Any one having back pain issues/feeling uncomfortable with 2010 Tacoma seats
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Mar 12, 2010.
  1. Apr 22, 2010 at 8:06 PM
    Country
    Country Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    I destroyed my back in the military and have not found a seat yet that is comfortable, so I just suck it up and deal with it
  2. Apr 22, 2010 at 11:52 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    I have the sport seats and they are terrible as well. They have zero support and cause me to hunch over as well. These are the worst seats of any vehicle I have every owned. The seats in my Lexus IS350 sucked to, what is Toyota thinking putting these shitty designed seats in for?
    I am going to consider getting a lumbar pillow as well. Does anyone know who makes the best one. One that has some lateral and vertical support would be best.
  3. Apr 23, 2010 at 12:12 AM
    philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    - philo
    Nashville, TN
    2010 Gray Tacoma TRD
    Tom Woods Custom Driveshaft
    i thought i was the only one
    i have an injured lower back and neck, and i find the seats and seating position uncomfortable
    i was thinking of modding the seat rails to raise the seat an inch or so, give me better leg extension, and straighten out my back
    it seems the seat design, which among other things is too narrow, causing hunching and centers your weight more toward the leg, rather than your core
    i don't love it, but i think it's fixable
  4. Apr 23, 2010 at 12:54 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Why don't you try a $12 solution B 4 a $2000 one ? Post right above yours. "I use a lumbar pillow, approx $12 at R & S or Walmart. It works 4 me. "[​IMG]
  5. Apr 23, 2010 at 4:04 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    If you've got an '09+ the headrests are different and are pushed forward. These cause you to sit all hunched over and might be causing your back pains. Its retarded.
    You can flip the headrest around backwards, or get a set off a Scion tC so you can drive without a gorilla hunch.
  6. Apr 23, 2010 at 5:56 AM
    plain_taco
    plain_taco Member
    J
    Austin
    plain 09 tacoma
    ARE MX cap with Yakima rack and slider windoors
    I guess everyone is different. I'm 6'5" and I find the bench in my '09 reg cab to be very comfortable...even on longer drives.
  7. Apr 23, 2010 at 7:01 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I have the seat up much straighter than I did in previous vehicles and have the SR5 lumber adjustment at almost 100%.
    The problem for me is that the back portion of the SR5 seat seems to be too low. I am trying to figure out how to put washers or mount some type of spacer to the rear seat bolts.
  8. Apr 23, 2010 at 7:08 AM
    Avman2119
    Avman2119 Well-Known Member
    Alex
    Colorado
    2010 Tacoma TRD Sport
    If you're seat is more upright ur back won't hurt. I had the same issue cause i used to lean the seat back, if you put it upright it's much more comfortable since it's more ergonomic
  9. Apr 26, 2010 at 3:28 PM
    Captain3
    Captain3 Member
    2010 Prerunner SR5
    I've talked with several people since my last post. The overarching problem is the height of the seat. The seat sits 10 inches from the floor. My Silverado and my wife Highlander each sit 12" from the floor. The lesser height lifts your legs and over time causes you the lower back pain. I talked with an upholstery shop this afternoon and he said welcome to Toyota. The back pain is a common problem and there is not much that can be done to solve the problem. The upholstery dealer owned a JTCruiser and he too has had back pain. He said he just lives with it because he likes the truck. My solution is going to be to trade the new vehicle in a something different.
    Kinda Sucks to buy something that you just can't drive!
  10. Apr 26, 2010 at 4:08 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    ^ Can't you raise the seats by 2"? Can't the shop add more padding and extend the seat out front to suppor the legs?
  11. Apr 26, 2010 at 4:26 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    Its true that 09+ trucks have a different head rest that kind of pushes your head forward. and I think thats a factor too. I will replacing it with something different.
  12. Apr 26, 2010 at 6:24 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Amazing what people will complain about. My TRD Sport seats are amazing,much better then the SR5 ones I used to have in my 2008, but thats one reason the TRD is more $$. Before you upgrade, just trade it in for the TRD probobly the same $$$
  13. Apr 26, 2010 at 6:53 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    ^^^ you think complaining about something that puts you in constant pain is unreasonable?
  14. Apr 26, 2010 at 7:01 PM
    Shack
    Shack Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    I could have wrote this very same post myself. Weird...:amen:
  15. Apr 27, 2010 at 3:53 PM
    #35
    Captain3
    Captain3 Member
    2010 Prerunner SR5
    The SR5 seats have less padding than the TRD sport seats. I drove a TRD last Saturday for about an hour and a half. It was much better. Problem is the replacement TRD seat to buy and put in the SR5 is 2K. To trade the new SR5 vehicle in and buy the TRD truck the trade in on the SR5 is 4K less than I payed for the truck 60 days ago. OUCH! I'd hate to spend 2K and find out two weeks later that the height is truly the cause and the TRD seat did not fix the problem. One of the posts above talks negatively against the TRD seat.
  16. Apr 27, 2010 at 4:16 PM
    #36
    sincitytaco
    Las Vegas
    the seats in all toyotas are piss poor shit. I have owned Tacomas, 4runners, is350, gs460s. All the seats suck compared to an entry level german car.
    Now Audi seats, especially in their S lines are phenomenal.
  17. Apr 27, 2010 at 4:40 PM
    #37
    pauldotcom
    Paul
    MA
    Didn't you guys test drive the damn truck first? If you think the seats are piss-poor then don't drive a Toyota. And sorry, the guy that said he only spends 10min in the truck and it is killing his back, give me a break. Try buying a quality bed or somthing because 10 minutes isn't going to do it.
  18. Apr 27, 2010 at 5:10 PM
    #38
    DCE469
    DCE469 New Member
    Dave
    Northwest Indiana
    10 SR5 4x4
    Rugged Cover Tri Fold Bed cover
    I bought my 2010 DC SR5 4x4 in January. Most of my driving is less than 18 miles. I took a 2 hour trip last week, and when I got out of the truck I could only stand @ a 45 degree angle. Until I saw this post I thought maybe it was just me not finding the "sweet spot". I wondered if the side air bags played a role?
  19. Apr 28, 2010 at 8:38 PM
    #39
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
    I just bought my 2010 Taco after driving an 05 4Runner...the 4Runner's had a better lumbar support...the one in the Taco doesn't go out far enough...
  20. Apr 28, 2010 at 8:55 PM
    #40
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    I think it's more ergonomics for different body types than it is seat comfort. The seats are padded and they fit some body types. I can't get comfortable in Honda cars or Nissan Titans or F150 bench seats. They just don't fit or adjust to me.
