Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Aug 13, 2018 at 1:37 PM
    #3381
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    :thumbsup: It's a pretty cheap upgrade. @MatthewMay1 helped me work my way through deciding what to get. He recommended going minimal, but something with RF gain. I wanted something small, so I went with a Uniden Pro 520XL and am very happy with it. I opted to buy my own SWM meter so I could get the antenna tuned properly.
    I got mine through RightChannelRadios, good guys, but be careful what you order. Their add-a-circuit fuse kit has the huge fuses and will not work on a Tacoma, best to just hit your local auto parts store and get one that fits. And the FireRing cables no longer come with the bolt that you need, so you'll have to pick one up from the hardware store if you use that kind of cable.
    And thanks for your tip on the breather relo, worked great behind the left tail light!
  2. Aug 13, 2018 at 2:13 PM
    #3382
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    @TenBeers That does look like a neat little radio. I'll have to figure out where I want to mount the antenna. Probably could affix it to my ditch light bracket easy enough.
  3. Aug 13, 2018 at 2:17 PM
    #3383
    beanulous128
    beanulous128 Well-Known Member
    zach
    Yellville
    2012 TRD Sport DCSB
    How do you like this set up?
  4. Aug 13, 2018 at 2:44 PM
    #3384
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    That's the one. Ride is improved over stock, for sure, but with AAL truck definitely rides stiffer now. I like it, I haven't tested it offroad yet, but on road is good after about 1000 miles.
    I bought this https://www.amazon.com/gp/product/B000X3EQ3G/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    I mounted passenger side tailgate top between tail light and tailgate and ran wire behind tail light down through frame and up through rubber grommet under cab. That mount is really versatile, and I needed it to clear my RTT. I added a 4' firestik firefly and is working good so far tuned in to about 1.5. Dave's is mounted in a similar location, but he has a 5' firestik we tuned yesterday and it metered in barely over 1. There was a thread on here using same bracket and install but I can't find it.
  5. Aug 13, 2018 at 3:12 PM
    #3385
    Dave_M
    Dave_M Well-Known Member
    Dave
    OR
    02 Tacoma
    My firestik is 4’, mounted in the sample spot as Chip’s but on the driver’s side. I had a lot of issues with a 3’ firefly/cheap coax cable, but since I upgraded the cable and went with the 4’ firestik it’s been great. Even with a soft topper frame there to interfere with things.
    Speaking of soft toppers! Anybody interested in a well used, but functional one? Tan in color. For first gen, long bed.
  6. Aug 13, 2018 at 5:07 PM
    #3386
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Heading to our cabin at Okemah, OK this weekend if anybody wants to ATFB :cool:. 4 hrs one way...
    BYOB and Ammo :infantry:
    Pistol Pete likes this.
  7. Aug 14, 2018 at 4:00 AM
    #3387
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Same bracket as I used on the driver side, but I did have to put it in a vise and give it a slight bend so it wouldn't rub the tailgate. I just ran the wire through the gap between tailgate and bed side and down through a hole I drilled in the bed. Also ran an additional ground wire down to a bolt on the frame. The 18' Firestik cable made it far enough to install the radio under the left side of the dash, but not enough length to do a console install. With a DCLB, it will be tight. If you already have ditch lights, though, going with a 9' cable should be plenty. I highly recommend the FireRing cable to avoid a big cable loop (and might be necessary for clearance at the ditch light location), but like I said, you gotta supply your own bolt. My 4' tuned in to about 1.3 - 1.4.
    [​IMG]20180420_172506 by MrTenBeers, on Flickr
    [​IMG]20180420_172251 by MrTenBeers, on Flickr
  8. Aug 14, 2018 at 6:19 AM
    #3388
    CRASHMAN50
    AA-ron
    Arkansas
    Dave, does that antenna location interfere with the opening of the back of your softopper any?
  9. Aug 14, 2018 at 7:31 AM
    #3389
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I mounted my antenna with the 90º adjustable hood hinge mount in the tailgate jam. 102" whip antenna tied down above the rear door. Really wish my radio had adjustable RF gain, because I get a lot of interference with that antenna sometimes. I think it receives too well for the radio I have.
  10. Aug 14, 2018 at 8:32 AM
    #3390
    Dave_M
    Dave
    OR
    02 Tacoma
    It doesn't block access to anything, but you will be reaching around it to open/close the softopper. Here's the only photo I have on hand with a decent angle so you can see what I mean. I can get a close up later today if you want. I've never thought of it as an issue.
    PinnaclePete likes this.
  11. Aug 16, 2018 at 7:38 AM
    #3391
    PinnaclePete
    Pete
    Central AR
    Picking up a new toy this weekend for the cabin...Kubota L3901 with bush hog, blade and front bucket :thumbsup:
    MatthewMay1, Pistol Pete and Dave_M like this.
  12. Aug 16, 2018 at 7:48 AM
    #3392
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    If you need somewhere to store that I may know a place...
    :devil:
  13. Aug 16, 2018 at 7:50 AM
    #3393
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    I was gonna say dibs on storage, but beat me to it!
  14. Aug 16, 2018 at 7:55 AM
    #3394
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Man, beer drinking, gun shooting, tractor driving? May have to take you up on that next invite to the cabin.
  15. Aug 16, 2018 at 7:56 AM
    #3395
    PinnaclePete
    Pete
    Central AR
    It'll fit just fine in my barn...in Okemah...in Oklahoma...where I'll be getting some bush hog therapy :cheers:
    Dave_M and TerraNerva[QUOTED] like this.
  16. Aug 16, 2018 at 7:57 AM
    #3396
    PinnaclePete
    Pete
    Central AR
    :boink:
  17. Aug 16, 2018 at 8:05 AM
    #3397
    CRASHMAN50
    AA-ron
    Arkansas
    Ah, Okemah. Still got those hot and cold water towers?
  18. Aug 16, 2018 at 9:28 AM
    #3398
    Dave_M
    Dave
    OR
    02 Tacoma
    Pete’s tractor is definitely cooler, but I’m bringing some new gear home today too!
  19. Aug 16, 2018 at 10:03 AM
    #3399
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Uh oh somebody is joining the RTT club. Who's next?
  20. Aug 16, 2018 at 5:38 PM
    #3400
    PinnaclePete
    Pete
    Central AR
    Waiting on colder weather...
