Any idea what this noise is? Video attached
Discussion in 'Performance and Tuning' started by Santa Cruzin, Mar 23, 2018.
  1. Mar 23, 2018 at 10:46 PM
    Santa Cruzin
    Santa Cruzin [OP] Well-Known Member
    NorCal
    05 Tacoma Prerunner SR5 4.0 DCSB
    https://youtu.be/ORsXluELS7U
    It sounds way louder than it is cause I put my phone right up to the bottom of the engine. It's actually pretty quiet and only happens when I first start the engine cold and makes the noise for about two minutes till it' warm
  2. Mar 25, 2018 at 9:18 PM
    Santa Cruzin
    NorCal
    Any ideas ?
  3. Mar 25, 2018 at 9:22 PM
    Bishop84
    Bishop84 Well-Known Member
    Too vague, doesn't sound like the typical idler issue that 2nd gens have, I would suggest buying a cheap stethoscope from a tool store and isolating the noise.
    My first instinct is it sounds like a throw-out bearing but it may not even be a manual.
    vasinvictor and Santa Cruzin[OP] like this.
  4. Mar 25, 2018 at 9:31 PM
    Santa Cruzin
    NorCal
    Yea it’s an auto , sounds like it’s coming from the Serp belt area or something in the front of the engine
  5. Mar 26, 2018 at 10:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Take another video with the hood open.
  6. Mar 26, 2018 at 10:32 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Does it get worse when the A/C is on?
  7. May 5, 2018 at 3:40 PM
    Rogersme
    Rogersme Member
    2015 white Tacoma TRD
    Mine makes the exact same noise, till it warms up also. The dealer said I would need to leave it overnight so they could start it on a cool morning. Havent wanted to go through the hassle yet
