Any idea which pulley/bearing is going out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Choco Tacko, Dec 17, 2021.
  1. Dec 17, 2021 at 1:47 PM
    Choco Tacko
    Choco Tacko [OP] Member
    Hey guys! Just looking to see if anyone can point me in the direction to diagnose where this noise is coming from. It’s getting progressively worse over time and I’m going to fix it before it gets worse just trying to identify which pulley or bearing I need to replace. Trying to upload the video now.
  2. Dec 17, 2021 at 2:00 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you think its coming from one of the idler’s under the serpentine belt, pull the belt and rotate the idler(s) by hand. A bad idler will feel rough (different).
    Blockhead, 6 gearT444E and Dm93 like this.
  3. Dec 17, 2021 at 2:24 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Rockauto sells kits to replace all of the pulley's.
  4. Dec 17, 2021 at 2:32 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have a long screwdriver I use just for that, put the tip near where you think the noise is coming from the handle to your ear. Try another spot until you hear the noise it will be obvious. Tip from an old fart mechanic.
    Dm93 likes this.
  5. Dec 18, 2021 at 12:23 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Don't know what year and mileage but usually if one is going others are not far behind so if you are keeping it do them all and be done. Check the tensioner pulley too.
    6 gearT444E and vtown like this.
  6. Dec 18, 2021 at 6:41 AM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    100%
    Just replace them all. They aren't that expensive, even from the dealer.
    Knute and 6 gearT444E like this.
  7. Dec 23, 2021 at 1:03 AM
    Choco Tacko
    2015, about 56,000 miles. Idk why it will not let me upload the video from my phone
  8. Dec 23, 2021 at 3:07 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I probably don’t have to tell you this but be sure to replace the belt with a new OEM belt.
  9. Dec 23, 2021 at 7:49 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Like others have said, if it's one, others will follow. Purchase a kit and replace them all.
