any known transmission issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mbarr, Oct 8, 2008.
  1. Oct 8, 2008 at 1:24 PM
    mbarr
    mbarr [OP] mgb2
    Dallas, GA
    06' PreRunner X-SP
    3" Pro-Comp lift. 33x12.50x20 Toyo M/T tires. 20x9 Driv Growler (-12) wheels. T-Rex billet grills. 8" shorty radio antenna. K&N Cold Air intake. Husky Liner floor mats and Crabon Fiber dash. TRD Exhaust, Skid Plate, & Shifter.
    Has anyone heard or had issues with 05+ Tacomas transmission jerking foward while stopped at a red-light, stop sign, etc.? I also have a loud whining noise or vibration while in reverse!!
    I've taken it to the dealer and they just said that's how they are. B.S. or is this true?
  2. Oct 8, 2008 at 1:26 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    the lurch forward is normal. just keep ur foot on the brake at a stop... after u drive a little you wont even notice after awhile
  3. Oct 8, 2008 at 1:29 PM
    mbarr
    mbarr [OP] mgb2
    Dallas, GA
    06' PreRunner X-SP
    its actually gotten progressively worse. If that is just how they are then I don't see how they would actually sell any trucks, thats how bad its gotten
  4. Oct 8, 2008 at 1:30 PM
    tacoskim
    Los Angeles, CA
    Stock
    someone already tried making a court case out of it and he lost
  5. Oct 8, 2008 at 1:32 PM
    mbarr
    mbarr [OP] mgb2
    Dallas, GA
    06' PreRunner X-SP
    that sux, so pretty much just deal with it huh?
  6. Oct 8, 2008 at 1:33 PM
    tacoskim
    Los Angeles, CA
    Stock
    if its as bad as u say it is then theres got to be something wrong with it. ive had my truck for 39,000 miles and i havent noticed it getting worse. i mainly feel it when my a/c is on
  7. Oct 8, 2008 at 1:34 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    it only does it once in a while for me so you should probably have that looked at
  8. Oct 8, 2008 at 1:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    have the dealership check the fluid level for you. when i had my 06, it shifted weird and had a bit of a lunge forward to it, got the fluid checked, and it was a quart low from the factory. it may fix it for ya!
  9. Oct 8, 2008 at 4:17 PM
    tflorida
    tflorida Member
    08 Sport SR5 Double Cab
    This has actually been a very big complaint. The national highway traffic and safety administration (NHTSA) has just recently concluded an investigation, and they could not find a problem. There were over 400 complaints, 50+ accidents and 12 injuries due to tacomas accelerating by themselves. It's even been on the I-team news a few times. The complaints ranged from surging at stoplights to people hitting 120 mph against there will. The idle on my new tacoma was going up a little when I pushed in the clutch and it was throwing an "idle air control valve" error code. They put in a new throttle body kit, which includes the idle air control valve and it fixed the problem with mine. Maybe the same thing is causing your problem, but you would expect that you would also get the error code.
  10. Oct 8, 2008 at 4:24 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Really! Officer the truck was going 120mph against my will! Honest! I don't know what happened!:D
    My truck goes 80 on the interstate all the time. There must be something to this. Or my foot is in on it too!:laugh:
  11. Oct 8, 2008 at 4:52 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    well how do i know if my auto trany maybe low? after all, the truck is made in mexico!! i thought the truck was made in tremont, calif?
  12. Oct 8, 2008 at 5:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    easiest way is to get the dealer to check it for you...its a long process.
