Any issues running headlights w/out the rubber seal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RustyBolts, Apr 9, 2017.
  1. Apr 9, 2017 at 11:05 AM
    RustyBolts
    RustyBolts [OP] Well-Known Member
    San Diego
    TRD 4x4
    Replaced my oem headlight bulbs with LED bulbs but the new LEDs have dedicated fans and heat fins too large to get the rubber boot over (seals the back of the headlight receiver and bulb) and lock via the metal spring retainer.
    Currently I'm running them with no rubber boot but was wondering if there might be future issues down the road? Or immediate issues?
  2. Apr 9, 2017 at 1:45 PM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Rubber boots keep water out of the connector, lamp, headlight housing, etc. Cheap item to replace if torn or whatever, expensive to fix later when water damaged.
    Silverspool likes this.
  3. Apr 9, 2017 at 1:55 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I haven't ran any in years. If you wheel in dusty environments you may collect dust inside your fixtures.
  4. Apr 9, 2017 at 2:23 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They're called dust boots.
    You'll get some dust inside as time goes on, how much varies on where you drive.
  5. Apr 9, 2017 at 2:48 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Can you trim the stock dust boot, so it'll fit around the LED but the fan will be sticking out? May not be a total seal, but some is better than none.
  6. Apr 9, 2017 at 4:23 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i had issues getting water in mine... but im in rainy Canada.
  7. Apr 9, 2017 at 5:35 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Over time, the combination of dust and moisture will contaminate the active parabolas and insides of the lenses, eventually degrading light output.
  8. Apr 9, 2017 at 6:43 PM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    OP, what LED's did you install. I just did the same today, installed OPT7 Fluxbeam LED's and I was wondering the same thing. Although I have been thinking that the fans need to be in the open to allow for adequate cooling. If you install the boot, you don't want to cover the fan area. I would consider doing installing the boot and doing all I can not to cover the fan area. something to consider
  9. Apr 9, 2017 at 6:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Unless you have retrofits, please read this to see why those are a bad idea:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
  10. Apr 9, 2017 at 7:04 PM
    gmann1972
    Greg
    Rhode Island
    I don't have retrofits, and I have read this thread previously, although I don't notice "light scatter". I parked my truck on my street (in the dark), hopped in my wifes car, parked at the other end of the street facing my truck (about 100yrds) drove slowly towards my truck and I did not find the new lights on my truck blinding at all. sooooooo, idk?
  11. Apr 9, 2017 at 7:41 PM
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    Put bulb through boot first then install. Your headlight will condense
  12. Apr 9, 2017 at 8:37 PM
    RustyBolts
    San Diego
    TRD 4x4
    I tried that, the collar actually twists off. It was re-applying the spring tension bar that was the issue while the rubber seal was on. There wasn't enough room.
    Final thoughts - I've uninstalled them and put the normal H4 bulbs back on. I've run them for one night and the color bothered my eyes. Oh well, it was an impulse Amazon gift card buy and I can send them back.
  13. Apr 9, 2017 at 8:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  14. Apr 9, 2017 at 9:42 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Use an led with a removeable heat sink. The led bulb goes in, then the boot and then screw on the heat sink. Ive been running these for a coupoe of years with no issues. No scattered light and the the pattern is the same as the stock bulb. I never get flashed.
