Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Dec 13, 2021 at 6:08 AM
    #8101
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Anyone here have a male standard poodle to stud out? I’d like to breed my trail buddy before she gets too old.
    CygnusX191 likes this.
  2. Dec 13, 2021 at 8:54 AM
    #8102
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    I have some friends that own an AKC kennel that have a male standard stud. PM me if you want info. They are in LR.
  3. Dec 14, 2021 at 8:02 AM
    #8103
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    2013 Tacoma 4x4 2017 4Runner TRD Pro
    SCS BR6/ Bilstein 6112/5160/ BajaDesigns Squadron Sport Fog Lights/ BajaDesigns Squadron Pro Ditch Lights/ BajaDesigns S1 Flush Mount Reverse Light/ 32" Light Bar/ Rago Fab Ditch Light Brackets/ CaliRaised Lower Bumper Light Bar Brackets/ BPF Tow hook/ BPF TRD Skid Plate/ Bora 3/4in Wheel Spacers/ Icon 3 Leaf AAL/ BAMF HD Shackles/ TRD Pro Grill/ OEM Roof Rack/ OEM Bed Mat/ Nitto Trail Grapplers/ Every Bulb LED
  4. Dec 14, 2021 at 8:12 AM
    #8104
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
  5. Dec 14, 2021 at 8:16 AM
    #8105
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    Thanks guys!!
  6. Dec 15, 2021 at 4:51 PM
    #8106
    PinnaclePete
    Pete
    Central AR
    Happy Holidays, Merry Christmas…etc.
    buyobuyo, Ozarklander, CS_AR and 2 others like this.
  7. Dec 15, 2021 at 7:55 PM
    #8107
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    @CS_AR Are you gonna be at the Rigs & Coffee meet this weekend?
    CygnusX191 and CS_AR like this.
  8. Dec 15, 2021 at 8:00 PM
    #8108
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I will be there briefly in the Tacoma to drop off some 4Runner seats and a console for Justin Pitman. The LX470 is down for some work.
    I'll get stuck if I try to go out the 2WD Taco.. LOL
  9. Dec 15, 2021 at 8:13 PM
    #8109
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    Ah ok, what’s getting done to the LX?
    CygnusX191 and CS_AR[QUOTED] like this.
  10. Dec 16, 2021 at 2:23 AM
    #8110
    CS_AR
    The radiator fan pulley bearing (and bracket) needs to be replaced. The bearing makes a whining noise and has become hard to turn. The fan pulley bracket shouldn't be a bad job. Though made harder than necessary compared to the two-piece fan shroud design used by Tacoma/Tundra/Sequoia.
    Fan Pulley Bearing and Assembly
    upload_2021-12-16_5-20-38.jpg'
    Then the transfer case rear seal started leaking gear oil. Someone on IH8MUD suggested using AT-205 to condition the seal. The slowed the leak to about 50%.
    So I will need to pull the transfer case rear extension, take it apart, maybe install new bearings. The front bearings are dry as a bone.
    Transfer Case Rear Seal Leak
    It needs valve cover gaskets and for me to pull the intake manifold to reseal it. People usually replace the starter when they have the intake manifold removed. I may decide to do that along with the other maintenance items.
    That's a bigger job than replacing valve covers on a Tacoma. I'm thinking about whether I should go "Full Taco" on the valve covers and intake job or just do a regular job.
    If I go "Full Taco" as I did on the 99 Tacoma, it will be hard to take it off-road again.
    HDMOTT[QUOTED] and CygnusX191 like this.
  11. Dec 16, 2021 at 2:26 AM
    #8111
    CS_AR
  12. Dec 16, 2021 at 5:45 AM
    #8112
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    Sounds like a job for Greg at Four C
    CS_AR[QUOTED] and CygnusX191 like this.
  13. Dec 16, 2021 at 6:14 AM
    #8113
    CS_AR
    I should farm out the t-case job.
  14. Dec 16, 2021 at 2:39 PM
    #8114
    CS_AR
    Local item. I received an order for these LIVSN pants. Some type of new high-tech material. These things are way comfortable.
    Ozarklander and CygnusX191 like this.
  15. Dec 17, 2021 at 8:45 AM
    #8115
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Made in Vietnam but locally designed. How are they compared to Duluth dry on the fly, Carhartt, Dickies, etc?
  16. Dec 17, 2021 at 8:55 AM
    #8116
    CS_AR
    I only know about Carhartt and Dickies. These are very well made and comfortable. So comfortable that I could sleep in them.
    https://youtu.be/OxzdPvdrRto
  17. Dec 17, 2021 at 1:06 PM
    #8117
    CS_AR
    I understand https://www.moosejaw.com/ Moosejaw in Bentonville has the caramel and brown colors so people from NWA can check the product in a store.
  18. Dec 17, 2021 at 1:44 PM
    #8118
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Holy crap, I had no idea they opened a store here.
  19. Dec 17, 2021 at 2:34 PM
    #8119
    PinnaclePete
    Pete
    Central AR
    Just south of the Square. We walked through last week end, mainly to stay warm, lots of cool stuff.
    CS_AR and CygnusX191 like this.
  20. Dec 20, 2021 at 6:40 AM
    #8120
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    Welp, time for a new one :rofl:
    CygnusX191, PinnaclePete and CS_AR like this.
