Any issues you’re still waiting to be fixed before buying a new Tacoma?
Discussion in '4th Gen. Tacomas (2024+)' started by CTNZ, Jan 23, 2025.
  1. Jan 25, 2025 at 4:36 PM
    #41
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    You have to roll with the groping.
    Put your hands behind your head, lean back, and sigh or moan a little bit.
    If you can make eye contact, it's a bonus.
    Barsoom likes this.
  2. Jan 25, 2025 at 4:45 PM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The only issue I’d like to make sure was fixed is the potential HVAC box cracking. Haven’t heard of many of those lately though, although I could have missed some of them if they are still happening.
    My 3rd gen is annoying me enough to push me in that direction of actually getting serious to swap to a 4th…
  3. Jan 25, 2025 at 7:09 PM
    #43
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Then keep whining about your local prices.
  4. Jan 25, 2025 at 7:37 PM
    #44
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    I’ll take the “non-access” “access” cab, IF they ever offer it in a TRD OR. The lack of long bed short wheelbase in an OR model might be a dealbreaker for me. You can’t retrofit MTS in an SR5.
    That one old guy and dneal like this.
  5. Jan 25, 2025 at 7:45 PM
    #45
    bananaboat
    bananaboat Well-Known Member
    Here's what I'm waiting for:
    1) six more months for new problems to arise;
    2) a large backup of trucks similar to the one I want on dealer lots so discounts start to happen and dealers remove all the add-on garbage from window stickers.
    I'm patient and don't mind waiting another year or two if necessary. Fortunately I have a very reliable and paid off gen2 that does everything I need to do with a truck.
    Kolter45, Raylo and That one old guy like this.
  6. Jan 25, 2025 at 8:27 PM
    #46
    MJB4450
    MJB4450 Well-Known Member
    2025 SR5 Supersonic Red
    Since your plan wasn't well thought through, I plan on doing just that. Stay tuned.
  7. Jan 25, 2025 at 10:05 PM
    #47
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Less power, less torque delivered at a later rpm, and worse fuel mileage. Exactly how is it better?
  8. Jan 26, 2025 at 3:18 AM
    #48
    World2405
    World2405 WUBBA LUBBA DUB DUB!!!!1!
    Delaware
    2023 Toyota 4Runner
    That’s just like your opinion man.
    AvalonTaco likes this.
  9. Jan 26, 2025 at 5:26 AM
    #49
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    And I'll take one as soon as they make it with the doors allowing proper "access" as originally designed. I got no problem with an SR, actually prefer the solid rear axle. Until then, deal breaker....:(
  10. Jan 26, 2025 at 6:26 AM
    #50
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    You know why they kill off?
    Not only Dodge.. Every dealerships. I mean, Chevy, Ford, etc. Except the big trucks for towing. If the trucks are no longer having V8, then you have to get RV that allows you to drive in RV... instead of pulling RV.
    Nice. I flown to Virgin Islands then back to the mainlands before the hurricane hit the islands. Good timing on my part. Wheeew.
    I have drove from SC to Utah without stopping for the night which totals 28 hours of driving.
    I haven't driven long trips since 2010. 2010 was my last trip.
  11. Jan 26, 2025 at 7:31 AM
    #51
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    My ‘99 was like that. Toyota called it an Xtracab. That’s a much shorter name than Non-Access Access Cab.
  12. Jan 26, 2025 at 7:58 AM
    #52
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I think this thread has taken a 90 degree turn. I feel the OP was looking at problems that need to be fixed and it's turned into a list of features or design changes that people want. I'm looking at buying a 4th gen in the next year or 2 and would like to know if things are getting better with the transmission. I'd also like to know if the turbo has had issues since that's a common point of failure with all vehicles from all manufactures. With a little googling you can find that some of the first models had transmission issues. Toyota created a TSB for the issues so they do acknowledge a problem. I found that some of the codes of a transmission issue are
    P07407F - Torque Converter Clutch Actuator Stuck Off
    P079571 - Pressure Control Solenoid "C" Actuator Stuck
    P08BA71 - Pressure Control Solenoid "L" Actuator Stuck
    P271371 - Pressure Control Solenoid "D" Actuator Stuck
    P280771 - Pressure Control Solenoid "G" Actuator Stuck
    P281671 - Pressure Control Solenoid "H" Actuator Stuck
    I'm 170 miles from 200K on my 2010. I've only had a few suspension parts replaced but the engine and drive train has had zero issues. I'd like to know if I can expect something like that with the 4th gen. I understand it requires time and many trucks with high mileage to predict that. Some people on this forum have put close to 100K miles a year on a Tacoma (wow!). Is there someone that is doing that on the 4th gen and what have been your experience?
  13. Jan 26, 2025 at 8:09 AM
    #53
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    hes a troll, dont feed em
    Sagebrush likes this.
  14. Jan 26, 2025 at 8:40 AM
    #54
    That one old guy
    Chuck
    Stockish
    Shorter,yes. As accurate, No. :cool:
  15. Jan 26, 2025 at 8:44 AM
    #55
    Sagebrush
    Gens 1, 2, 3, and 4
    I think most trolls here have been abused at some point. Thus, the tolling.
    PEAKIT likes this.
  16. Jan 26, 2025 at 9:09 AM
    #56
    MJB4450
    Yeah, that must be it. Couldn't be anything else.
    PEAKIT likes this.
  17. Jan 26, 2025 at 12:44 PM
    #57
    alphaomega420
    alphaomega420 Well-Known Member
    2019 SR SX V6 RWD
    Not exactly, my truck is a 2019 but I bought it in 2023. I feel fine with a 7-year trial run. I actually wanted a 2.7 but it was hard to find towards the end of 2023.
    Part of the reason I would probably not own a 4th gen are the prices. They’re way too expensive for a mid-size imo.
    bananaboat and MJB4450 like this.
  18. Jan 26, 2025 at 2:09 PM
    #58
    OpeCity
    Long Beach, CA
    With a matching feature set, they’re roughly the inflation adjust price of previous gens but vastly improved in nearly every way
  19. Jan 26, 2025 at 4:05 PM
    #59
    jdjones
    Nothing wrong with that other than wages haven’t kept up.
    bananaboat, PDKTaco and TomHGZ like this.
  20. Jan 26, 2025 at 5:42 PM
    #60
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    I waited too and got tired of waiting and got the long bed Double cab OR premium in October. The back seats have hardly any room compared to my 2016 access cab and the floor isn't flat so i cant just take them out. And i wish I had got a SR5 Cold weather package instead. I don’t like much of the premium stuff now that I've had it 2000 miles. I like the seats and the larger screen because I am blind close up, and sunroof. But i have nearly everything that makes it s premium turned off. It regularly gets 17mpg the first time i got 19 was last weekend on an 800mile trip in eco mode on cruise at 75
