Any ideas for removing xm radio antenna?
Discussion in 'Audio & Video' started by Tortoise, Jan 30, 2012.
  1. Jan 30, 2012 at 10:44 AM
    Tortoise
    Tortoise [OP] Member
    Ron
    Utah
    12 TRD Sport
    My brand-new 2012 Tacoma has a "shark fin" xm radio antenna at the back of the access cab roof, and interferes with installing a camper. I don't care to keep the xm radio, but am looking for a good way to at least reduce the height of the antenna by about 2". Is it totally crazy to saw it off?!
  2. Jan 31, 2012 at 8:17 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    replace it with the older factory style xm antenna. (09-11) I think its around $60.
  3. Feb 1, 2012 at 8:42 AM
    Tortoise
    Ron
    Utah
    12 TRD Sport
    Thanks for your response. It's hard to tell how the shark fin is attached.
  4. Feb 2, 2012 at 12:31 AM
    billyjoe
    billyjoe Taco Fever - I've got it bad!
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Extang Trifecta Tonneau
    You'll need to remove the headliner to verify mounting technique and ultimately change yours out. Pretty easy to remove/install headliner - just refer to the online repair manual for instructions.
    I recently installed a low profile 09-11 OEM sat. antenna on my '05 AC.
    For this version, there is one special nut that holds the antenna down and a locator pin that prevents rotation.
    The antenna part number is color specific:
    86960-04010-A0 Super-White (040)
    86960-04010-D0 Barcelona Red (3R3)
    86960-04010-C0 Black Sand Pearl (209)
    86960-04010-B1 Magnetic Gray (1G3)
    86960-04010-E0 Pyrite Mica (4T3)
    86960-04010-B0 Silver (1E7)
    86960-04010-J0 Speedway Blue (8P1)
    86960-04010-G0 Timberland Mica (6T8)
    The nut you'll need is:
    86396-47010 Sat Antenna Nut
    You can order both parts from Town & Country Toyota for 25% off (55.81 + 6.78). They only charge 3.99 for shipping!
    Hope that helps...:)
  5. Feb 2, 2012 at 11:13 AM
    Tortoise
    Ron
    Utah
    12 TRD Sport
    Thanks so much for the detailed info, billyjoe. This just might do it!!
  6. Feb 3, 2012 at 11:56 AM
    TACONOLE
    TACONOLE Member
    When you installed the new antenna did your truck already have an existing sat antenna ? I want to add sat radio to my 2011 DC using toyota parts but i'm not sure if is possible or worth the hassle. i guess i would have to cut a hole in my roof to run the wires.
  7. Feb 3, 2012 at 1:27 PM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    No, it's a 2005 AC. Toyota didn't offer factory installed Sat Antennas until 2009.
    It's quite easy actually. Simply remove your headliner, drill a 9/16" hole (centered & 5.25" forward of 3rd brake light), use a round file to square the corners, then drill a small hole (forward) for the rotation prevention pin. Insert the antenna "bolt" through the hole and screw the nut on (from inside under roof).
    I'm not sure if the 2011s come pre-wired with Sat antenna cable. If they do, attach it the antenna connector. Then you'll need the optional OEM antenna cable that connects behind the left kick plate and runs to the back of your radio.
    You can purchase a custom cable from VAISTech.com ($80) that provides a shorter direct connection (better signal). Attach this cable to the antenna connector, then route across underside of roof, down the right A-Pillar, along the harness bundle over to the radio.
    Refer to the online service manual for instructions on removing headliner, radio, etc.
    Whole thing took about 1.5 hours:
    - Remove headliner: 20 mins
    - Mount antenna: 25 mins
    - Remove Glove/Radio: 5 mins
    - Route custom cable: 10 mins
    - Reinstall headliner, glove & radio: 30 mins
    Just let me know if you have any further questions :)
  8. Feb 3, 2012 at 4:04 PM
    TACONOLE
    TACONOLE Member
    Thanks, that does sound pretty easy. I hope it's prewired.
  9. Feb 3, 2012 at 8:04 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    Thanks for posting this Tortoise......I was looking at the new style shark fins on a '12 the other day and wondered if they functioned better than the lower styled ones on my '10. Does anyone know if they offer better reception or are interchangeable?
  10. Oct 4, 2012 at 3:45 AM
    trd_eric
    trd_eric Well-Known Member
    Hey I am looking to go the opposite way to a shark fin antenna...does anyone have the part numbers by color for that? Thanks in advance.
  11. Oct 4, 2012 at 3:52 AM
    trd_eric
    Or do they come unpainted? I went to the dealer and when they looked it up only one listing popped up.
    mr_dredd likes this.
  12. Mar 2, 2015 at 10:44 AM
    abbazaba14
    abbazaba14 Member
    Did anyone end up doing the swap? I have a 2015 with the "fin" and would like to go low profile if it works/fits as good.
  13. Mar 2, 2015 at 10:57 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack, RadFlow 2.5" Extended travel Coilovers- front & rear shocks with res, front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    I did the swap on my 2012 which had the fin... with the older flat one so I could run my roof rack. Under my front runner aluminum roof rack it doesn't pickup XM stations going certain directions so I dropped the service
