Any Members in Arkansas?
Discussion in 'South Central' started by Silver1, Jul 16, 2009.
  1. Jan 4, 2023 at 9:45 AM
    #9141
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Looks like a long walk home if you get stuck......:mudding:
    CygnusX191 likes this.
  2. Jan 4, 2023 at 10:30 AM
    #9142
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    Long walk gets real long in waders too :anonymous:
    CygnusX191 and thewrongtone like this.
  3. Jan 4, 2023 at 2:20 PM
    #9143
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    2013 Tacoma 4x4 2017 4Runner TRD Pro
    SCS BR6/ Bilstein 6112/5160/ BajaDesigns Squadron Sport Fog Lights/ BajaDesigns Squadron Pro Ditch Lights/ BajaDesigns S1 Flush Mount Reverse Light/ 32" Light Bar/ Rago Fab Ditch Light Brackets/ CaliRaised Lower Bumper Light Bar Brackets/ BPF Tow hook/ BPF TRD Skid Plate/ Bora 3/4in Wheel Spacers/ Icon 3 Leaf AAL/ BAMF HD Shackles/ TRD Pro Grill/ OEM Roof Rack/ OEM Bed Mat/ Nitto Trail Grapplers/ Every Bulb LED
    Ran into some flooded fields today too.
    CS_AR, CygnusX191 and CRASHMAN50 like this.
  4. Jan 5, 2023 at 5:17 PM
    #9144
    PinnaclePete
    Pete
    Central AR
    Probably look better from the Ozarks……
    Wolf Mooooooon
    CS_AR, CRASHMAN50 and CygnusX191 like this.
  5. Jan 9, 2023 at 8:42 AM
    #9145
    CRASHMAN50
    AA-ron
    Arkansas
    Opinions wanted: I've decided against trying to go to 33s and will get the same 265/75r16 Cooper ST Maxx's again. I could probably run my current set another 5-10k miles, but I've got getting a new set on my mind since I know it's on the horizon. I picked up a cheap set of 2nd gen stock 16 inch rims that I'm going to have the set currently on the truck mounted onto so I can run a pair on the tent trailer and also have a pair of spares til they dry rot, I guess.
    But here's where I'm actually conflicted; I'll have a pair of the old Coopers on the 2nd gen rims as spares. One of those could replace the stock spare tire that's still under the bed if I get a new set of 4 tires. BUT, I also have a 5th rim that matches my truck's rims. So, I could order a 5th new tire, put that new matching spare under the truck, and do 5-wheel rotations. Or is that more trouble than it's worth? Either way, I'm putting a matching-sized tire under the truck, but I'd be interested in everyone's thoughts. A set of 5 would obviously last longer, but I wonder if they WEAR better than a set of 4? :confused:
    CS_AR and CygnusX191 like this.
  6. Jan 9, 2023 at 9:10 AM
    #9146
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I've never done 5-tire rotations, even though I bought 5 tires when I upgraded to the 265/75 KO2's. Heck, I don't even rotate my tires as much as I probably should, but they are wearing evenly. I just wanted my spare to be the same size. My thinking is that you won't get that much more mileage doing a 5-tire rotation, and my spare will likely still be in good shape when I need to replace 4 tires (at least good enough for temporary use). Maybe someone that has done 5-tire rotations will chime in, I just personally don't see it as worth the hassle.
  7. Jan 9, 2023 at 9:41 AM
    #9147
    Ozarklander
    Ozarklander Well-Known Member
    2018 quicksand dclb
    Don’t forget about a 5th tire pressure sensor that you got to worry with.
  8. Jan 9, 2023 at 12:41 PM
    #9148
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Totally forgot about that. That would be a big nope for me.
    FWIW, I cut a sidewall back when I had a Tundra. The tires weren't super worn, but probably 1/4 to 1/3 worn. Replaced it with a new tire and was back getting another front tire within a couple of days. You might not notice it on the back, but on the front it pulled and drove like crap due to the tires being different circumferences. I'd be concerned about this behavior if doing a 5-tire rotation - it would likely force me to rotate quite often.
  9. Jan 9, 2023 at 4:44 PM
    #9149
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    5 when rotated properly will wear the same as four but last significantly longer.
    Not needed since your other tire will go back under the truck. It is within range of the receivers. You'll just have to manually check your air once in a blue moon.
    Rotate every 5000 with your oil changes and you'll be fine. Spare tire goes to back left, back left goes to front left, front left goes to back right, back right Goes to front right, front right goes under the truck for spare.
    Easy breezy :D
  10. Jan 9, 2023 at 5:07 PM
    #9150
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    I thought the stock spare comes with a Tpm sensor??
  11. Jan 9, 2023 at 6:42 PM
    #9151
    Ozarklander
    2018 quicksand dclb
    Some of those fancy “cough cough” 4 runners might have tpms for the spare but the tacomas only have the 4 on the ground. You have to relearn sensors at every rotation any way so it wouldn’t be a big deal just the added expense of another sensor.
  12. Jan 9, 2023 at 10:56 PM
    #9152
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    I really thought my 2013 has a sensor in the spare, if not I’ve been riding around on low tires for a few weeks. My light came on but no tires look low, then again I probably should check on that. :eek:
    Ozarklander[QUOTED] likes this.
  13. Jan 10, 2023 at 3:34 AM
    #9153
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You can be 10 lb low and not look like you're running low. If the light comes on, check your tires. That's what it's for.
    HDMOTT[QUOTED] and Ozarklander like this.
  14. Jan 12, 2023 at 4:42 PM
    #9154
    PinnaclePete
    Pete
    Central AR
    Prinsu $ rack and WeatherTecs make it look so much better, but damn what do I do with all the chrome ?
  15. Jan 13, 2023 at 5:57 AM
    #9155
    CRASHMAN50
    AA-ron
    Arkansas
    Just go all Gen-Z and plastidip it all :rofl:
  16. Jan 13, 2023 at 7:00 PM
    #9156
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Take it to Jeff at Grafitti Graphics in Jacksonville and have him do a chrome delete.
    PinnaclePete and CygnusX191 like this.
  17. Jan 15, 2023 at 11:12 AM
    #9157
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    My preferred route to Murray Falls is from Ozone.
    More problems at the big mudhole up from Union School. I must have bypassed this mess. I don't even remember much about it on November 25th.
  18. Jan 15, 2023 at 11:18 AM
    #9158
    CS_AR
  19. Jan 15, 2023 at 2:59 PM
    #9159
    CS_AR
    Moving up to Petit Jean State Park for our next meet. The Museum of Automobiles has agreed to let us use the entire showground. Save the date. More to come on details and times. Our membership has doubled since last year. We needed a place where we can grow.
  20. Jan 21, 2023 at 4:40 AM
    #9160
    CS_AR
