Any long term damage from larger/heavier tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Garfunkel, Feb 21, 2020.
  1. Feb 21, 2020 at 3:14 PM
    Garfunkel
    Garfunkel [OP] Well-Known Member
    This is gonna be a horrible question for you all but could use some insight. On any truck (mine specifically is the 4cyl 4x4), if you add 285 tires/heavier loads, the loss in mpg and obviously power sucks but is manageable, but are you doing long term damage to your truck by asking the engine and everything to work much harder?
    mgmdclb likes this.
  2. Feb 21, 2020 at 3:19 PM
    Tacospike
    Two Trucks
    Idk, that engine is pretty tested and proven over decades. I’m sure with regular maintenance you should be fine. If you’re not hot rodding around every day you should be good. I’ve had family members run bigger tires since I was a kid on Tacoma’s and they still seem fine to this day. Maintenance, change fluids as specd, you should be good
    mgmdclb and Skydvrr like this.
  3. Feb 21, 2020 at 3:23 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    No but you’ll get passed by a kite on the highway.
  4. Feb 21, 2020 at 3:24 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Regear.
    GillyLink likes this.
  5. Feb 21, 2020 at 3:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's a Toyota pickup ;) Hammer it at redline all day. Just change the oil and fluids at the intervals specified in the maintenance booklet
  6. Feb 21, 2020 at 3:37 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I would assume that extra load is negligible. There are many trucks on TE with hundreds of thousands of miles in good condition with large tires and extra weight. If you have a manual, your clutch may wear out faster because you will need to slip it more to get moving with the extra large tires.
  7. Feb 21, 2020 at 3:56 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    My 22re did 300K with 31" back in the day.. slowly, but it got there..
    GillyLink, specter208 and Paul631 like this.
  8. Feb 21, 2020 at 3:59 PM
    Garfunkel
    Haha regear in the future but gonna have to see if the 4banger can pull the 285s going on soon with OME lift. Thanks guys though for the help
  9. Feb 21, 2020 at 4:04 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Additional wear yes, but not damage. Brake pads/rotors wear faster, power steering pump, steering rack work harder, axles.... I wouldn't say you are causing damage but increasing the wear on some components for sure....
    Chew likes this.
  10. Feb 21, 2020 at 4:08 PM
    Garfunkel
    Now I can get on board with that makes sense, sacrifices I’ll make for the 33s haha
  11. Feb 21, 2020 at 4:13 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Engine longevity totally depends on distance above sea level and severity of steep hills, but the 2TR is a beast so no worries there.
    Larger tires will accelerate wear on brakes, bushings, shocks, steering racks, etc pretty much everything 'chassis'.
  12. Feb 21, 2020 at 4:45 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I had 285/75/16’s on my 2012 for about 140,000 miles. No problems except for one wheel bearing. Still climbed these hills in West Virginia at 70mph.
  13. Feb 21, 2020 at 4:45 PM
    Garfunkel
    4 cylinder though?
  14. Feb 21, 2020 at 4:45 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Just remember your forfeit your right to complain about loss of MPG. No one here wants to hear it and those that do will lie their asses off saying that they're getting the same as stock with 35s and no re gear and 700# of camping gear that's never seen any travel outside the Amazon package it came it.
    mallege and GreyBaldTaco like this.
  15. Feb 21, 2020 at 4:46 PM
    tomwilson74
    Tom
    West Virginia
    4.0
  16. Feb 21, 2020 at 4:47 PM
    Garfunkel
    Haha I can suck up the mpg and power loss, I just really don't want to have to get towed on a highway climb or be forced to go 40 on it
  17. Feb 21, 2020 at 4:47 PM
    Garfunkel
    Very nice I like hearing that, actually going to snowshoe with the setup soon so can test out that hilly drive
  18. Feb 21, 2020 at 4:50 PM
    tomwilson74
    Tom
    West Virginia
    I would easily cruise up Sandstone Mountain on I-64 at 70. (7% grade). I don’t like to speed but I could have did more than 70.
    Garfunkel[QUOTED][OP] likes this.
  19. Feb 21, 2020 at 4:51 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    How in the hell can you guys think that a heavier load would not increase wear? Of course it wiil OP.
    You will be continuously asking for more power output out of the engine than you will with stock tires. This is a given.
    Let's say that engine produces X power output per hour, on average today. When you add larger tires the power output will now go to X plus Y, with Y equalling the additional power required to drive those larger tires. Your engine and all related components will decrease their life.
    Now, realistically does that mean 10,000 less miles over the life of the truck? Or 5,000? Or 20,000? Nobody can say for sure but I can damn sure tell you it will have less life than stock tires. This is simple physics man. Engines don't heal themselves, chains and pumps wear, there will be accelerated heating, etc.
    Speedbird and jmneill like this.
  20. Feb 21, 2020 at 4:54 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Please stop making sense, you're starting to stand out like a sore thumb around here..
    hiPSI[QUOTED] likes this.
