Any interest in upgraded steering rack bushings??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speed Freek, May 15, 2012.
  1. May 15, 2012 at 8:35 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    I was thinking of making some sets of rack bushings since they seem to be unavailable unless you purchase an entire rack assembly!
    Crazy....gotta be a better way, and there is!
    If there is enough interest I will build a batch using oilite, it is an oil impregnated brass casting, these should last the life of the truck.
    Another benefit would be more precise steering input without deflection on the worn out rubber bushings that ususally get oil soaked and turn into mush.
    Any interest?? The cost will be affordable, the more I make the cheaper it is as most of you know...
  2. May 15, 2012 at 8:38 AM
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
    how much brother
  3. May 15, 2012 at 8:45 AM
    Speed Freek
    Not sure, I haven priced a complete stick of oilite, but I am thinking anywhere between $60 and $80 for pair, after cost of material and having it machined at a shop.
    If I get enough interest I will start a group buy and that will help cut costs toward the lower end of the estimate.
  4. May 15, 2012 at 8:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Color me curious.............
  5. May 15, 2012 at 8:46 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    DEFINITELY INTERESTED! !!
  6. May 15, 2012 at 8:53 AM
    Speed Freek
    Nice, getting more interest over here than CT, its a damn ghost town over there, lol.
    I got probably 10 PMs about new bushings, i put up a post and absolutely no takers...? Everybody wants a set until the time comes to pay up, then people tend to look at the ground and walk away...
    I figures if it was cheap enough I would have a friggin flood of orders, I see sooooo many Tacos with bushings as soft as gummy bears, mine included!
  7. May 15, 2012 at 8:55 AM
    Speed Freek
    I see some of you are 2nd gens, I will look at those and see if I can make sets for those as long as its roughly the same configuration, then I can make bushings for those as well, shouldnt be a problem.
    What I do is order a complete rack, remove and measure the bushings and then send it back and say I didnt need it, free R&D!
  8. May 15, 2012 at 9:00 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Which piece is this? The actual tie rod end? :notsure:
  9. May 15, 2012 at 9:03 AM
    Speed Freek
    No its the actual bushing that holds the rack to the frame of the truck. If you go in the truck and turn your wheel back and fourth slightly and very little happens, most likely your bushings have play, even brand new truck have a little, and older ones usually have a LOT!
  10. May 15, 2012 at 9:05 AM
    nfs257
    Ah... I see~ My tie rod end has grease oozing out which is why I asked.
  11. May 15, 2012 at 9:14 AM
    Speed Freek
    That means its time for a regrease!
    If ya need any maintenance let me know I work on cars for a living as well as fabrication, and teaching SCUBA diving...gotta multi-faceted these days in order to make a buck!
  12. May 15, 2012 at 9:18 AM
    nfs257
    There is no grease zerks! AT ALL! It really sucks!
  13. May 15, 2012 at 9:19 AM
    dorkmagus
    dorkmagus Well-Known Member
    Shane
    Bentonville, AR
    2012 Double Cab Tacoma TRD OR
  14. May 15, 2012 at 9:25 AM
    Speed Freek
    Sheesh, i guess there is bushings (polyurethane) last time I searched I couldnt find them..
    So I guess the question now is who would want a set made from oilite?
  15. May 15, 2012 at 9:25 AM
    Speed Freek
    You gotta use a grease needle...;)
  16. May 15, 2012 at 9:50 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
  17. May 15, 2012 at 10:24 AM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Only one bushing labeled 'grommet' is shown. You won't see it in the FSM because it is not a Toyota recommended repair. They want you to buy a whole new rack.
    You can see what bushings need replacement here: http://www.lieblweb.com/steeringbush.html
    Also check out the wheelers link above for more info.
    I did this a few weeks ago. This a GREAT "mod" if you're experiencing poor or loose steering and double bump or clunky steering over rough roads. I highly suggest it and wish I did it earlier
    Jason - I'd like to see what you come up with... Greasable somehow?
  18. May 15, 2012 at 10:25 AM
    Speed Freek
  19. May 15, 2012 at 1:09 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Don't see any for 2nd gens in that link...................
  20. May 15, 2012 at 1:24 PM
    boshak
    Tony
    Southern California
