Any last recommendations? Install next weekend.
Discussion in 'Audio & Video' started by mceagle555, Aug 28, 2009.
  1. Aug 28, 2009 at 10:25 AM
    mceagle555
    mceagle555 [OP] Tacoma Shrek
    VA
    '05 Impulse Red PreRunner DC TRD OR
    Metra iPod/aux; Rugged Cover Tri-fold Tonneau; Center Console Divider; AFE Pro-Dry S AF; 4-leaf TSB; Fumoto Oil Valve;
    Well, the time has come where I've found enough good deals to start my moderate sound system upgrade. I plan on doing the install next weekend and I am looking for any specific advice fellow Taco owners might have.
    What I have thus far going in:
    Kenwood DDX512 (Factory refurb): $265
    Metra Dash Kit & Harness: $25
    Infinity Reference 6020cs Speakers (New): $65
    RaamMat BXT, Ensolite Sound Deadening: $148
    USB Extension Cable to Center Console for Ipod: $6
    3.5mm Headphone Cable to Center Console: $6
    Note: This is my first install and I don't want to jump into an AMP yet. I purposely picked a receiver with 22 watts RMS for this purpose.
    Other Things
    - Plan on using the stock factory speakers for a slight bit of rear fill
    - Making my own MDF baffles
    - Will be deadening the front & rear doors first. We'll see what I have left over after that.
    Questions
    1. Am I ok to stick with stock wiring for now?
    2. Any other suggestions?
  2. Aug 28, 2009 at 10:53 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    If you already have it opened up I would go ahead and re-run some good wire. It will make it easier than if you want to do it in the future.
  3. Aug 28, 2009 at 10:56 AM
    BradleyJ33
    BradleyJ33 Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    I agree, if you're going to sound-deaden the doors this weekend, go ahead and run the speaker wires while you have the door broken down. Then all you'll have to do is pop in the new speakers in the rear door, hook up the new wires to all the speakers, and hook the other end to your amps when you get them and you'll be rockin!
  4. Aug 28, 2009 at 11:33 AM
    mceagle555
    VA
    OK...I might just run new wire then. I have a ton of good quality Monoprice 14 AWG speaker wire. Will that work?
    How do I splice that in with the factory harness?
  5. Aug 28, 2009 at 4:52 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    if you plan on adding an amp later and not use the built in amp of the headunit when that happens then i would probraly not add speaker wire until the amp was installed. the only reason i say that cause if you run new speaker wire from headunit to speakers and add an amp later your speaker wire no longer goes where your amp is installed.
  6. Aug 28, 2009 at 8:08 PM
    mceagle555
    VA
    Wise man...
  7. Aug 28, 2009 at 8:51 PM
    stang88
    stang88 Well-Known Member
    invest in a good alarm.
  8. Aug 29, 2009 at 8:03 AM
    BradleyJ33
    Brad
    Brandon, MS
    Yeah, I wouldn't hook up the new speaker wire to the head unit...I would go ahead and route it all to where your amp is going to be, then you're ready to go as soon as you run the power wires and RCAs when you get the new amp...
  9. Aug 29, 2009 at 10:51 AM
    stang88
    onmy metra kit.. the ends that snap into the dash were just a tad too long to use the white clips that come with it.. just shave a very little bit off the ends of the install kit and they snap right on... and hold the kit in good.
