Any issues with my life/wheel/tire setup?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17Taco96, May 11, 2020.
  1. May 11, 2020 at 7:03 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    You can throw money at me too...... :anonymous:
    71tattooguy and rmepilot like this.
  2. May 11, 2020 at 7:18 PM
    Brofessor
    Brofessor Well-Known Member
    I don’t know... you tell me. Looks like you have experience.
  3. May 11, 2020 at 7:27 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    You don’t know the half of it.
    So let me give you some free, unsolicited advice. There’s plenty of threads to be an asshole, on purpose. A new members thread is not one of them. Lucky for you, it wasn’t the OP.
    Looks like I have a new MVP..see you around brah.
  4. May 11, 2020 at 7:53 PM
    Brofessor
    I guess that depends on what you call problematic... 265s will be more fuel efficient. 285s will look more aggressive and will fill out your truck nicer. They will also put more rubber on the ground which is a good thing (traction wise).
    most people on here always end up going bigger. That’s not to say that 265s don’t work, but most end up upgrading.
    With 285s, lift/wheels you plan on going with, there would be some trimming of the fender liner. With a good alignment you can get away without having to do a CMC, especially if you don’t do any heavy off-roading.
    only modification required (if you don’t off-road heavily) would be trimming some plastic, which is not a big deal. Really isn’t. Even the CMC is not a big deal.
    I suggested skipping the eibach because the 5100s are adjustable. They were engineered to lift your truck just as is. Saves you some money.
    Lifting your truck on 265/70s won’t look right. Like a guy that goes to the gym and never trains legs.
    Buy once, cry once!
  5. May 11, 2020 at 8:21 PM
    Brofessor
  6. May 11, 2020 at 8:51 PM
    ColoradoTJ
    Colorado
    You made it easy. See you in seven.
    jmauvais and rmepilot like this.
  7. May 11, 2020 at 10:02 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    My opinion is that 9” rims are a touch too wide for 265 tires. You might have rubbing issues due to the wide rim and modest backspace.
    17x8 0 offset will widen the stance a little. You could get more aggressive with -10 or -20 offset but you might start rubbing again.
  8. May 11, 2020 at 10:50 PM
    Aaronparker001
    Aaronparker001 Just another basic dude in a tacoma
    Pacific Northwest
    2019 TRDOR DCSB MT BLACK
    Not sure how many miles you have on your truck or how it been used and/or abused but before deciding on AAL or block take a look at your rear leaf springs. If they are flat I would encourage you to look into a full leaf replacement. Yes, they are more expensive but as you’ll hear around here “buy once, cry once.”
    rmepilot likes this.
