Any negatives for the manual transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bdunna, Aug 29, 2019.
  1. Aug 30, 2019 at 10:21 PM
    #141
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I thought the automatic already came with those. :boink:
    cedarpangolin[QUOTED] likes this.
  2. Aug 30, 2019 at 10:35 PM
    #142
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    Hmmm. Lol
  3. Aug 30, 2019 at 10:51 PM
    #143
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Get with the times?
    July 11, 2019
    https://www.caranddriver.com/news/a27438193/ford-powershift-transmission-problems/
    August 14, 2019
    https://jalopnik.com/fords-dual-clutch-transmission-continues-to-be-a-disast-1837238730
    So when will the DCTs be offered for off road vehicles and trucks ? And when will the DCT be offered in the Tacoma Mr. Einstein?
    You don't know much about Hyundai which affirms your lack of experience:
    https://www.forbes.com/sites/davidk...nd-hyundai-top-quality-rankings/#70af175923e5
    Get with the times..... and lay off the cedar.
  4. Aug 30, 2019 at 11:32 PM
    #144
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    The DCT in the fords is garbage - but more so the programming. VWs have been using DCTs for years, and so have super cars - not too many problems that i’m aware of. One issue with the DCT is that it can only be prepared to upshift or downshift - so if you surprise it, it will need time to shift the cogs from say 3 to 1 before letting you out of 2 - noticeably slower than the hydraulic transmissions
    I don’t see trucks going that route though. The torque converter/hydraulic transmissions work very well for the low speed work required of trucks. - if i worked my truck harder, or wasn’t so into the fun factor, i absolutely would have gone auto for a truck.
    I do ‘t think you can argue longevity either way with modern transmissions. Both do very well if you consider the average time a vehicle is owned. I suppose a strength of the manual trans is they can have many failures and still function well enough to move. (Losing gears, syncros, clutch, etc)
  5. Aug 31, 2019 at 3:47 AM
    #145
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    These trucks with manuals are just that, trucks with manual transmissions. Why expect a leaf spring, midsize, 4×4 pickup truck to shift like a S2000, 350z or M3? These are trucks.
  6. Aug 31, 2019 at 6:14 AM
    #146
    MtnFisher
    ZeroDrift
    Exactly.
    Cedar lost me here:
    I thought we were talking MTs vs CVTs in trucks?
    shakerhood likes this.
  7. Aug 31, 2019 at 7:16 AM
    #147
    Buschman
    Buschman Well-Known Member
    Oregon
    1998 Tacoma V6 4x4 5speed
    Kings, TC uppers , TRD rear end, 4.30s, 285's
    I did not know that, makes me feel a little better about a new truck.
  8. Aug 31, 2019 at 8:13 AM
    #148
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You cannot turn it off on the Tacoma
    tonered likes this.
  9. Aug 31, 2019 at 9:22 AM
    #149
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Amen sir, amen.
  10. Aug 31, 2019 at 9:25 AM
    #150
    cedarpangolin
    Christian
    You’re using fords difficulties as a standard... #fail
    Hyundai has had top notch “initial quality“ for years. This is tested in the first six months of the car being rolled off the manufacturing process.
    Down the road a year or more there’s few things other than FCA that go through more programming, electronics, and reliability issues.
    I love your sarcasm and adamant personality, it’s refreshing to see someone so passionate about inaccurate points.
  11. Aug 31, 2019 at 12:23 PM
    #151
    cupcaketaco
    cupcaketaco Member
    Andy
    2023 Tacoma DCLB
    manual tranny ftw
  12. Aug 31, 2019 at 11:08 PM
    #152
    AKGSD
    Joe
    Alaska
    But you can?
    Auto headlights - switch on the dash
    Blind spot monitor - switch on the dash
    Park aid sensors - switch on the dash
    Radar cruise - hold “on” for 1.5secs
    Lane keep assist warning - settings
    Pedestrian collision detection system - settings
    With programming you can set it to remember the last setting so you don’t have to turn it off every time
    And realistically you can always unplug the sensor
    Annnnd i’ve put on nearly 19k, and while it will beep at my now and then in situations where i know better than it, it’s only engaged the brakes once, a millisecond before i started to
    (Outside radar cruise of course)
  13. Aug 31, 2019 at 11:11 PM
    #153
    shakerhood
    Southern Ohio
    Where would the Sensor be for you to unplug, if I had a guess I would say it works thru the ABS System so you would probably have to completely disable that.
  14. Aug 31, 2019 at 11:12 PM
    #154
    AKGSD
    Joe
    Alaska
    The radar cruise sensor is in the grill. If it can’t see it’s not going to hit the brakes. This will obviously put some warning lights on the dash.
  15. Aug 31, 2019 at 11:13 PM
    #155
    shakerhood
    Southern Ohio
    What does that have to do with the Hill Holder on the Sport?
  16. Aug 31, 2019 at 11:15 PM
    #156
    AKGSD
    Joe
    Alaska
    Dafuq? You quoted my post about the safety systems you can disable that you claimed could not be.
    It has /jack shit/ to do with hill hold assist
  17. Aug 31, 2019 at 11:17 PM
    #157
    shakerhood
    Southern Ohio
    You quoted me in Post #152 which was about the Hill Holder on the Sport, has nothing to do with TSS. Probably just confusion about 2 different subjects in the same thread.
  18. Aug 31, 2019 at 11:20 PM
    #158
    AKGSD
    Joe
    Alaska
    Nope. Hit the quote arrows up all the way, i quoted buschman initially, in regards to TSS - not anything about hill assist
  19. Aug 31, 2019 at 11:21 PM
    #159
    shakerhood
    Southern Ohio
    Right, 2 different subjects in the same thread, sorry for the confusion.
    AKGSD[QUOTED] likes this.
  20. Aug 31, 2019 at 11:22 PM
    #160
    AKGSD
    Joe
    Alaska
    No worries haha
