Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Jul 19, 2022 at 4:06 PM
    #8821
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Did anyone else get an email from “OwnerCS” regarding verification of email for the Tacoma event???
    CygnusX191 likes this.
  2. Jul 19, 2022 at 6:10 PM
    #8822
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Welcome welcome.
    I did not.
    CygnusX191 and Buddy08[QUOTED] like this.
  3. Jul 19, 2022 at 7:15 PM
    #8823
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    2013 Tacoma 4x4 2017 4Runner TRD Pro
    SCS BR6/ Bilstein 6112/5160/ BajaDesigns Squadron Sport Fog Lights/ BajaDesigns Squadron Pro Ditch Lights/ BajaDesigns S1 Flush Mount Reverse Light/ 32" Light Bar/ Rago Fab Ditch Light Brackets/ CaliRaised Lower Bumper Light Bar Brackets/ BPF Tow hook/ BPF TRD Skid Plate/ Bora 3/4in Wheel Spacers/ Icon 3 Leaf AAL/ BAMF HD Shackles/ TRD Pro Grill/ OEM Roof Rack/ OEM Bed Mat/ Nitto Trail Grapplers/ Every Bulb LED
    I did not either.
  4. Jul 19, 2022 at 7:22 PM
    #8824
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    IMG_20220719_155510507.jpg IMG_20220719_155918158_HDR.jpg IMG_20220719_182545972_HDR.jpg
    Wyoming photo dump, a little out of order. Went to Devil's Tower today and a little bit of Bighorn forest exploring. Camping at a brewery in Ten Sleep tonight.
  5. Jul 19, 2022 at 7:26 PM
    #8825
    E.J.
    Josh
    NWA
    Yeah my kid loves Pusheen, fight me.
  6. Jul 19, 2022 at 7:43 PM
    #8826
    Skootter14
    Jeremy
    Trying to make sure it was really Craig and not some compromised system that got my email.
    @CS_AR
    CS_AR and CygnusX191 like this.
  7. Jul 19, 2022 at 7:43 PM
    #8827
    Ozarklander
    Ozarklander Well-Known Member
    2018 quicksand dclb
    @CS_AR
    mind sending the link to register for the event again so I can be lazy and not go searching for it?
  8. Jul 19, 2022 at 7:50 PM
    #8828
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    I believe that registration already closed for the prizes, but I'm sure you're welcome to show up and hang out.
  9. Jul 19, 2022 at 9:38 PM
    #8829
    beanulous128
    beanulous128 Well-Known Member
    zach
    Yellville
    2012 TRD Sport DCSB
    So is the bilstein 5100s still an option for leveling a 3rd gen? I think on my 2nd gen access cab I went with 5100s and a stiffer spring to get a level stance. Just didn’t see much info on people running the 5100s on 3rd gens.
    Also on another note still waiting on my 93 pickup 4wd 22re motor to be done. I know that the machine shop has bored it 20 over I believe. Pretty sure I’ve picked up everything needed to slap the motor in and get it running. Just waiting on the motor.
  10. Jul 20, 2022 at 12:44 AM
    #8830
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    It was me.. I was trying to make sure the email wasn't a bot. LOL
  11. Jul 20, 2022 at 12:59 AM
    #8831
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    My experience is they don't. They just need the correct pressure, which is different for every size and based off the actual weight of the vehicle. In general, more sidewall, less psi for a given vehicle weight.
  12. Jul 20, 2022 at 3:10 AM
    #8832
    Ozarklander
    2018 quicksand dclb
    O Dang
  13. Jul 20, 2022 at 5:50 AM
    #8833
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, now that you mention it, higher psi might not be needed for all situations. I mainly wanted to point out that the chalk test is old school and there are more accurate ways to determine what psi you should be running.
    There's a good Toyo guide for converting between tire types and sizes, but it's still a bit confusing to follow. In short, you start with the OEM spec to determine what load it was set up for, then inflate the replacement tires to match that load. With the help of another NWA member, I finally got the conversion calculation correct (I forgot to start by de-rating the OEM load specs since they put P-rated tires on a truck -- I was coming out with higher pressures around 44 psi). For my truck, the conversion came out to 37 psi for E-rated 265/75R16 KO2's. So, this would be the correct pressure for that particular tire and size to match the OEM spec -- BUT, you may want to adjust for your actual load. Mine have been set to 37 and seem to be wearing great. Maybe not the most comfortable ride, but a good compromise between comfort and fuel efficiency, and hopefully longer tire life. Even so, Aaron's cupping issue is likely not caused by the inflation pressure. Most sources indicate a suspension issue, or possibly balance/alignment.
    Here's the Toyo guide: https://www.toyotires.com/tires-101/tire-load-and-inflation-tables/
  14. Jul 20, 2022 at 6:00 AM
    #8834
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Hey Buddy :wave: Welcome....You ought to come to Burns Park (NLR) this Saturday for the Toyota GTG
    Buddy08[QUOTED] and CygnusX191 like this.
  15. Jul 20, 2022 at 6:01 AM
    #8835
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Most tire manufacturers have an inflation guide, but I like Toyos best and use it often. I start with the size and load rating for my actual weight (not GVWR) and adjust from there, verses the chalk test. Agree on the modern application of the chalk test. Usually end up a few pounds lighter, but it's a great place to start.
  16. Jul 20, 2022 at 6:05 AM
    #8836
    PinnaclePete
    Pete
    Central AR
  17. Jul 20, 2022 at 6:15 AM
    #8837
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    Yeah, realistically, I'd guess it's somewhere between the shocks going out or me running 730lb coils with only skid/sliders. :notsure:
  18. Jul 20, 2022 at 6:55 AM
    #8838
    Buddy08
    Buddy08 New Member
    Arkansas
    2015 White DCSB Tacoma TRD Pro
    Unfortunately I work every weekend. Nurse life. Great pay but every weekend takes its toll. I do go to burns quite often shooting my bow when it’s nicer out. Y’all keeps the pics coming. It’s cool seeing the these trucks taking the trips all over the US.
  19. Jul 20, 2022 at 7:24 AM
    #8839
    Buddy08
    Buddy08 New Member
    Arkansas
    49611722-913F-4AE9-8972-20280C794002.jpg 3625D4A9-52E6-4EBC-AACF-4D439A55469F.jpg
    Here’s some pics of mine during hunting season last year. That’s about as much off-roading as I do!
  20. Jul 20, 2022 at 7:30 AM
    #8840
    Bat Trd
    Bat Trd Friendly Neighborhood Batman
    Layne
    Hot Springs, Arkansas
    2014 Tacoma TRDOR DCSB 1D6
    Bruce Wayne taste on an Alfred budget.
