Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. May 14, 2022 at 7:08 AM
    #8641
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    They were already located in St Louis They just have a much larger facility to accommodate growing demand. I have several friends who work for them in various capacities and by all accounts it's a fantastic company to work for, in addition to the fantastic lighting products.
    I run their 30-in light bar and it's definitely cheaper than competitors bars with equal if not greater output but 100% more defined being pattern. You can also swap out lenses and stuff to get different configurations for fairly cheap. I put two wide pattern amber lenses on the outside and left the three centrals for spot pattern with white slash clear. It's a killer light bar out on the trails at night.
    CS_AR likes this.
  2. May 14, 2022 at 9:50 AM
    #8642
    Cards3
    Cards3 Well-Known Member
    Jake
    Northwest Arkansas
    2011 DC Tacoma TRD offroad
    Stock
    I found a leak the other day leaking between transmission and motor out of that plastic piece thinking it's the rear main seal but my oil level is still full. Could the transmission leak from there as well ?There is no way to check the fluid level of my transmission20220513_101614.jpg
    CygnusX191 likes this.
  3. May 14, 2022 at 11:49 AM
    #8643
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Any attempt to reach out to Hot Springs ORV Park for any day passes or shirts, etc??? Just an idea.
    CS_AR and CygnusX191 like this.
  4. May 14, 2022 at 2:09 PM
    #8644
    Ozarklander
    Ozarklander Well-Known Member
    2018 quicksand dclb
    Is the fluid red? If so, definitely transmission.
  5. May 14, 2022 at 3:10 PM
    #8645
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    That's a great idea!
  6. May 14, 2022 at 4:58 PM
    #8646
    Cards3
    Jake
    Northwest Arkansas
    Stock
    Honestly I can't tell. Called Toyota dealership they said most likely rear main seal and $1100 to fix it. Usually I do all my own work on my truck but I really don't want to tackle this job
    CygnusX191 and CS_AR like this.
  7. May 14, 2022 at 8:26 PM
    #8647
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Oof
  8. May 15, 2022 at 6:04 AM
    #8648
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Rear main is likely. Is yours a manual or automatic transmission? How many miles? If it's an automatic, I'd just keep an eye on it. An occasional drip probably isn't going to hurt anything. If it's a manual, I'd do it whenever replacing the clutch. You can try something like Bar's or Blue Devil in the meantime.
    CRASHMAN50, CygnusX191 and CS_AR like this.
  9. May 15, 2022 at 6:22 AM
    #8649
    Cards3
    Jake
    Northwest Arkansas
    Stock
    It's an automatic with 149,000 miles. Not seeing any drips on the ground must be a slow leak I will just keep an eye on it. Wish there was a way to check transmission fluid level though
  10. May 15, 2022 at 10:18 AM
    #8650
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Open the fill plug while parked on flat ground. The fluid should be about 1 mm lower than the lip.
  11. May 15, 2022 at 2:44 PM
    #8651
    Cards3
    Jake
    Northwest Arkansas
    Stock
    Thanks I will have to check that
    CS_AR and CygnusX191[QUOTED] like this.
  12. May 15, 2022 at 3:08 PM
    #8652
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Def would prefer a dip stick, but welcome to 2022 lol
    CS_AR likes this.
  13. May 15, 2022 at 3:14 PM
    #8653
    Cards3
    Jake
    Northwest Arkansas
    Stock
    Yeah I know back a few years ago when I bought this truck I went to check the transmission fluid and couldn't find a dip stick and was totally confused when I couldn't find one. Every vehicle I had owned before I could check the transmission fluid. Still don't understand why they would design a vehicle where you can't check fluid levels
  14. May 15, 2022 at 3:17 PM
    #8654
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I guess every manufacturer gave up on trusting the owners would do any kind of maintenance
    CS_AR likes this.
  15. May 15, 2022 at 4:55 PM
    #8655
    Cards3
    Jake
    Northwest Arkansas
    Stock
    Yeah I guess so
    CygnusX191[QUOTED] likes this.
  16. May 15, 2022 at 6:02 PM
    #8656
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Had a friend who was a tech tell me that there were too many shade tree mechanics that didn't understand how to use the dip stick properly (operating temp, cycling through gears, ect.) and were overfilling. Manufacturers were catching bad raps from other people's errors so they just stopped putting them in. I really wish mine still had them. I didn't exactly use an IR thermometer on mine but I know not to check them cold.
    CygnusX191[QUOTED] and CS_AR like this.
  17. May 15, 2022 at 6:08 PM
    #8657
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Are you still looking for info or contact person? I may have a POC for you.
  18. May 15, 2022 at 6:12 PM
    #8658
    CS_AR
    That will be great. I'm waiting for the weekend to end before contacting them.
    Skootter14 and CygnusX191 like this.
  19. May 15, 2022 at 6:19 PM
    #8659
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    OK, I know one of the trail guides there and will see if I can get ahold of him tonight. I think they had a busy weekend.
  20. May 15, 2022 at 6:23 PM
    #8660
    CS_AR
    I appreciate the lead. Just PM me with any contact information.
