Any MGM owners paint stock sport wheels gun metal/anthracite
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tactical Tacoma, May 10, 2012.
  1. May 10, 2012 at 12:23 AM
    Tactical Tacoma
    Tactical Tacoma [OP] Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    So I had a 2009 silver stream mica that I painted the stock sport wheels anthracite and it looked great. Even when I traded it in the salesman asked if they were a special order and couldn't believe how well the rattle can job held up over 2 years. Well now I have a 2012 MGM and I'm debating between black or anthracite on the stockers this time.
    Any MGM owners got pics of 17" sports painted anthracite/gun metal?
  2. May 10, 2012 at 12:52 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    No one? I searched but couldn't find any.
  3. May 24, 2012 at 9:30 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Well, I'll be doing this in a couple weeks and post some pics. Got the FJ anthracite TRD center caps in a couple days ago, now just gotta paint the wheels.
  4. May 24, 2012 at 9:34 PM
    TacomaGuy22
    TacomaGuy22 That deserves to be put in the cool story jar..
    I was planning on painting mine black along with all my badges. I would like to see what it looks like. I think the anthracite will good,but you really don't know until its actually under the MGM. Good luck
  5. May 24, 2012 at 9:44 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Yeah I painted my old ones on my 09 SSM and they looked great.
    Another member, Snake~, photoshopped a pic for me to show me what it might look like.
  6. May 24, 2012 at 9:48 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
  7. May 24, 2012 at 10:02 PM
    TacomaGuy22
  8. Dec 9, 2012 at 7:48 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Finally painted the wheels.
    As far as prep and painting, here are the steps I took.
    - removed weights from front lip
    - washed with soapy water and scrubbed with green brilo pad
    - dried with towel
    - wiped with tack cloth
    - sanded with 600 grit
    - rinsed thoroughly with water
    - Dried with towel
    - wiped with tack cloth again
    - taped off valve stems by wrapping tape around stem
    - used index card method between wheel and tire
    - primed with self etching primer
    - dried/heat cured with a heat gun
    - lightly sanded any necessary areas that were not to my liking
    - wiped sanded areas with tack cloth
    - painted with duplicolor "graphite" wheel paint
    - heat cured again
    - took and had them balanced with sticky weights
    - admired hard work
    I tend to over prep, but I have found it better to over prep than to under prep. I have found myself overusing the tack cloth, but I would rather overuse it than have dust and hair particles on the wheel and paint over them.
    Just an FYI for those wondering, yes I painted my calipers red, and my rear OME shocks red. I hated the yellow color the OME shocks were. So, I sanded them down, primed them with universal primer and sprayed them with red VHT spray on caliper paint. Actually, I painted one rear with primer and paint, and the other with red Plastidip, as a test to see which I liked better and which holds up. I will be removing the plastidip from the one rear and painting it with primer and VHT caliper paint. As it looks sharper. The calipers I actually painted with the brush on style caliper paint since its easier to work with on the calipers.
    29B555C3-4AEA-4844-B31C-FF095F8B1028-245_11bdcb3af43054f57cca9324ff53ffb781a0ba2b.jpg
    B6DEEC53-FA6D-4AF5-A01C-6A58FA8BF7CD-245_87ceb72aff6f248e1dbc51f339e64c7b8e27b808.jpg
    C7A26D8E-5AAA-4508-AE15-4B8A57EFB117-245_7d093375f2594fc2e28bc021c995b7cf8d28d952.jpg
  9. Dec 9, 2012 at 7:56 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Ft. Knox, KY / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    OP, that looks great! Do you plan to buy tires?
  10. Dec 9, 2012 at 8:06 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Most definitely! It looks so horrible and goofy right now. But since the company I work for gives me a company car (2013 Avalon Limited, fully loaded) with gas paid for and unlimited personal use :) I barely drive the truck. I bought the truck on May 5th and it only has about 12K on it right now. Just to put things in perspective within 7 months of buying my old 09 brand new, it had 20k-25K on it. I just can't justify spending $$$$ on AT tires, until I wear out the ones it came with. I plan on getting 285/70/17's
  11. Dec 9, 2012 at 8:26 PM
    bullaculla
    bullaculla IKA fabrications
    Honolulu HI
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Looks great, I think there are a few in the MGM thread with painted wheels.
    I might have to do the same!
  12. Dec 9, 2012 at 9:55 PM
    MGoBlue
    MGoBlue Active Member
    Rex
    Ann Arbor, MI
    2013 Tacoma 4X4 TRD Sport
    Debadged, 5% Tint on Rear Windows Over Factory, 35% Tint on Fronts, 1.25" Hub-Centric Spacers with Factory 17" Sport Rims Painted Black, Valentine One Radar Detector Install (ODB Powered), Blacked Out Front Emblem
    Looks great! I may swagger jack you and do this to mine. I have an 13 MGM DCSB. Very good idea to use the FJ Anthracite center caps! How much did those cost you if you don't mind my asking?
    How long did you let them dry after you heat cured them before you put them back on the taco?
  13. Dec 9, 2012 at 10:04 PM
    00PowderSpecial
    00PowderSpecial Well-Known Member
    Chad
    Newfoundland, Canada
    09 TRD DC
    That looks awesome! I've been wanting to do my sport wheels with the same paint, and this sealed the deal for me. Now when I get a chance to do it will be another story, I'll get pics though
  14. Dec 9, 2012 at 10:16 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Looks good.
  15. Dec 9, 2012 at 11:37 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    About $8-11 per center cap, depending on where you buy them. Dealership wanted $18, I told them TRDParts4U.com had them for $10/ea and parts guy matched the price.
    Overnight. So approximately 12 hours.
  16. Dec 9, 2012 at 11:40 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    I noticed you have OME springs but they are red....how'd you go about making that happen?
  17. Dec 10, 2012 at 7:38 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Nice job, looks good! Did you clear coat them too? I'm in the process of doing this myself. I bought 17" FJ alloys on craigslist (5 wheels and tires for $325). The spare is gouged up pretty bad so I'm practicing on it. If it turns out good, I'll do the others. If not, I'll probably get them powder coated.
  18. Dec 10, 2012 at 10:27 AM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Rattle canned and baked them in the oven for a couple of hours. No chips or flakes.
    Make the coat extra thick. After baking them let them just chill in the oven for over night
  19. Dec 10, 2012 at 10:35 AM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    Nice job on the wheels! Definitely gave me an idea.
    Do you happen to remember what the part number was on the center caps you used?
  20. Dec 10, 2012 at 1:00 PM
    MGMTaco2012
    MGMTaco2012 Active Member
    SW FL
    2012 Sport Double Cab
    [​IMG][/url][/IMG]
    I did black over the weekend and it looks great..going for that undercover/miltary look.
