Any issues without an exhaust heat shield ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Jan 5, 2017.
  1. Jan 5, 2017 at 2:53 PM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    One of my exhaust heat shields was rattling and when I looked under the truck it was hanging partially loose and came completey off with just a small tug. It's the one under the rear passenger side, mid way back but forward of the muffler. Is there any reason to replace this or is it ok just not being there??
  2. Jan 6, 2017 at 8:07 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Nobody has an opinion on this?
  3. Jan 6, 2017 at 8:11 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Are u talking about the shields surrounding the cats?
    I ripped mine off long ago and havent burned down
  4. Jan 6, 2017 at 8:15 AM
    Markcal
    Markcal Well-Known Member
    My neighbor has a 2005 tacoma and I told him about the rattle I was having and had me stumped where it was coming from. He told me he used a stainless steel band clamp on his heat shield, so I did the same and the rattle is gone. I would use this method to reinstall the heat shield, because if it didn't have a purpose Toyota would never have it there in the first place.
  5. Jan 6, 2017 at 8:30 AM
    inwood customs
    Dave
    Long tube headers ftw
  6. Jan 6, 2017 at 12:41 PM
    Jeff350
    Jeff350 Well-Known Member
    Colorado
    2008 TRD Off-Road
    Where does a heat shield rattle sound like it's coming from? I have an intermittent rattle from the drivers footwell/dash area that I haven't been able to track down. I might have to check the heat shields this weekend.
  7. Jan 6, 2017 at 12:45 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    A lot of rattling comes from rusted and loose heat shields,I would repair mine.
  8. Jan 6, 2017 at 1:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Add larger washers to nuts to disperse the load. The shields' mounting holes wear out and sometimes widen over the years.
  9. Jan 6, 2017 at 1:11 PM
    Markcal
    I thought at first the sound was coming from my universal joints, but it never occurred to me the heat shield were loose.
  10. Jan 6, 2017 at 1:16 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    No problem.... those things don't really do much in the grand scheme of things
  11. Jan 6, 2017 at 1:17 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I took mine off cause they were rattling. No problems yet and it's been a year/ 20,000 miles
    inwood customs likes this.
  12. Jan 6, 2017 at 1:26 PM
    inwood customs
    Dave
    Crawl under when the trucks cool.... smack the shield around.
    Next move is up to you
  13. Jan 6, 2017 at 2:45 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Easy enough to put it back on with a couple stainless hose clamps. I did it to mine.
    Clearwater Bill likes this.
  14. Jan 13, 2017 at 6:47 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    For the people who said use a hose clamp, did you just wrap the exhaust with the heat shield? If it's not a problem I'm probably going to end up just yanking them off, here in MA with all the road salt those nuts are going to be a royal PITA to get off and I'm probably going to snap at least one of them. I pulled one off since it was barely hanging on but now another one somewhere is rattling, it's probably only a matter of time before the others all start to fall off.
  15. Jan 13, 2017 at 8:46 AM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    I previously owned an Xterra that always had this issue. I replaced the factory rusted, broken, rattling straps with hose clamps. I'm in northern Minnesota though, and because of the road salt and whatnot, I ended up replacing rusted, broken, rattling hose clamps about once a year as well. And yes, I just wrapped it around the exhaust, replacing the factory clamp that was originally in the same place.
  16. Jun 21, 2019 at 7:56 PM
    81shark
    81shark Well-Known Member
    Mine came off and wedged it self about two feet behind where it was suppose to be. Defiantly felt warmer in the footwell. I'm going with oversized washers and some type of clamp
  17. Jun 22, 2019 at 1:40 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    If you mean the textured aluminum ones mounted to the body, above the exhaust pipes/muffler, mine have been gone for many, many miles. They partially rusted off, rattled off and got ripped off because any rattles and vibrations annoy me. I could only see it causing an issue during prolonged periods of idling.
  18. Oct 6, 2020 at 12:12 PM
    shley<3stacos
    shley<3stacos New Member
    Boston
    2009 Tacoma TRD access cab
    Topper
    It’s to prevent the grass from catching fire when parking on grass with 500 plus degree exhaust pipe. This is something I have read online, not something I know from experience.
