Any issues changing to synthetic oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebigk, Jun 4, 2010.
  1. Jun 4, 2010 at 10:32 AM
    thebigk
    thebigk [OP] 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    I'm thinking about switching to synthetic and doing my own oil changes on my next interval. (20k)
    Is there anything "special" needed to switch? Or just drain the oil...change the filter & pour in synthetic?
    Any special oil filter needed?
  2. Jun 4, 2010 at 10:40 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I made the switch over a year ago, and the only thing I did was change the oil while the engine was still fairly warm so that the old oil would run out as much as possible. Run the synthetic in there and consider doing another oil change in about 500 miles just to get the synth/regular oil mix out. No need to change anything else that I'm aware of, and the truck runs nice.
  3. Jun 4, 2010 at 10:42 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    You should be fine. Just keep a close eye out for small leaks. It can happen, but I have not ever seen it myself.
  4. Jun 4, 2010 at 10:58 AM
    270 Well-Known Member
    Jeff
    California
    09 Dc 4x4
    Why would you need to check for small leaks?
  5. Jun 4, 2010 at 11:02 AM
    wlmuncy
    William
    Knoxville, TN
  6. Jun 4, 2010 at 11:03 AM
    lrak
    lrak Well-Known Member
    I'd love to here an explanation on why someone would want to do that.
  7. Jun 4, 2010 at 11:06 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    You don't have to, but I'm anal like that and wanted to "flush out" the old oil with the new.
  8. Jun 4, 2010 at 11:14 AM
    Jeff
    California
    09 Dc 4x4
    So if you have a newer truck, assuming you dont have any engine problems, then you should be fine switching to synthetic?
  9. Jun 4, 2010 at 11:18 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Synthetic oil molecules are so much smaller than the regular molecules. Seriously, they're like Z-Max size and will leak everywhere. Double torque specs for all bolts that touch synthetic oil. [Jeezus don't do this, really]
    Seriously, just change it like you normally would and roll. I have no idea how all these synthetic oil fairytales came about. My personal favorites inlcude not being able to change back to regular oil ever, and never ever mix synthetic and regular oils. (Synthetic blends are different though).
    The only thing I've gathered is that synthetics are great if you might procrastinate on an oil change and will give you some extra protection if you go over your change intervals. Which is a whole 'nother topic altogether. 3000, 5000, 7500, 8000, 10000? Amsoil for life?
  10. Jun 4, 2010 at 11:19 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The reason is that synthetic oils generally have stronger additive packages (anti-wear additives, anti-corrosives and especially detergents) than dino oils since they are designed to be run with extended drain intervals. Consequently it could loosen sludge and varnish that has accumulated...it's kinda like a motor flush but done with something that doesn't damage the bearings if you drive it.
    Changing early on a low mileage motor, or one with good maintenance, is not very likely needed at all.
  11. Jun 4, 2010 at 11:23 AM
    wlmuncy
    William
    Knoxville, TN
    yes you should have no problem. I changed over on a 4.0 Jeep Grand Cherokee with 120k miles, I had no problems. You should just be aware to keep an eye out.
  12. Jun 4, 2010 at 11:27 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    You'd be fine switching even with an older motor and one with problems.
    Although it depends on what the problems are. Synthetic isn't a cure (usually). Problems will still be there...to me it's far better to leak/burn out 2 qts of cheap dino every thousand miles than expensive synthetic.
  13. Jun 4, 2010 at 11:27 AM
    ExFordFan
    ExFordFan Semper Fi
    Mark
    Wauwatosa, WI.
    Stock
    Where did this come from? I'd like to see some documentation on this. Start doubling torque specs you better have some good drill bits and easy outs cause stuff will start breaking and gaskets will stare leaking.
  14. Jun 4, 2010 at 11:29 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I'm sure he was being sarcastic...
    ok...I hope...
  15. Jun 4, 2010 at 11:34 AM
    SManZ
    Fauquier County, VA
    Lol people will believe anything...
    I better edit my post before someone fucks up their oil pan.
  16. Jun 4, 2010 at 12:29 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    been running fully synthetic since day 1...:D never had a problem and I take tons of road trips...
