Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Sep 7, 2018 at 11:34 AM
    #3581
    Dave_M
    Dave_M Well-Known Member
    Dave
    OR
    02 Tacoma
    I wouldn’t expect you to be able to observe any ill effects without having an oil analysis done. The concern is that moisture being introduced would lessen the ability of the oil to do it’s job in the same way that oil with 30k miles on it won’t protect as well as oil with 5k on it. Any failure would likely present itself as a normal wear failure. It would be unlikely that anyone would ever equate it to moisture in the lubricant. With routine maintenance at a higher frequency, this isn’t a concern at all.
    Axle seals will never be designed as the weak point in the sealing of the rear end. The vent would be made to let air in before a pressure difference high enough to collapse a seal occurs if everything is operating correctly. There are so many variables here that can effect this though. Especially on 20 year old vehicles, and determining a root cause for a failure in that case would be nearly impossible.
    The point of all of this is really just that if you have an open vent, you might want to consider increasing your maintenance frequency.
  2. Sep 7, 2018 at 12:00 PM
    #3582
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    The TenBeers Breather Balloon Bellow! You might be onto something. TW folks would buy it.
  3. Sep 7, 2018 at 12:08 PM
    #3583
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    roguegs likes this.
  4. Sep 7, 2018 at 1:07 PM
    #3584
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    You are not the target market. I would post in the 3rd gen section.
    Set of 2 Diff Breather Balloons - $19.97 + $14.32 Shipping and Handling
    Quality differential air is an often overlooked item when maintaining top vehicle performance. Don't let your diff air escape or be contaminated, regardless of where you drive! These quality Diff Breather Balloons will keep your sealed system sealed and extend the service life of your differential fluid. Also effective in containing environment-harming fluids in the case of a rollover. No re-routing needed, just attach over existing breather and drive! Share with a friend!
  5. Sep 7, 2018 at 1:12 PM
    #3585
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    Lol, sounds like a salesman....
  6. Sep 7, 2018 at 1:13 PM
    #3586
    PinnaclePete
    Pete
    Central AR
  7. Sep 7, 2018 at 1:15 PM
    #3587
    PinnaclePete
    Pete
    Central AR
    I double dog dare ya... :rofl::rofl::rofl:
  8. Sep 7, 2018 at 1:16 PM
    #3588
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    No, but I've known a few. I sold shoes at a mall Thom McAnn when in HS, and I knew then I would not go into sales.
  9. Sep 7, 2018 at 1:17 PM
    #3589
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    That might get me in trouble with the TW gods.
  10. Sep 7, 2018 at 1:18 PM
    #3590
    PinnaclePete
    Pete
    Central AR
  11. Sep 7, 2018 at 1:23 PM
    #3591
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    LOL, just read the rules and I would need to be a vendor or have a photo of the actual item. But I may do it after a beer or 2 later anyway.
    BTW, these Nike posts are getting deleted as political . . .
  12. Sep 7, 2018 at 1:27 PM
    #3592
    PinnaclePete
    Pete
    Central AR
    Just put it in the 3rd Gen BST...watch the responses as you :cheers:
  13. Sep 7, 2018 at 1:31 PM
    #3593
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
  14. Sep 7, 2018 at 3:46 PM
    #3594
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Diff breather plot thickens . . .
    So, I ran my own tests with the recommended Toyota part from all the mod threads as well as the original breather I removed:
    Mod Breather (supposedly an OEM Toyota part): Just an open fitting with a crimped cap. Took the crimped cap off and it's just an open tube. No valve mechanism at all. Maybe I got a fake one? Suggest going to a dealer, not ordering the "genuine" part off of Amazon.
    Original Breather: Requires a bit of pressure buildup to let air OUT. Blowing lightly it is closed, but then pops open with more pressure. Does not let air IN at all. At least not using my test method, and I am too new to this town to know where to find someone that can improve on my oral test method.
    So....interesting. Using the recommended mod part would likely be worse than the filtered breather I put on there. I could clamp the original breather on there, but it doesn't seem to account for ANY vacuum, possibly allowing water to get pulled in through axle seals.
    What to do?
  15. Sep 7, 2018 at 4:27 PM
    #3595
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    OK, 3rd gen marketplace is loaded. :D
    PinnaclePete likes this.
  16. Sep 7, 2018 at 4:36 PM
    #3596
    G.T.
    G.T.
    CONUS
    Who am I going to be looking for at Rendezvous in October?
  17. Sep 7, 2018 at 4:41 PM
    #3597
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Hey, @G.T. hope you are feeling better (still lurking in both the STL thread and here, sorry I moved before joining you for a mod day). @PinnaclePete for sure, I'm a possibility if my folks decide to leave in time.
    PinnaclePete and G.T.[QUOTED] like this.
  18. Sep 7, 2018 at 5:13 PM
    #3598
    PinnaclePete
    Pete
    Central AR
    88F514C4-F527-44AF-A1F1-7AD2EC1A4EFF.jpg FC31D033-33BC-4785-BE23-3D0F25232E54.jpg
    :thumbsup: :cheers: :wave:
    Flipac still for sale? It would be great on my truck, but...
  19. Sep 7, 2018 at 5:31 PM
    #3599
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
  20. Sep 7, 2018 at 6:41 PM
    #3600
    PinnaclePete
    Pete
    Central AR
