Any idea when someone should replace the thermostat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexfiggy, May 13, 2022.
  1. May 13, 2022 at 6:26 PM
    Alexfiggy
    Alexfiggy [OP] Well-Known Member
    Alex
    Miami
    Trd off road
    Any idea when? I have changed the radiator fluid about 2 times in 10 years . 137000 miles
  2. May 13, 2022 at 6:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyotas rarely have thermostat failures.
    They typically failed in the old days because the coolant became corrosive sooner and would eat everything.
    A sign you need a thermostat is it doesn't reach operating temperature, or constant overheating.
    It's not a maintenance item, you repair them as needed. Because you're on top of the coolant flushes, you'll be fine.
    The new 2016 + models are failing due to the electronics in the thermostat, so be glad you don't have that concern.
  3. May 13, 2022 at 7:24 PM
    Alexfiggy
    Alex
    Miami
    Trd off road
    Thanks for the info . What about the hoses ?
  4. May 13, 2022 at 7:54 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Those will last you quite a while. Joust look for cracking and dry rot every now and then
  5. May 13, 2022 at 8:15 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    There is no set life span on radiator hoses. In general the automotive industry suggests replacing about every 60,000 miles or every 5 to 6 years. The responses to your question are going to be all over the map. I replaced mine at 90,000 miles. So I’d say replace between 60,000 and 100,000 miles or 6 to 10 years.
    In any event you don’t want to wait until they fail. They are cheap so just look at it as being normal maintenance and replace them sooner than later.
    You’re going to have guys saying they have a zillion miles on them and they are fine. But it makes no sense to wait until they fail because again they are cheap. So somewhere between 50,000 and 100,000 miles , what ever you feel comfortable with just replace them.
    If you have 137,000 miles on the hoses just change the damn things.
    michael roberts and wi_taco like this.
  6. May 13, 2022 at 8:16 PM
    saint277
    saint277 Vigilo Confido
    The ecu will throw a code if it starts failing, thats when you need to change it.
  7. May 13, 2022 at 8:21 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I replaced my belt, PCV, hoses and thermostat when I did my first coolant flush, at 100K. They looked in very good condition. I now recommend to do them at the second flush, at 150K, unless there is observable damage. Im not going to wait for them to fail.
    Crom, wi_taco and Sprig like this.
  8. May 13, 2022 at 9:11 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The usually fail full cooling so it’s not a big deal. I view it as a run to maintenance item and not replace on a predetermined interval.
    Crom likes this.
