Any one have experience with ALPINE KTP-445U?
Discussion in 'Audio & Video' started by larrybbaker, Jul 22, 2013.
  1. Jul 22, 2013 at 7:45 PM
    larrybbaker
    larrybbaker [OP] Well-Known Member
    larry
    South Central PA
    2013 MGM DCLB TRD SPORT 4WD
    OME 885 | Bilstein 5100 x 4 | WeatherTech Window Visors | VAIS Tech SiriusXM Adapter |Alpine KTP-445U Amp | Anytime fog light mod
    http://www.alpine-usa.com/product/view/ktp-445u/
    Looking for an easy bump in sound quality/volume. Seems to have decent reviews.
    Rather not get into a too laborious install of a "regular" amp, and trying to stick with stock radio... for now anyway.
    Thanks!
  2. Jul 23, 2013 at 5:39 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    My local audio shop sells these left and right from trucks to cars to boats to even motorcycles. For that price and how compact that amp is. You can't go wrong. If you focus on front staging you can always bridge it to run two components up front and run the rear speakers off the deck. It'll improve over stock but it'll blow those cheap stock paper cone speakers. I would install this if you want to run the factory deck with aftermarket speakers. Because no amount of amp power will make those stock speakers sound good.
  3. Jul 23, 2013 at 7:24 AM
    eric3187
    eric3187 Well-Known Member
    i have one, it definitely gets the speakers louder. im running it bridged into 2 channel mode. i use the EQ on the headunit to set Lowpass filters and such.
    if you want louder, this is a easy way to go. if you want to really tune the stereo, a true 4 channel amp is your best bet
    no complaints.
    ill be running one on my next vehichle as well but the Alpine specific one for alpine decks.
  4. Jul 23, 2013 at 9:18 PM
    larrybbaker
    larry
    South Central PA
    Thanks for the input! It is bought… sitting in the back seat for a convenient time to install. Waiting for anxiety of cutting the stock wiring to pass…
  5. Aug 1, 2013 at 6:29 PM
    larrybbaker
    larry
    South Central PA
    Installed today. Definite improvement in overall sound quality and volume. Will have to tweak gain and filter settings over the next few days. Unit fit nicely above the stock radio - I VELCROed it to the underside of the dash. One tip - add length between the radio out and amp in leads - otherwise you won't be able to fit it in anywhere… learned that the hard way.
  6. Aug 2, 2013 at 5:45 AM
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Have had my eye on this for a while - how was the install and what did you tap into for all the input/power?
  7. Aug 2, 2013 at 7:36 PM
    larrybbaker
    larry
    South Central PA
    Install was pretty painless - like I said add some length to the in wires or you will have a heck of a time getting it in place above the HU. Power - I tapped the HU power lead. Ground went to easily accessible bolt behind glove box. Unit is remote sensing if using line in (as opposed to RCA) so no need for the blue/remote wire.
    Sound quality is greatly improved. Still probably going to have to tweak the gain settings once I get a better feel for it.
  8. Sep 3, 2013 at 8:38 AM
    919motoring
    919motoring Active Member
    Shaun
    Raleigh, NC
    13 DC Mag Gray TRD sport 4x4
    We use a parrot hands free t-harness so we don't have to cut factory wiring
