Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Jun 23, 2021 at 1:21 PM
    #7481
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    You talking about something like this?: https://www.amazon.com/Voswitch-Programmable-Control-Wrangler-Gladiator/dp/B07VVN9T4X
    If so, the box with all the relays and fuses under the hood basically makes up a wiring harness for each accessory. Those fuses in the box under the hood will be between the positive of the battery and each relay. Those are essentially fuse blocks with relays, but it has the advantage of a nice switch panel with one cable to run through the firewall instead of a cobwebbed mess of switch wires. There shouldn't be a need to put a circuit breaker for the entire box, though. As long as each accessory's fuse is appropriately sized, you'd be fine.
    If that's not what you have or talking about, then I may be speaking way out of turn. ;):oops:
    CS_AR, Bat Trd[QUOTED] and CygnusX191 like this.
  2. Jun 23, 2021 at 2:28 PM
    #7482
    Bat Trd
    Bat Trd Friendly Neighborhood Batman
    Layne
    Hot Springs, Arkansas
    2014 Tacoma TRDOR DCSB 1D6
    Bruce Wayne taste on an Alfred budget.
    Its more as a protection for my battery. If anything were to cause the box itself to short there would be nothing between the battery and box. Perhaps I should rephrase my question; what amperage of circuit breaker would be adequate for a voswitch box that is used for controlling a winch or other high load accessory?
    I may be overthinking this...
    CS_AR, CRASHMAN50 and CygnusX191 like this.
  3. Jun 24, 2021 at 5:53 AM
    #7483
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Picked Chip up on the radio this morning from about 6 miles out. I had my 6db ant. and he had his Ghost 3db. It was a little scratchy at first but cleared up at about 5 miles. Guess I'll have to work on getting on the Saline repeater.
    TerraNerva, E.J., Bat Trd and 3 others like this.
  4. Jun 24, 2021 at 6:15 AM
    #7484
    CRASHMAN50
    AA-ron
    Arkansas
    I gotcha. Certainly, without there being a manual circuit breaker between the box and the battery, accessories could be left on by accident and drain your battery. Obviously, it's less of an issue if you were to go dual battery or something like that as all accessories could be dedicated to the "house" battery. However, the box is rated for 100 amps total and 30 amps per accessory. That's plenty to run lightbars, tire inflators, a fridge, disco balls, and so on. But, that isn't sufficient for the high-amp load a winch uses. I would wire the winch on its own using high quality/high amp rated materials and use a marine-grade disconnect like this one:
    https://www.amazon.com/Blue-Sea-Sys...24539375&sprefix=blue+seas+dis,aps,174&sr=8-5
    You'll want to ensure that the rated amperage for the disconnect switch is more than the max amp draw of the winch, just to be safe. For reference, max amp draw on a Warn M8000 is something like 435 amps, and the manual HD blue seas switches are 500 or 600 amps. And you could use one of these switches to manually cut power to the voswitch box if you really wanted to, but the danger is leaving accessories on without the truck running. Obviously, draining a non-deep cycle battery frequently will shorten its service life significantly.
    Any real danger would be potential shorts in the wiring/accessories, and that would be stopped with the appropriately-sized fuses within the box.
    I have a little experience with 12v, but I don't have a winch installed; so, you know, grain of salt and all that.. ;)
    Hope that helps though.
    CygnusX191, CS_AR and Bat Trd[QUOTED] like this.
  5. Jun 24, 2021 at 7:07 AM
    #7485
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Your winch should be wired straight to the battery, that votswitch box only handles 100amps...a typical 9500 pound winch can draw up to 500 amps if it's pulling hard.
    CygnusX191 likes this.
  6. Jun 24, 2021 at 7:15 AM
    #7486
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Solid advice from AA-ron here. I definitely would NOT try to run a winch through anything except what they supply it with and keep it separated from everything else.
  7. Jun 24, 2021 at 7:18 AM
    #7487
    E.J.
    Josh
    NWA
  8. Jun 24, 2021 at 7:58 AM
    #7488
    Bat Trd
    Layne
    :anonymous: I'm dumb lol. Of course the winch wouldn't be powered from the box. But I can run the controller through it.
    This is what I get for planning so far ahead even though I don't have anything to install. I find myself down the rabbit hole of preparation. Thanks for the advice, guys.
  9. Jun 24, 2021 at 9:12 AM
    #7489
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Shouldn't the controller be tied directly to the winch and not run through the box?
    Bat Trd[QUOTED] likes this.
  10. Jun 24, 2021 at 9:32 AM
    #7490
    Bat Trd
    Layne
    I've seen people use theses momentary programmable switch panels for interior winch control. I'm sure that there was some cutting and splicing to make it work. I'm confident that I can figure out how to maintain the use of standard style controller as well as being able to control it from the drivers seat with the voswitch. I would assume that I could use the winch plug end off of a controller to cut and wire to the box. I would also have an extra controller for exterior use.
    Keep in mind, I have never had nor wired a winch before, so there may be something that I'm not aware of that would prevent me from being able to do this as I would like.
  11. Jun 24, 2021 at 10:00 AM
    #7491
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Get a wireless winch controller? Might be your ticket.
    Bat Trd[QUOTED] and TerraNerva like this.
  12. Jun 24, 2021 at 10:00 AM
    #7492
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    Your best bet is to isolate the winch by using a switch as Aaron suggested, but it needs to be a min of 600A, but double check how many amps your (new) winch pulls before, and exceed that with plenty of buffer. Pete just installed one of those fancy switch boxes, but you could relay a momentary switch for in and out. Most winches have wireless controllers, so may be a dollar waiting on a dime.
    Edit: Dave convinced me some time ago that a winch switch between the battery and winch was a good idea. Those are AWG4, and a short would cause a fire and ruin your day pretty quick.
    CygnusX191 and Bat Trd like this.
  13. Jun 24, 2021 at 10:21 AM
    #7493
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    They're is most definitely a reason to run something as a breaker on winch leads. I don't but I've had a wireless remote short out on my winch causing it to run. Had it not been in free spool it likely would have cooked the battery. I'm pretty sure there is something on the market for this purpose other than a manual disconnect switch. I just always leave mine in free spool.
    CRASHMAN50, CygnusX191 and TerraNerva like this.
  14. Jun 24, 2021 at 11:10 AM
    #7494
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I'm a noob. I know nothing about radio or antenna. I did some basic reading. But couldn't find an answer. I have a Midland mxt275 with the stock antenna mount on top of the roof. If I get a 6db antenna and mount it on the truck bed. The top of the two antenna now is about the same height. Would the two antenna have the same transmitting/receiving power or performance (or what ever the term is)?
    Sorry for the long post and thanks in advance for helping.
  15. Jun 24, 2021 at 11:35 AM
    #7495
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Pretty sure the antenna transmits from the coil, which on the 6dB is in the middle of the antenna. That would put the transmission point a bit lower, but I am not sure where your current coil sits, and I could be wrong in my assumption. If you are using a 3dB now, it is probably a wash.
  16. Jun 24, 2021 at 11:48 AM
    #7496
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    Your 6db should out perform the little stock antenna regardless of where you put it, but it will work better when it has a plane to reflect off of, like your roof.
  17. Jun 24, 2021 at 12:03 PM
    #7497
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    The coil of the 6db is in the middle of the upper half of the rear window (approximately) and the coil is lower then the stock antenna. The stock antenna has no coil, it's about 2db. I'm just trying to understand how antenna work base in mounting height, antenna height, db gain, etc. I haven't purchase the 6db antenna yet. At the moment I'm trying to learn more before upgrading. I'm trying to find out if the stock 2db mounting on top of the roof would be the same as the 6db mounting on the bed basing on the information of the higher the antenna sit the better it is.
  18. Jun 24, 2021 at 12:07 PM
    #7498
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Even if it's lower then the stock 2db? So higher db antenna will out perform a smaller antenna even if its mount at a lower location.
  19. Jun 24, 2021 at 12:20 PM
    #7499
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    A 2db basically has zero gain and radiates evenly in all directions, so yes, theoretically a 6 db will out perform a 2db in receiving and transmitting regardless of location on the vehicle. A 3db vs a 2db, not so much.
    CS_AR and CygnusX191 like this.
  20. Jun 24, 2021 at 12:24 PM
    #7500
    E.J.
    Josh
    NWA
    That is a very long antenna.
