Any locals have done a CAB MOUNT RELOCATION install?
Discussion in 'Ontario, Canada' started by TegoTaco, Jul 26, 2021.
  1. Jul 26, 2021 at 3:06 PM
    TegoTaco
    TegoTaco [OP] Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Don’t have access to a welder or know anyone that does welding. Looking to have a cab mount relocation kit installed, looking to be upgrade to a 34-35” tire around fall. Or a really an aggressive cab mount chop. :) Would prefer someone who had done one successfully. Willing to pay for your service, any help would be greatly appreciated.
  2. Jul 26, 2021 at 4:00 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Is this too aggressive? You can fit 41s no problem :D
    Shveet and TegoTaco[OP] like this.
  3. Jul 26, 2021 at 8:19 PM
    blqchclt
    blqchclt Oh, that's what this is for
    2018 Quicksand DCSB
    Ski from CT Motorsports will likely be the one to go to
  4. Jul 27, 2021 at 7:23 AM
    TegoTaco
    Ontario, Canada
    Is he a member here?
  5. Jul 27, 2021 at 7:48 AM
    blqchclt
    2018 Quicksand DCSB
    He is but he's super busy/less likely to respond on social media because of that, best to give him a call...he can definitely help or point you in the right direction!
  6. Jul 27, 2021 at 8:18 AM
    TegoTaco
    Ontario, Canada
    Just emailed them, hopefully I get an answer. In need of tires soon, so might as well do 35” tires.
  7. Jul 28, 2021 at 2:42 PM
    TegoTaco
    Ontario, Canada
  8. Jul 28, 2021 at 3:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Shveet likes this.
  9. Jul 28, 2021 at 4:00 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I'd recommend the Cab Mount Chop. The cab relocation although seems like good idea? You really gain very little over a good CMC. This is due to the actual Cab mount still remaining in the exact same location. That large metal structure that you are removing is designed to protect you and your passengers from off center frontal impacts. (From your tire coming up into your face)
    With a good CMC you can still maintain most of the design protection. the other limiting factor to achieving tire clearance is the actual cab floor.
    Get a good CMC and a set of adjustable UCA and move your front wheels forward in the wheel well and get a high clearance bumper.
    Just something to consider.
    Good Luck with what ever you decide!
  10. Jul 28, 2021 at 4:19 PM
    TegoTaco
    Ontario, Canada
    I have SPC UCA’s along with a 1” body lift and a CMC. Still rubs, my alignment guy sucked!
  11. Jul 28, 2021 at 4:28 PM
    toku58
    Mall Crawler!
    LOL! Yeah that's something I found most alignment shops don't truly understand how to be creative and use the SPC UCA. We have a specialty shop here that the guy is always tweaking the suspension for Tacoma owners. He's fairly good.
    Don't get me started as to why he needs to tweak their suspension. (14" Wide 24" rims) LMAO!!!
    You can do a CMC that will clear 34-35" tires. It's been done before. I'm ordering a PRO and it's destined to have 34" tire, and I don't plan on doing a lift. (Should be interesting!)
    Good luck with your journey down the rabbit hole! :)
    Shveet likes this.
  12. Aug 4, 2021 at 5:09 AM
    TegoTaco
    Ontario, Canada
  13. Mar 25, 2022 at 11:50 AM
    TegoTaco
    Ontario, Canada
    Haven’t had any luck as of yet…
    anyone??
  14. Mar 25, 2022 at 4:38 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I mean i'm sure people here have done them, but it's also a level of responsibility they would have to take on god-forbid the cab mount fails in some way.
    ¯\_(ツ)_/¯
    at this rate, you're falling into a point of 4 options:
    1) take it to another shop; you had the opportunity to contact CT motorsport, but seems like that was a no-go.
    2) Test your luck with a shop that has never done it before. Check out Sumin Auto
    3) Pick up a welder and learn for yourself. Practice on spare steel before hand but since you plan to go to 34s/ 35s and want to entirely relocate the cab mounts, you might as well learn that way you can make changes yourself.
    4) change your approach to your goal. as buddy above said, you can change your rims and geometry to avoid needing to even do a CMC.
  15. Mar 25, 2022 at 4:45 PM
    TegoTaco
    Ontario, Canada
    1. Never got an email or phone call returned from CT MOTORSPORTS
    2. Many shops have said no to the work.
    3. Yeah, I don’t think so…lol
    4. Not looking to spend more money on a set of wheels when I have the correct spec’d wheels for 35’s.
  16. Mar 25, 2022 at 4:56 PM
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    I’ll take care of you buddy! I can do the cutting, just need my buddy to weld since my father-in-law isn’t able to do it.
    I need to do work on @Shveet truck too. He has a Marlin Crawler LCA kit to go in
    TTOutsider, TegoTaco[OP] and Shveet like this.
  17. Mar 25, 2022 at 5:16 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i wasn't sure if that would go in this year :anonymous:
    work things are moving faster than anticipated for me.
  18. Mar 25, 2022 at 5:17 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Looks like you got someone willing;
  19. Mar 27, 2022 at 3:56 PM
    TegoTaco
    Ontario, Canada
    Let me know!
    :D
  20. Apr 14, 2022 at 12:09 PM
    TegoTaco
    Ontario, Canada
