Any Ideas
Discussion in 'Towing' started by rydaniels, Apr 13, 2012.
  1. Apr 13, 2012 at 7:59 PM
    rydaniels
    rydaniels [OP] Well-Known Member
    South Jersey
    4x4 4cyl manual
    bone stock except tool box in bed
    Anyone have any experience or knowledge on this (or product like it) they are the "helper springs" like an add a leaf for the leaf springs. I am going to be towing 2500-3000 pounds and looking to do something like this (with in budget) to help with the load (be able to handle the tongue weight better). The tow is going to be 900 miles. here is the link: http://www.truckspring.com/products/Hellwig-EZ-990-Medium-Duty-Helper-Spring__HW981.aspx
    thanks
  2. Apr 14, 2012 at 3:12 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    I have not had any thing like this. Just wondering why this and not a weight distribution system on the tongue of trailer?
  3. Apr 14, 2012 at 3:23 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Looks like the Add a leaf--
    same principal--
    What will your "tongue weight" be?
    Good vendors here--they have discount codes.
    Think I payed $80 for the AAL.
    From the pic-It appears that you can adjust the Height with the U bolts.
    AAL did not have that option.
  4. Apr 14, 2012 at 4:20 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    I am leaning that way too...but i think this will have added benefit without trailer as in with payload
  5. Apr 14, 2012 at 4:21 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    I im not sure what the tongue weight will be..but its a 6x12 tandem axel uhaul...I should be good in the tongue weight...just looking to better handle the load and future payloads
  6. Apr 14, 2012 at 5:14 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    In my opinion- it WILL help the stiffness in the rear-Less BOUNCE.
    The thing I like about the one you posted--IT LOOKS adjustable-I would call the co. and ask.
    My truck was too BOUNCY before the AAL install. With NO LOAD!
    Drove like a car--Did not want that.
    After the install--the ride is more like a truck--STILL PRETTY SMOOTH and a good ride.
    Live in a hilly and curvy road area-needed the added stiffness.
    Haul wood in the spring--used the old truck previously--have not used te 03 yet--It has a BUNCH more power.
  7. Apr 14, 2012 at 5:59 PM
    rydaniels
    South Jersey
    4x4 4cyl manual
    cool thanks for the help...much appreciated
