Any manual transmission towing reviews out there?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Dec 26, 2015.
  1. Dec 26, 2015 at 10:42 AM
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Anyone with a 2016 manual towed with their Tacoma? Looked for a review but could not find one. Curious on how it pulls vs the auto. I have heard the rear end is different on the manual. I have tested both transmissions and the manual does indeed seem more torquey, especially off the line. I am sure it tows a 4 wheeler just fine. Really wanting to know how it pulls ~3000 lbs up grades. Thanks.
  2. Dec 28, 2015 at 7:15 AM
    IKYR
    IKYR Member
    2016 DCSB OR MT
    Hi TacoJonn- your question inspired me to join TW, I've been reading and learning since getting my truck, and it's time to give back.
    I towed a 4 x 8 U-Haul from Billings back to the Colorado Front Range last month, the U-Haul weighed 850 lbs., so I figure the load was 2000+ lbs. The truck handled beautifully, and with the trailer I was able to maintain a good pace on I-90 and I-25. I found for the most part that 5th gear would get me up the long grades, with occasional forays into 4th gear. This engine has a lot to give when you hit the 3000 and 4000 RPM mark, and being able to find that range with the MT is awesome. I did use 3rd once or twice, having more to do with navigating with the other drivers and not the contours of the highway. I had about 1000 miles on my truck when I got up to Billings, so I was still learning the way this engine and tranny interfaced and worked together, having driven MT Subaru's for the past 20 years.
    One other note, I was using Ethanol-free Premium gas for much of the drive. I topped off in Casper on the way up, maybe half a tank, then filled up in Billings, topped up in Sheridan and Casper on the way down. When I first added it I could feel a small difference in performance, but I figured since I was towing, and finishing the engine break-in on this trip, that using the better grade fuel would be worthwhile. I cannot say in absolute terms how much of a difference it made.
    I hope this info is helpful to you.
    TacoJonn[OP] and nevadabugle like this.
  3. Dec 28, 2015 at 9:19 AM
    TacoJonn
    Jon
    Laramie, Wyoming
    Thanks for the review! I live in Cheyenne and am frequently all up and down the front range and even in Casper sometimes. I would be pulling my trailer to Moab Utah on I70 a couple of times a year I imagine. Seems to manual seems to be the stronger option if that 2 mpg is not a concern.
  4. Dec 28, 2015 at 11:01 AM
    IKYR
    IKYR Member
    2016 DCSB OR MT
    I'm glad my story was useful. Given the reviews I've read of the automatic here, I'd say the manual would be better for the trek over I-70. I would also say that if you were doing this and other trips more regularly, you'd want to think about a bigger truck. But the '16 is a sweet ride.
  5. Dec 28, 2015 at 11:04 AM
    TacoJonn
    Jon
    Laramie, Wyoming
    Yeah that is my dilema. I would probably not tow more than 10x per year. I like everyday drivability of a mid-size pickup, but a V8 would be nice going over passes. Then again I am never in a hurry when I drive. I just want an engine to be reliable in a way that towing won't affect it's overall lifespan. Got any more pics of your truck? If so post here. I really like that topper.
  6. Jan 28, 2016 at 11:47 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    On a related note for my MT bruthas-do you guys find going from 2nd to 3rd gear a bit un-precise/ or for lack of better term un-snyched... every other gear has smooth and accurate shift engagements.
    I drove a car once like that but it was only when going into Reverse, so I just double pumped the clutch to remesh/sync and it went in smooth.
