Any issues with instrument cluster programming?
Discussion in '4th Gen. Tacomas (2024+)' started by LouDawgIII, Sep 26, 2024.
  1. Sep 29, 2024 at 8:48 PM
    metdfd
    metdfd Well-Known Member
    Has anyone here taken it to the dealer for this?
  2. Sep 30, 2024 at 3:41 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Good idea to get the process rolling. Going to roll into scheduled service.
  3. Oct 2, 2024 at 11:29 AM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    My 24 Pro will not memorize TPMS either!
  4. Oct 2, 2024 at 8:04 PM
    FdogBrowncloud
    FdogBrowncloud Well-Known Member
    2024 TRD OR DCLB
    Too poor for mods
    Same here, tried to put tire pressure in place of pitch/roll and it stuck for about a week before it magically turned into trip a/b
    Ryan's Taco likes this.
  5. Oct 3, 2024 at 7:00 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    Seems like all but 1 of us is having this problem. Hope they come up with a fix mind you now that I have done it 100 times it only takes about 5 seconds to fix it and go back to my main screen
  6. Oct 3, 2024 at 7:34 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    I wish there was more than 3 pages of gauges . There's enough to have like 6!
    Want-a-taco likes this.
  7. Oct 3, 2024 at 11:20 AM
    tactrac
    tactrac Well-Known Member
    2024 TRD Off-Road
    You’ll need more than 6. If you have a TRD or TH there are at least 1350 permutations for the 12.3” display.
    (15 on the LH side) x (6 in the center) x (15 on the RH side) = 1350.
    Or is my math off?
  8. Oct 7, 2024 at 2:15 PM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    You guys have jinxed me! Now I'm losing it (changes to Trip B). However, there was a change that occurred. I got the privacy policy change notice and declined to have my location sent. So all of the connected services were disabled. I've turned them back on to see if that helps. Will let you know.
  9. Oct 7, 2024 at 4:37 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    The TPMS lack of permanence also affects some (maybe all?) other Toyota models with the digital-dash, in my personal experience. Some sort of software bug.
  10. Oct 7, 2024 at 4:39 PM
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    Wouldn't need as many pages if we could put any gauge in the center. All gauges should be able to go in any of the 3 positions. There's also small stuff that could be permanent elsewhere in the empty real estate.
    I find what works best is round tach in the center, this way, oil pressure and temp is on the lower left, and alternator and fuel gauge on the lower right. So no need to add those in another precious spot.
    Vitamins likes this.
  11. Oct 7, 2024 at 5:02 PM
    gmtech
    Stock AF
    Yes since it's all digital there should be more options. Even sweet retro bar graph one would be cool!
  12. Oct 8, 2024 at 1:15 PM
    soupy1234
    With all of the connected services enabled I no longer lose the TPMS display.
    I'm going comet chasing for the next few days but after that I'll try disabling individual services to see if I can determine if there is a specific one that is causing the problem.
  13. Oct 12, 2024 at 3:53 PM
    snickers
    This is interesting. I can replicate this as well.
  14. Oct 12, 2024 at 5:13 PM
    FdogBrowncloud
    2024 TRD OR DCLB
    Too poor for mods
    It would be super interesting, and not surprising, if TPMS data was making a round trip through Toyota servers between the ECU and the dash.
  15. Oct 13, 2024 at 9:03 AM
    #35
    soupy1234
    I think it's more that your custom settings are tied in with your account profile and getting reset if your profile is not available. Should be able to save settings locally though. Still have to consider this a bug in my opinion. Odd that I've never noticed it happening when I'm somewhere with no cellular service. Will have to play with it some more later. Going comet chasing again. Came up with clouds last week.
    PS: it's not just the TPMS display that changed for me when I disabled communication, all 3 displays reverted to their default settings (I have customized all of them).
  16. Oct 13, 2024 at 2:31 PM
    #36
    snickers
    The only service I didn't have selected was the reporting to insurance companies. When enabled, TPMS is now sticky. :eek:
  17. Oct 13, 2024 at 5:16 PM
    #37
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    this is what I think as well, mine worked fine until i cancelled all the Toyota app stuff
  18. Oct 13, 2024 at 9:56 PM
    #38
    bdkjones
    bdkjones Well-Known Member
    Bryan
    2024 TRD Off-Road
    I also have all of the "Connected Services" nonsense disabled and experience the same TPMS widget issue. Would a software update fixing the problem be installable at home over the air, or is that a take-it-to-the-dealer-and-have-the-system-flashed thing? (I haven't owned a car with updatable software before.)
  19. Oct 14, 2024 at 9:16 AM
    #39
    tactrac
    2024 TRD Off-Road
    Where/how are connected services enabled/disabled? App or multimedia screen?
  20. Oct 14, 2024 at 9:40 AM
    #40
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    It's probably not, since it's a function that needs to work out in the wilderness where there's no cellular signal. That and it does function with the connected services turned off. The display just doesn't stick.
    I'm sure it's just a glitch that wasn't particularly well tested because it really sounds like an edge case. I'm a professional software QA engineer and have been for quite a few years. It probably wouldn't have occurred to me to test the persistence of the display setting in connection with the connected services setting. What the heck would they have to do with one another?
    Regardless, the way software glitches get fixed is by users that experience them reporting them and providing whatever information they can surrounding the circumstances of when the glitch happened. The developers need data to be able to reproduce the problem so they can identify the root cause, fix it, and QA can make sure it's really corrected. Keep telling them everything you know when you experience it.
    nosualc, CharlieCafe and gmtech like this.
