can still get these hood struts working...can I do that with this part?
    Thnx
    Mouse
  2. May 21, 2008 at 5:02 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    it looks like a hood switch for an alarm system
  3. May 21, 2008 at 5:04 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    you are correct. it is a hood switch for the alarm.
  4. May 21, 2008 at 5:22 PM
    Mouse
    Charlotte - NC
    How does it work?
  5. May 21, 2008 at 5:24 PM
    The_Hodge
    SC
    if the hood pops up while the alarm is set, it'll go off, i do believe
  6. May 21, 2008 at 5:25 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    When your hood is popped/open, it triggers the alarm.
  7. May 22, 2008 at 4:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Had one on my 02 except it was mojnted in the center of the hood on the fire wall.
  8. May 22, 2008 at 11:23 AM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    I had the same problem with mine. I removed it and lengthened the wire a bit, then installed it closer to the front of the truck. I put a few washers between the outer and inner fender surface to support it after I drilled a new hole.
  9. May 22, 2008 at 11:52 AM
    Mouse
    Charlotte - NC
    I think I bent mine...is your straight?
    I tried to test it to make sure I didnt break it by pressing the button down...turning on the alarm...then releasing the button, but that didnt seem to do anything.
    Does anyone know of another why I could test this to see if I broke it or not?
