Any manual t/cases in 2nd Gens in the GTA?
Discussion in 'Ontario, Canada' started by JAGCanada, Feb 27, 2023.
  1. Feb 27, 2023 at 7:43 PM
    JAGCanada
    JAGCanada [OP] Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Seriously considering installing a 4runner manual transfer case in my 2010 TRD Sport. My existing t/case has some mechanical issues internally that prevent use of 2Lo....
    Before I cut a hole in my floor and shifter console, would really like to see a 2nd gen truck in person that has a manual t/case... add bonus would be with ADD delete.
    If you are in the GTA and have a manual t/case in your 2nd gen I'd really appreciate being able to see it in person. I've read a lot about it and seen videos /pictures, but I'd like to see one first hand and talk to someone who has one installed.
    Let me know.
    Thanks
    Windigo and drewskie like this.
  2. Feb 27, 2023 at 8:15 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    @tacoma16 @Windigo can help, but that’s easy, just cut a hole… i chopped entire front lower frame pivots to weld JD kit without ever seeing anyone, first truck in Eastern Canada, have some sense of adventure! :anonymous:
  3. Feb 28, 2023 at 5:22 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Yup. Did the fj t case a while back.
    tried to document everything here.
    https://www.tacomaworld.com/threads/flatbed-35’s-and-mainly-parked-for-repairs.202916/page-35#post-22436149
    Overall it is pretty straight forward to get in and working. The nitty gritty stuff like sealing the floor and making the sticks look good takes some tkme. Mind you, if you are just slapping it in and wanting a single stick then it’s much easier to make it all fit.
    Edit:
    also I have the add delete. All in my build. Lots of info on here about how to do it. Wild recommend getting a diff with the front diff tube from the wrecker versus the dealer. Cheaper.
    ontarioyota and Norilsk like this.
  4. Mar 1, 2023 at 3:46 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I'm in Toronto if you want to see one. Message me and we can grab a coffee too. Cheers.
    tacoma16 likes this.
