Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Dec 5, 2022 at 10:12 AM
    #9101
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm certainly not an expert, but software engineering background with prior experience with robotics (lots of electronics). But in general, the Weboost is designed to amplify a signal (more sensitive receiver, stronger transmitter than your mobile device), and it creates an additional hop between your client device and the tower. If you've already got a decent signal, it probably won't do much to improve your speeds -- and going through the extra hop may slow things down a little. The main time you might see a speed difference is if you have a single bar without using it and then you switch to using it. The main use case is when you've got spotty or weak connectivity. It can improve things, but don't expect to stream at 1080p in the boonies.
    CS_AR and CygnusX191 like this.
  2. Dec 5, 2022 at 4:33 PM
    #9102
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I’ve been curious about those but haven’t bought one because of what Chip mentioned. You basically have to have your phone right over the router (whatever you’d call it) in order for it to work well. It’s too restrictive for me, so I’ll give it a few more years to improve the tech
    CygnusX191 likes this.
  3. Dec 5, 2022 at 7:14 PM
    #9103
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I went out near Devils Den today to give it a decent test. What I found was if my phone didn't register a signal at all, I wasn't getting one with the Weboost. When I did get a faint signal, the Weboost increased it by about 5dBm. Using my mini ipad, that would give a good increase in download and a moderate increase in upload speed. Enough that checking email and doing light internet use was possible. Certainly not a miracle worker, but I think it will make calls possible in areas that only texts would get out. One thing I did notice when I tried it at home today is it allowed my tablet to connect to 5G when it has only ever been on LTE. Don't know what the usable application of that is, but it's something.
    Worth the money? I guess it remains to be seen. Probably not. What I'm really looking forward to is driving out West in a few months in places I always drop calls to see if it helps stay connected. I will only turn it on in low coverage areas when I need it so it won't interfere with a good signal.
  4. Dec 5, 2022 at 7:18 PM
    #9104
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    They recommend 18-36 inches, so I mounted the inside antenna to the center console. Should be good for anyone up front. I could get a few steps away from the vehicle before it faded.
  5. Dec 6, 2022 at 11:21 AM
    #9105
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  6. Dec 6, 2022 at 11:44 AM
    #9106
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    @CS_AR Did I see you coming up hwy 7 Saturday?
    CygnusX191 and CS_AR like this.
  7. Dec 6, 2022 at 1:33 PM
    #9107
    CS_AR
    Yep. It had to be me. I was on my way up to Ponca and Steel Creek.
  8. Dec 6, 2022 at 1:35 PM
    #9108
    CS_AR
    I've been going to Newton County every weekend since Nov 27th.
  9. Dec 6, 2022 at 2:00 PM
    #9109
    CS_AR
    I think I want to buy some land (5 acres or less) in Newton County.
  10. Dec 6, 2022 at 2:43 PM
    #9110
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    You passed me going N. I was pulling my camper trailer, saw you, and then tried to get you on 16 but you didn't answer. Newton County is nice. I'd love to get a spot outside Parthenon.
    CygnusX191 and CS_AR[QUOTED] like this.
  11. Dec 6, 2022 at 4:37 PM
    #9111
    CS_AR
    Ahh.. I didn't know to be listening on 16. Is that for local comms?
  12. Dec 6, 2022 at 5:21 PM
    #9112
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    Yea, we use 16 for local and the repeaters.
    CS_AR[QUOTED] and CygnusX191 like this.
  13. Dec 6, 2022 at 5:54 PM
    #9113
    CS_AR
    Good to know
  14. Dec 6, 2022 at 6:24 PM
    #9114
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    I thought all 4X4 owners used 16 as it's the only math we know.
  15. Dec 6, 2022 at 6:42 PM
    #9115
    CS_AR
    Or as in 0123456789ABCDEF
  16. Dec 6, 2022 at 6:44 PM
    #9116
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    How did you get my password?
  17. Dec 6, 2022 at 7:55 PM
    #9117
    CS_AR
  18. Dec 6, 2022 at 9:36 PM
    #9118
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    That's either voodoo or witchcraft. Not sure which (witch).
  19. Dec 11, 2022 at 9:28 PM
    #9119
    MatthewMay1
    Matthew
    Lone Star Republic
    Oh this is cool. I didn’t realize you had that much freedom of movement.
    I never made this connection…wow I feel dumb.
    In other news, I pulled this out of my Tacoma yesterday. I should really drive it more often!
  20. Dec 12, 2022 at 4:56 AM
    #9120
    wtp67
    wtp67 Active Member
    Warren
    Arkansas
    2009 Access Cab 4x4
    [/QUOTE]
    Been there.... twice... had to repair/replace wires as well...... ever since my truck has had the awesome aroma of the newest air freshener scent: rat poison.
    MatthewMay1, CygnusX191 and CS_AR like this.
