Any interest in a dash cam group buy?
Discussion in 'Automotive Group Buys' started by USDashCamera, Jan 9, 2018.
  1. Mar 17, 2018 at 10:36 AM
    #521
    Bipper2504
    Bipper2504 Well-Known Member
    2016 Magnetic Grey Tacoma TRD Sport
    any one else have problems with their fn800 pro not saving the settings you previously set. like I changed the settings to record continuously in parking mode but when I go back into the app everything goes to default.
    Coop68 and theredofshaw like this.
  2. Mar 17, 2018 at 12:51 PM
    #522
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    Thinkware app sucks wont let me stay connect to the camera! I am trying to configure settings and it keeps crashing Cant do anything anyone else having these problems?
  3. Mar 17, 2018 at 1:07 PM
    #523
    USDashCamera
    USDashCamera [OP] Put it in H
    2017 Quicksand TRD OR
    I don't ever remember it crashing, but maybe it's worth reinstalling the app and factory resetting the camera.
  4. Mar 17, 2018 at 1:49 PM
    #524
    Coop68
    Coop
    Erie/Dacono, CO
    I Think I figured it out was using the wrong app. The cloud one is working and saving the settings the viewer app is not working with the F800pro
  5. Mar 17, 2018 at 5:37 PM
    #525
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Well it took me a few tries to find the correct fuse and I mounted the rear camera upside down (I'll fix that tomorrow). Camera is working.
    P.S. I tried to upload the video but I guess the site does not accept MP4 files.
    Thank you @Sandman614... here you go...https://youtu.be/RL2iBMDFepc
  6. Mar 17, 2018 at 6:10 PM
    #526
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Gotta upload to a hosting site YouTube/vimeo/etc
    theredofshaw likes this.
  7. Mar 18, 2018 at 7:41 AM
    #527
    SH7mi
    Kevin
    West Grove, Pa.
    @USDashCamera,
    I purchased the BlackVue 750S 2 channel. Is there a function (other than manually flipping the camera) to invert the rear camera view. Mine is recording upside down. I mounted it so the writing on the camera is right side up. Reading through the manual, I am not seeing any info on this. Can you help?
  8. Mar 18, 2018 at 9:50 AM
    #528
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    I know there was a setting in the app for the pro. Not sure if they use the same one.
  9. Mar 18, 2018 at 11:00 AM
    #529
    SH7mi
    Kevin
    West Grove, Pa.
    Thank you.
    I drove the truck today and found the option in the firmware.
    theredofshaw[QUOTED] likes this.
  10. Mar 19, 2018 at 5:20 PM
    #530
    USDashCamera
    yea there are two different thinkware apps, i did the same thing because i went from a f770 to the f800 and assumed i could use the same app. wasted bunch of time in frustration hah.
    Coop68[QUOTED] likes this.
  11. Mar 19, 2018 at 5:24 PM
    #531
    USDashCamera
    cant recall on the 750s, don't have it on hand anymore. I am testing the DR590 right now tho and there seems to be an option. If its not in the settings on the app or PC/mac app it might not have it. its not unusual for blackvue cams to have different options than others, its sort of frustrating.
    honestly if I were you I would just reinstall the camera. I seriously did the exact same thing with my DR550GW-2CH years ago haha. Did it come with a spare adhesive? I can't remember if the 750S did when I got it for review, I know they usually do have one extra for both cams.
    Otherwise if you go to target or walmart they should have it near the super glue and tape in packs of strips. 3M sells the same stuff called "VHB" tape. i know target sells it in packs of 2"x1" strips you can just cut down.
    edit: although you should probably double check and make sure you didn't change a setting to flip the rear camera first. the text should definitely be right side up.
    the way I always install blackvue cams now, is if you are looking TOWARDS the window from OUTSIDE, the mount should be to the left of the lens. so when you are inside the car looking at the cam, the mount is always to the right of the lens. pretty sure thats how its always been with blackvue cams for 4+ years, front and rear cams.
  12. Mar 19, 2018 at 5:27 PM
    #532
    SH7mi
    Kevin
    West Grove, Pa.
    Thanks for responding.
    I found the option in the firmware.
  13. Mar 19, 2018 at 5:31 PM
    #533
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Okay, I’ve been lazy. I installed my main camera, but have yet to run the wire all the way to the back of my shell for my rear.
    Is the supplied wire long enough, or do I need a longer one?
    Camera is the 800 Pro.
  14. Mar 19, 2018 at 5:41 PM
    #534
    USDashCamera
    I needed an extension but depends on how you wire it i guess. I wired it along the passenger a pillar, then went under the plastic trip along the bottom of the door, and out the firewall under the front passenger seat. used palstic tubing to protected the cable and used zip ties to wire it along the frame, then had it come out and up right along the edge of the tailgate frame on the passenger side. I think I ran out of cable at the top of my topper so i needed a few more feed to get to the center. If I were you I would wire it how you want first, then measure how much you need. i ended up with too much slack and had to tie up slack at the top of my topper.
    Naveronski[QUOTED] and Coop68 like this.
  15. Mar 19, 2018 at 6:52 PM
    #535
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    @USDashCamera Curious... Do your incident recordings have sound? I think mine don't.
    F800 Pro here.
    May just have to play with settings.
  16. Mar 20, 2018 at 6:44 AM
    #536
    SH7mi
    Kevin
    West Grove, Pa.
    Have any of you had issues with the WiFi connection to the dash cam interfering with other signals getting to your phone? I.e. Pandora and receiving texts.
  17. Mar 20, 2018 at 7:08 AM
    #537
    Naveronski
    Fort Worth
    Yes. My phone seems to think it’s a normal WiFi connection, and doesn’t realize it needs to still use LTE for data.
    I’m not thrilled about that, and their software seems to be hit-or-miss when connecting to the cam.
  18. Mar 20, 2018 at 7:09 AM
    #538
    Naveronski
    Fort Worth
  19. Mar 20, 2018 at 10:54 AM
    #539
    USDashCamera
    well in general you would only want to connect to it when you are changing settings or saving files. I am pretty sure it actually stops recording while connected via WiFi even. If you want to be connected without interruption to the camera or your phone you would need to do the hot spot setting.
    SH7mi likes this.
  20. Mar 20, 2018 at 11:34 AM
    #540
    SH7mi
    Kevin
    West Grove, Pa.
    I guess I thought it needed to be connected via WiFi constantly. The camera keeps the recordings on the memory card, if I do need to view it I would then turn on WiFi, I got it now. Please forgive my ignorance with this technology, I'm still not good with my PC.
