Any one ever heard of or used Sky Manufacturing?
Discussion in 'Solid Axle Suspension' started by luk8272, Jun 15, 2011.
  1. Jun 15, 2011 at 6:13 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  2. Jun 15, 2011 at 6:16 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I've heard of them before, I'm pretty sure they have a good reputation. TTORA will have more people that have experience with them.
  3. Jun 16, 2011 at 3:50 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Are you in the market for doing a SAS? Sky manufacturing is good. However it's just like trailgear... It's just a basic starter kit to help you get going. Check out my sticky at the top of this section and do some reading about SAS. Any questions and I'm more than happy to help answer them.
  4. Jun 16, 2011 at 9:43 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Slowly but surely i'll get it done i'm in no hurry as I'm getting the engine working properly at the moment. Fuel tank issues. I have a very nice and clean 1990 3.slow IFS, pretty much stock at the moment. I've been learning and collecting parts, mostly learning. I have a 1982 Toy front axle with stock 4.10 gears to match my ratio. When I came across the sky kit I was searching for some stock leafs. I won't likely buy a kit but piece it together. I'm sure I'll contact you in the future.
  5. Jun 26, 2011 at 8:28 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Fireturk used some sky stuff on his SAS...I don't know if he used this or just individual parts...
  6. Jun 27, 2011 at 11:09 PM
    erisman33
    erisman33 Crawlin Over 1 Rock At A Time
    Pismo/Mendocino
    1995 Ton'd Taco
    1 Tons with 4 Wheel Disc
    If you want the best kit for your needs build it your self. It tends to be cheaper also but not always the case. Sky is a good company but so is a lot of other company out there like: Front Range Offroad, All Pro, Trail Gear for kits. If you want to build it yourself go to ruff stuff and ballistic fab and make it what you want.
